[petsc-users] [petsc-maint] Assistance Needed with PETSc KSPSolve Performance Issue
Barry Smith
bsmith at petsc.dev
Fri Jun 28 16:11:01 CDT 2024
In the branch I introduce at https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7658__;!!G_uCfscf7eWS!bDIUaHqh4wl1qOCJcAguXJHWFoOm4VTVCLhaVCpC9UKNvTShW_jjtq_DiWBWpbj0cSsF0wPyRAJm2hzppiiRwaE$
On src/ksp/ksp/tutorials/ex45.c on a good memory bandwidth Intel system using the options
OMP_NUM_THREADS=1-64 ./ex45 -pc_type none -da_refine 4 -ksp_max_it 100 -log_view -ksp_gmres_preallocate true -blas_view -vec_maxpy_use_gemv -ksp_converged_reason -ksp_view
I get pretty good performance improvement with speedups of 24 MatMult, 15 VecMdot, 27 VecMAXPY
I also get good speedups on an M2 Mac.
I am trying, slowly, to improve the experience of OpenMP users of PETSc (with or without MPI).
$ OMP_NUM_THREADS=1 ./ex45 -pc_type none -da_refine 4 -ksp_max_it 100 -ksp_monitor -log_view -ksp_gmres_preallocate true -blas_view -vec_maxpy_use_gemv -ksp_converged_reason -ksp_view | egrep -e MatMult -e MAXPY -e MDot
MatMult 104 1.0 9.6804e-01 1.0 1.22e+09 1.0 0.0e+00 0.0e+00 0.0e+00 28 17 0 0 0 28 17 0 0 0 1263
VecMDot 100 1.0 8.6170e-01 1.0 2.65e+09 1.0 0.0e+00 0.0e+00 0.0e+00 25 38 0 0 0 25 38 0 0 0 3072
VecMAXPY 104 1.0 9.4225e-01 1.0 2.83e+09 1.0 0.0e+00 0.0e+00 0.0e+00 27 40 0 0 0 27 40 0 0 0 3003
$ OMP_NUM_THREADS=2 ./ex45 -pc_type none -da_refine 4 -ksp_max_it 100 -ksp_monitor -log_view -ksp_gmres_preallocate true -blas_view -vec_maxpy_use_gemv -ksp_converged_reason -ksp_view | egrep -e MatMult -e MAXPY -e MDot
MatMult 104 1.0 5.2966e-01 1.0 1.22e+09 1.0 0.0e+00 0.0e+00 0.0e+00 25 17 0 0 0 25 17 0 0 0 2308
VecMDot 100 1.0 4.8504e-01 1.0 2.65e+09 1.0 0.0e+00 0.0e+00 0.0e+00 23 38 0 0 0 23 38 0 0 0 5457
VecMAXPY 104 1.0 4.9861e-01 1.0 2.83e+09 1.0 0.0e+00 0.0e+00 0.0e+00 23 40 0 0 0 23 40 0 0 0 5674
$ OMP_NUM_THREADS=4 ./ex45 -pc_type none -da_refine 4 -ksp_max_it 100 -ksp_monitor -log_view -ksp_gmres_preallocate true -blas_view -vec_maxpy_use_gemv -ksp_converged_reason -ksp_view | egrep -e MatMult -e MAXPY -e MDot
MatMult 104 1.0 2.9545e-01 1.0 1.22e+09 1.0 0.0e+00 0.0e+00 0.0e+00 20 17 0 0 0 20 17 0 0 0 4137
VecMDot 100 1.0 2.7871e-01 1.0 2.65e+09 1.0 0.0e+00 0.0e+00 0.0e+00 18 38 0 0 0 18 38 0 0 0 9496
VecMAXPY 104 1.0 2.9648e-01 1.0 2.83e+09 1.0 0.0e+00 0.0e+00 0.0e+00 20 40 0 0 0 20 40 0 0 0 9543
$ OMP_NUM_THREADS=8 ./ex45 -pc_type none -da_refine 4 -ksp_max_it 100 -ksp_monitor -log_view -ksp_gmres_preallocate true -blas_view -vec_maxpy_use_gemv -ksp_converged_reason -ksp_view | egrep -e MatMult -e MAXPY -e MDot
MatMult 104 1.0 1.6195e-01 1.0 1.22e+09 1.0 0.0e+00 0.0e+00 0.0e+00 15 17 0 0 0 15 17 0 0 0 7547
VecMDot 100 1.0 1.4976e-01 1.0 2.65e+09 1.0 0.0e+00 0.0e+00 0.0e+00 14 38 0 0 0 14 38 0 0 0 17674
VecMAXPY 104 1.0 1.5640e-01 1.0 2.83e+09 1.0 0.0e+00 0.0e+00 0.0e+00 14 40 0 0 0 14 40 0 0 0 18090
