[petsc-users] [EXTERNAL] Re: Is there anything like a "DMPlexSetCones()" ?
Matthew Knepley
knepley at gmail.com
Fri May 3 17:45:16 CDT 2024
On Wed, May 1, 2024 at 6:30 PM Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>
wrote:
> "You know the number of cells if you can read connectivity. Do you mean
> that the format does not tell you
> the number of vertices?"
> Sort of...
> So, the format does provide the number of vertices, however, due to the
> way I read the data in parallel I don't know immediately how many local
> vertices there will be.
> Which prevents me from knowing the chart a priori.
> I figured out the number of vertices using PetscHashSetI to determine the
> number of unique entries in the connectivity list.
Right, but that means that the connectivity you read in is not in local
numbering. You will have to renumber it, so making a copy is probably
necessary anyway. This is the same sort of processing I do for the parallel
read.
Matt
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Wednesday, May 1, 2024 8:52 PM
> *To:* Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject:* Re: [EXTERNAL] Re: [petsc-users] Is there anything like a
> On Wed, May 1, 2024 at 4:23 PM Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>
> wrote:
> Matt:
> My bad again, I need to clarify something that I just realized doesn't
> make sense.
> I said: "The nature of the I/O makes it so that I need to read the
> connectivity before I get a semblance of buffer sizes."
> Scratch that, obviously, if I can read the connectivity, I know the buffer
> sizes.
> What I should have said is that I cannot know the "chart" that one sets in
> DMPlexSetChart() a priori like in most cases.
> I need to determine the chart from the connectivity lists.
> Thanks,
> Matt
> *From:* Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>
> *Sent:* Wednesday, May 1, 2024 8:17 PM
> *To:* Matthew Knepley <knepley at gmail.com>
> Matt:
> "I do not understand the "flag check". What is that?"
> My bad, I should have referred to the "dm->setupcalled".
> I believe this PetscBool is checked by the other DM (not just DMPlex) APIs.
> The subsequent checks for dm->setupcalled == PETSC_TRUE is what I meant to
> say.
> Here's a copy of DMSetUp().
> *PetscErrorCode <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscErrorCode/__;!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowpJ3s88P$ > DMSetUp <https://urldefense.us/v3/__https://petsc.org/release/manualpages/DM/DMSetUp/__;!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowpy3zGSd$ >(DM <https://urldefense.us/v3/__https://petsc.org/release/manualpages/DM/DM/__;!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowt_sd2eh$ > dm)*
> 817: {
> 818: PetscFunctionBegin <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscFunctionBegin/__;!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowuMbcxmD$ >;
> 820: if (dm->setupcalled) PetscFunctionReturn <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscFunctionReturn/__;!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowhC986W-$ >(PETSC_SUCCESS <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscErrorCode/__;!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowpJ3s88P$ >);
> 821: PetscTryTypeMethod <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscTryTypeMethod/__;!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowrbaxERF$ >(dm, setup);
> 822: dm->setupcalled = PETSC_TRUE <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PETSC_TRUE/__;!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowoILDY_P$ >;
> 823: PetscFunctionReturn <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscFunctionReturn/__;!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowhC986W-$ >(PETSC_SUCCESS <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscErrorCode/__;!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowpJ3s88P$ >);
> 824: }
> "We could make a DMPlexSetCones(), but as you point out, the workflow for
> DMSetUp() would have to change. Where does the memory come from for your
> connectivity?"
> It's a memory that I myself allocate based on a file's contents.
> The nature of the I/O makes it so that I need to read the connectivity
> Otherwise, I would stick to the tried and tested way.
> Also, when replying to the PETSc developers, users must reply to
> petsc-users at mcs.anl.gov and not just to the individual email accounts of
> the developers, right?
> *Sent:* Wednesday, May 1, 2024 8:07 PM
> *Subject:* [EXTERNAL] Re: [petsc-users] Is there anything like a
> *CAUTION:* This email originated outside of Embry-Riddle Aeronautical
> University. Do not click links or open attachments unless you recognize the
> sender and know the content is safe.
> On Wed, May 1, 2024 at 3:34 PM Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>
> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Dear PETSc team:
> For a project that I'm working on, I need to manually build a DMPlex.
> From studying the source code of the various APIs in which the plex is
> built from some supported file format, I get that the workflow is this:
> 1. DMPlexSetChart() <-- Input nCells + nVerts
> 2. DMPlexSetConeSize() <-- Input ConeSize for each point in [0,nCells)
> 3. DMSetUp() – Allocates memory internally.
> 4. DMPlexGetCones() --> Gives you the memory onto which to write the
> cell connectivity.
> 5. *Write connectivity*
> 6. DMPlexReorderCell() <-- For each point in [0,nCells)
> I'm in a situation where the memory given by step (4) is available
> a-priori.
> I was hoping to skip steps 2, 3 , and 4 with something like a
> "DMPlexSetCones()", but such an API does not exist.
> My current workaround is to implement steps 2 through 4 as always and have
> double the memory allocated in the interim (my instance + DM's internal
> instance).
> I was thinking of looking for the name of the struct member and = it to my
> memory, but I can't overcome the flag check in DMSetUp() during later calls
> to DMPlexGetCones() or DMPlexGetTransitiveClosure().
> connectivity?
> Thanks,
> Matt
> Sincerely:
> *J.A. Ferrand*
> Embry-Riddle Aeronautical University - Daytona Beach - FL
> Ph.D. Candidate, Aerospace Engineering
> M.Sc. Aerospace Engineering
> B.Sc. Aerospace Engineering
> B.Sc. Computational Mathematics
> *Phone:* (386)-843-1829
> *Email(s):* ferranj2 at my.erau.edu
> jesus.ferrand at gmail.com
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowhNf6eH7$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowmj1eqYm$ >
> Dear PETSc team:
> cell connectivity.
> a-priori.
> instance).
> connectivity?
> Thanks,
> Matt
> Sincerely:
> *J.A. Ferrand*
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> wrote:
> Matt:
> make sense.
> sizes.
> Thanks,
> Matt
> Matt:
> say.
> 817: {
> 824: }
> connectivity?"
> Dear PETSc team:
> cell connectivity.
> a-priori.
> instance).
> connectivity?
> Thanks,
> Matt
> Sincerely:
> *J.A. Ferrand*
> experiments lead.
> -- Norbert Wiener
> Dear PETSc team:
> cell connectivity.
> a-priori.
> instance).
> connectivity?
> Thanks,
> Matt
> Sincerely:
> *J.A. Ferrand*
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowhNf6eH7$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!e603Zn0jXSCVvzNnzzRiius-0-C5jw6GGzCOFJ7EW5nKTGdX8aI6qchOlBW23rM9TlwMTiidfBsowmj1eqYm$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240503/e01bd796/attachment-0001.html>
