[petsc-users] [EXTERNAL] Re: Is there anything like a "DMPlexSetCones()" ?
Matthew Knepley
knepley at gmail.com
Mon May 6 06:52:04 CDT 2024
On Fri, May 3, 2024 at 7:32 PM Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>
wrote:
> "Right, but that means that the connectivity you read in is not in local
> numbering. You will have to renumber it, so making a copy is probably
> necessary anyway. This is the same sort of processing I do for the parallel
> read."
> True, the connectivity is read in global numbering.
> Renumbering is facilitated by the table from PetscHashSetI.
> The connectivity list I am able to renumber in place though, I don't see
> the need to have another interim copy of the numbers.
> My concern is that I have two memory chunks that both contain the same
> information.
> The only reason It has to be this way is because I can't manually set the
> Cones first and the Chart/ConeSizes second.
The cone sizes are used to allocate the array to hold the cones. How would
you have an array holding the cone information without knowing the sizes?
Matt
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Friday, May 3, 2024 6:45 PM
> *To:* Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject:* Re: [EXTERNAL] Re: [petsc-users] Is there anything like a
> On Wed, May 1, 2024 at 6:30 PM Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>
> wrote:
> "You know the number of cells if you can read connectivity. Do you mean
> that the format does not tell you
> the number of vertices?"
> Sort of...
> So, the format does provide the number of vertices, however, due to the
> way I read the data in parallel I don't know immediately how many local
> vertices there will be.
> Which prevents me from knowing the chart a priori.
> I figured out the number of vertices using PetscHashSetI to determine the
> number of unique entries in the connectivity list.
> read.
> Thanks,
> Matt
> *Sent:* Wednesday, May 1, 2024 8:52 PM
> On Wed, May 1, 2024 at 4:23 PM Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>
> wrote:
> Matt:
> My bad again, I need to clarify something that I just realized doesn't
> make sense.
> I said: "The nature of the I/O makes it so that I need to read the
> connectivity before I get a semblance of buffer sizes."
> Scratch that, obviously, if I can read the connectivity, I know the buffer
> sizes.
> What I should have said is that I cannot know the "chart" that one sets in
> DMPlexSetChart() a priori like in most cases.
> I need to determine the chart from the connectivity lists.
> Thanks,
> Matt
> *From:* Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>
> *Sent:* Wednesday, May 1, 2024 8:17 PM
> *To:* Matthew Knepley <knepley at gmail.com>
> Matt:
> "I do not understand the "flag check". What is that?"
> My bad, I should have referred to the "dm->setupcalled".
> I believe this PetscBool is checked by the other DM (not just DMPlex) APIs.
> The subsequent checks for dm->setupcalled == PETSC_TRUE is what I meant to
> say.
> Here's a copy of DMSetUp().
> *PetscErrorCode <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscErrorCode/__;!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZer-j-oyw$ > DMSetUp <https://urldefense.us/v3/__https://petsc.org/release/manualpages/DM/DMSetUp/__;!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZeoSbWShF$ >(DM <https://urldefense.us/v3/__https://petsc.org/release/manualpages/DM/DM/__;!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZejDeWAFT$ > dm)*
> 817: {
> 818: PetscFunctionBegin <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscFunctionBegin/__;!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZektoWvJh$ >;
> 820: if (dm->setupcalled) PetscFunctionReturn <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscFunctionReturn/__;!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZeu0w4xLy$ >(PETSC_SUCCESS <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscErrorCode/__;!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZer-j-oyw$ >);
> 821: PetscTryTypeMethod <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscTryTypeMethod/__;!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZepyDqHVK$ >(dm, setup);
> 822: dm->setupcalled = PETSC_TRUE <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PETSC_TRUE/__;!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZevcdAZDo$ >;
> 823: PetscFunctionReturn <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscFunctionReturn/__;!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZeu0w4xLy$ >(PETSC_SUCCESS <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscErrorCode/__;!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZer-j-oyw$ >);
> 824: }
> "We could make a DMPlexSetCones(), but as you point out, the workflow for
> DMSetUp() would have to change. Where does the memory come from for your
> connectivity?"
> It's a memory that I myself allocate based on a file's contents.
> The nature of the I/O makes it so that I need to read the connectivity
> Otherwise, I would stick to the tried and tested way.
> Also, when replying to the PETSc developers, users must reply to
> petsc-users at mcs.anl.gov and not just to the individual email accounts of
> the developers, right?