$ OMP_NUM_THREADS=16 ./ex45 -pc_type none -da_refine 4 -ksp_max_it 100 -ksp_monitor -log_view -ksp_gmres_preallocate true -blas_view -vec_maxpy_use_gemv -ksp_converged_reason -ksp_view | egrep -e MatMult -e MAXPY -e MDot
MatMult 104 1.0 9.0148e-02 1.0 1.22e+09 1.0 0.0e+00 0.0e+00 0.0e+00 11 17 0 0 0 11 17 0 0 0 13558
VecMDot 100 1.0 6.9346e-02 1.0 2.65e+09 1.0 0.0e+00 0.0e+00 0.0e+00 8 38 0 0 0 8 38 0 0 0 38167
VecMAXPY 104 1.0 6.9274e-02 1.0 2.83e+09 1.0 0.0e+00 0.0e+00 0.0e+00 8 40 0 0 0 8 40 0 0 0 40842
$ OMP_NUM_THREADS=24 ./ex45 -pc_type none -da_refine 4 -ksp_max_it 100 -ksp_monitor -log_view -ksp_gmres_preallocate true -blas_view -vec_maxpy_use_gemv -ksp_converged_reason -ksp_view | egrep -e MatMult -e MAXPY -e MDot
MatMult 104 1.0 7.4300e-02 1.0 1.22e+09 1.0 0.0e+00 0.0e+00 0.0e+00 8 17 0 0 0 8 17 0 0 0 16450
VecMDot 100 1.0 5.7918e-02 1.0 2.65e+09 1.0 0.0e+00 0.0e+00 0.0e+00 7 38 0 0 0 7 38 0 0 0 45698
VecMAXPY 104 1.0 5.2788e-02 1.0 2.83e+09 1.0 0.0e+00 0.0e+00 0.0e+00 6 40 0 0 0 6 40 0 0 0 53597
$ OMP_NUM_THREADS=64 ./ex45 -pc_type none -da_refine 4 -ksp_max_it 100 -ksp_monitor -log_view -ksp_gmres_preallocate true -blas_view -vec_maxpy_use_gemv -ksp_converged_reason -ksp_view | egrep -e MatMult -e MAXPY -e MDot
MatMult 104 1.0 6.4348e-02 1.0 1.22e+09 1.0 0.0e+00 0.0e+00 0.0e+00 8 17 0 0 0 8 17 0 0 0 18994
VecMDot 100 1.0 5.8682e-02 1.0 2.65e+09 1.0 0.0e+00 0.0e+00 0.0e+00 8 38 0 0 0 8 38 0 0 0 45103
VecMAXPY 104 1.0 3.4760e-02 1.0 2.83e+09 1.0 0.0e+00 0.0e+00 0.0e+00 4 40 0 0 0 4 40 0 0 0 81394
> On Jun 28, 2024, at 2:33 PM, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> OK, then you need '--with-mkl_pardiso-dir='+os.environ['MKLROOT'] in petsc configure
> --Junchao Zhang
> On Fri, Jun 28, 2024 at 1:05 PM Pierre Jolivet <pierre.jolivet at lip6.fr <mailto:pierre.jolivet at lip6.fr>> wrote:
>>> On 28 Jun 2024, at 7:20 PM, Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>>> Hi, Yongzhong,
>>> It is great to see you have made such good progress. Barry is right, you need -vec_maxpy_use_gemv 1. It's my mistake for not mentioning it earlier. But even with that, there are still problems.
>>> petsc tries to optimize VecMDot/MAXPY with BLAS GEMV, with hope that vendors' BLAS library would be highly optimized on that. However, we found though they were good with VecMDot, but not with VecMAXPY. So by default in petsc, we disabled the GEMV optimization for VecMAXPY. One can use -vec_maxpy_use_gemv 1 to turn on it.
>>> I turned it on and tested VecMAXPY with ex2k and MKL, but failed to see any improvement with multiple threads. I could not understand why MKL is so bad on it. You can try it yourself in your environment.
>>> Without the GEMV optimization, VecMAXPY() is implemented by petsc with a batch of PetscKernelAXPY() kernels, which contain simple for loops but not OpenMP parallelized (since petsc does not support OpenMP outright) . I added "omp parallel for" pragma in PetscKernelAXPY() kernels, and tested ex2k again with now parallelized petsc. Here is the result.