> *Sent:* Wednesday, May 1, 2024 8:07 PM
> *Subject:* [EXTERNAL] Re: [petsc-users] Is there anything like a
> *CAUTION:* This email originated outside of Embry-Riddle Aeronautical
> University. Do not click links or open attachments unless you recognize the
> sender and know the content is safe.
> On Wed, May 1, 2024 at 3:34 PM Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>
> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Dear PETSc team:
> For a project that I'm working on, I need to manually build a DMPlex.
> From studying the source code of the various APIs in which the plex is
> built from some supported file format, I get that the workflow is this:
> 1. DMPlexSetChart() <-- Input nCells + nVerts
> 2. DMPlexSetConeSize() <-- Input ConeSize for each point in [0,nCells)
> 3. DMSetUp() – Allocates memory internally.
> 4. DMPlexGetCones() --> Gives you the memory onto which to write the
> cell connectivity.
> 5. *Write connectivity*
> 6. DMPlexReorderCell() <-- For each point in [0,nCells)
> I'm in a situation where the memory given by step (4) is available
> a-priori.
> I was hoping to skip steps 2, 3 , and 4 with something like a
> "DMPlexSetCones()", but such an API does not exist.
> My current workaround is to implement steps 2 through 4 as always and have
> double the memory allocated in the interim (my instance + DM's internal
> instance).
> I was thinking of looking for the name of the struct member and = it to my
> memory, but I can't overcome the flag check in DMSetUp() during later calls
> to DMPlexGetCones() or DMPlexGetTransitiveClosure().
> connectivity?
> Thanks,
> Matt
> Sincerely:
> *J.A. Ferrand*
> Embry-Riddle Aeronautical University - Daytona Beach - FL
> Ph.D. Candidate, Aerospace Engineering
> M.Sc. Aerospace Engineering
> B.Sc. Aerospace Engineering
> B.Sc. Computational Mathematics
> *Phone:* (386)-843-1829
> *Email(s):* ferranj2 at my.erau.edu
> jesus.ferrand at gmail.com
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZelBUE2lU$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZer6CMguM$ >
> Dear PETSc team:
> cell connectivity.
> a-priori.
> instance).
> connectivity?
> Thanks,
> Matt
> Sincerely:
> *J.A. Ferrand*
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> wrote:
> Matt:
> make sense.
> sizes.
> Thanks,
> Matt
> Matt:
> say.
> 817: {
> 824: }
> connectivity?"
> Dear PETSc team:
> cell connectivity.
> a-priori.
> instance).
> connectivity?
> Thanks,
> Matt
> Sincerely:
> *J.A. Ferrand*
> experiments lead.
> -- Norbert Wiener
> Dear PETSc team:
> cell connectivity.
> a-priori.
> instance).
> connectivity?
> Thanks,
> Matt
> Sincerely:
> *J.A. Ferrand*
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> Sort of...
> read.
> Thanks,
> Matt
> wrote:
> Matt:
> make sense.
> sizes.
> Thanks,
> Matt
> Matt:
> say.
> 817: {
> 824: }
> connectivity?"
> Dear PETSc team:
> cell connectivity.
> a-priori.
> instance).
> connectivity?
> Thanks,
> Matt
> Sincerely:
> *J.A. Ferrand*
> experiments lead.
> -- Norbert Wiener
> Dear PETSc team:
> cell connectivity.
> a-priori.
> instance).
> connectivity?
> Thanks,
> Matt
> Sincerely:
> *J.A. Ferrand*
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> wrote:
> Matt:
> make sense.
> sizes.
> Thanks,
> Matt
> Matt:
> say.
> 817: {
> 824: }
> connectivity?"
> Dear PETSc team:
> cell connectivity.
> a-priori.
> instance).
> connectivity?
> Thanks,
> Matt
> Sincerely:
> *J.A. Ferrand*
> experiments lead.
> -- Norbert Wiener
> Dear PETSc team:
> cell connectivity.
> a-priori.
> instance).
> connectivity?
> Thanks,
> Matt
> Sincerely:
> *J.A. Ferrand*
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZelBUE2lU$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fO0pwSt99ISQDFM7Ioe1NhbBE_v7qVVrHxyaL60C6opn3c9PYf5hK7WjgrAQJUZh1UQDk3UhZUjZer6CMguM$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240506/2312c394/attachment-0001.html>