>>> $ OMP_PLACES=cores OMP_PROC_BIND=spread OMP_NUM_THREADS=1 ./ex2k -n 15 -m 2 -test_name VecMAXPY -vec_maxpy_use_gemv 0
>>> Vector(N) VecMAXPY-1 VecMAXPY-3 VecMAXPY-8 VecMAXPY-30 (us)
>>> 128 7.0 10.1 21.4 72.7
>>> 256 7.9 12.9 29.5 101.0
>>> 512 9.4 17.2 40.5 136.2
>>> 1024 15.9 27.3 67.5 249.3
>>> 2048 26.5 48.7 139.6 432.7
>>> 4096 47.1 77.3 186.4 710.3
>>> 8192 84.8 152.2 423.9 1580.6
>>> 16384 154.9 298.5 792.1 2889.2
>>> 32768 183.7 338.7 893.9 3436.2
>>> 65536 639.1 1247.8 3219.1 12494.8
>>> 131072 1125.2 1856.2 6843.0 23653.7
>>> 262144 2603.2 4948.4 13259.4 51287.7
>>> 524288 5093.6 10305.0 26451.7 96919.6
>>> 1048576 5898.6 10947.2 45486.4 127352.8
>>> 2097152 11845.4 21912.5 57999.6 331403.4
>>> $ OMP_PLACES=cores OMP_PROC_BIND=spread OMP_NUM_THREADS=16 ./ex2k -n 15 -m 2 -test_name VecMAXPY -vec_maxpy_use_gemv 0
>>> 128 17.0 16.1 31.5 112.9
>>> 256 13.7 16.8 31.2 120.2
>>> 512 14.5 18.1 33.9 129.9
>>> 1024 16.5 21.0 38.5 150.4
>>> 2048 18.5 22.1 41.8 171.4
>>> 4096 21.0 25.4 55.3 212.3
>>> 8192 27.0 30.3 68.6 251.9
>>> 16384 32.2 44.5 93.3 350.5
>>> 32768 45.8 65.0 149.8 558.8
>>> 65536 59.7 102.8 247.1 946.0
>>> 131072 100.7 186.4 485.3 1898.1
>>> 262144 183.4 345.2 922.2 3567.0
>>> 524288 339.6 676.8 1820.7 7530.4
>>> 1048576 662.0 1364.7 3585.3 13969.1
>>> 2097152 1379.7 2788.6 7414.0 28275.3
>>> We can see VecMAXPY() can be easily speeded up with multithreading.
>>> For MatSolve, I checked petsc's aijmkl.c, and found we don't have interface to MKL's sparse solve.
>> We do, it’s in src/mat/impls/aij/seq/mkl_pardiso, and it’s threaded (the distributed version is in src/mat/impls/aij/mpi/mkl_cpardiso).
>> Thanks,
>> Pierre
>>> I checked https://urldefense.us/v3/__https://www.intel.com/content/www/us/en/docs/onemkl/developer-guide-linux/2023-0/openmp-threaded-functions-and-problems.html__;!!G_uCfscf7eWS!bDIUaHqh4wl1qOCJcAguXJHWFoOm4VTVCLhaVCpC9UKNvTShW_jjtq_DiWBWpbj0cSsF0wPyRAJm2hzp5_cFIXQ$ <https://urldefense.us/v3/__https://www.intel.com/content/www/us/en/docs/onemkl/developer-guide-linux/2023-0/openmp-threaded-functions-and-problems.html__;!!G_uCfscf7eWS!bT8Fh0B1GB5nDS3DTpc--fcfGuqOeym0MPwCORXl6F2Sy8A0GFIbVFQUT0J54XZ5Ds7eG_kLdQ-s6tD0GVEQIgTsoHmt$>, but confused with MKL's list of threaded function
>>> Direct sparse solver.
>>> All Level 3 BLAS and all Sparse BLAS routines except Level 2 Sparse Triangular solvers.
>>> I don't know whether MKL has threaded sparse solver.
>>> --Junchao Zhang
>>> On Fri, Jun 28, 2024 at 11:35 AM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>> Are you running with -vec_maxpy_use_gemv ?
>>>>> On Jun 28, 2024, at 1:46 AM, Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> Thanks all for your help!!!
>>>>> I think I find the issues. I am compiling a large CMake project that relies on many external libraries (projects). Previously, I used OpenBLAS as the BLAS for all the dependencies including PETSc. After I switched to Intel MKL for PETSc, I still kept the OpenBLAS and use it as the BLAS for all the other dependencies. I think somehow even when I specify the blas-lapack-dir to the MKLROOT when PETSc is configured, the actual program still use OpenBLAS as the BLAS for some PETSc functions, such as VecMDot() and VecMAXPY(), so that’s why I didn’t see any MKL verbose during the KSPSolve(). Now I remove the OpenBLAS and use Intel MKL as the BLAS for all the dependencies. The issue is resolved, I can clearly see MKL routines are called when KSP GMRES is running.
>>>>> Back to my original questions, my goal is to achieve good parallelization efficiency for KSP GMRES Solve. As I use multithreading-enabled MKL spmv routines, the wall time for MatMult/MatMultAdd() has been greatly reduced. However,the KSPGMRESOrthog and MatSolve in PCApply still take over 50% of solving time and can’t benefit from multithreading. After I fixed the issue I mentioned, I found I got around 15% time reduced because of more efficient VecMDot() calls. I attach a petsc log comparison for your reference (same settings, only difference is whether use MKL BLAS or not), you can see the percentage of VecMDot() is reduced. However, here comes the interesting part, VecMAXPY() didn’t benefit from MKL BLAS, it still takes almost 40% of solution when I use 64 MKL Threads, which is a lot for my program. And if I multiple this percentage with the actual wall time against different # of threads, it stays the same. Then I used ex2k benchmark to verify what I found. Here is the result,
>>>>> $ MKL_NUM_THREADS=1 ./ex2k -n 15 -m 5 -test_name VecMAXPY
>>>>> 128 0.4 0.9 2.4 8.8
>>>>> 256 0.3 1.1 3.5 13.3
>>>>> 512 0.5 4.4 6.7 26.5
>>>>> 1024 0.9 4.8 13.3 51.0
>>>>> 2048 3.5 12.3 37.1 94.7
>>>>> 4096 4.3 24.5 73.6 179.6
>>>>> 8192 6.3 48.7 98.9 380.8
>>>>> 16384 9.3 99.2 200.2 774.0
>>>>> 32768 30.6 155.4 421.2 1662.9
>>>>> 65536 101.2 269.4 827.4 3565.0
>>>>> 131072 206.9 551.0 1829.0 7580.5
>>>>> 262144 450.2 1251.9 3986.2 15525.6
>>>>> 524288 1322.1 2901.7 8567.1 31840.0
>>>>> 1048576 2788.6 6190.6 16394.7 63514.9
>>>>> 2097152 5534.8 12619.9 35427.4 130064.5
>>>>> $ MKL_NUM_THREADS=8 ./ex2k -n 15 -m 5 -test_name VecMAXPY
>>>>> 128 0.3 0.7 2.4 8.8
>>>>> 256 0.3 1.1 3.6 13.5
>>>>> 512 0.5 4.4 6.8 26.4
>>>>> 1024 0.9 4.8 13.6 50.5
>>>>> 2048 7.6 12.2 36.5 95.0
>>>>> 4096 8.5 25.7 72.4 182.6
>>>>> 8192 11.9 48.5 103.7 383.7
>>>>> 16384 12.8 97.7 203.7 785.0
>>>>> 32768 11.2 148.5 421.9 1681.5
>>>>> 65536 15.5 271.2 843.8 3613.7
>>>>> 131072 34.3 564.7 1905.2 7558.8
>>>>> 262144 106.4 1334.5 4002.8 15458.3
>>>>> 524288 217.2 2858.4 8407.9 31303.7
>>>>> 1048576 701.5 6060.6 16947.3 64118.5
>>>>> 2097152 1769.7 13218.3 36347.3 131062.9
>>>>> It stays the same, no benefit from multithreading BLAS!! Unlike what I found for VecMdot(), where I did see speed up for more #of threads. Then, I dig deeper. I learned that for VecMDot(), it calls ZGEMV while for VecMAXPY(), it calls ZAXPY. This observation seems to indicate that ZAXPY is not benefiting from MKL threads.
>>>>> My question is do you know why ZAXPY is not multithreaded? From my perspective, VecMDot() and VecMAXPY() are very similar operations, the only difference is whether we need to scale the vectors to be multiplied or not. I think you have mentioned that recently you did some optimization to these two routines, from my above results and observations, are these aligned with your expectations? Could we further optimize the codes to get more parallelization efficiency in my case?
>>>>> And another question, can MatSolve() in KSPSolve be multithreaded? Would MUMPS help?
>>>>> Thank you and regards,
>>>>> Yongzhong
>>>>> From: Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>>
>>>>> Sent: Thursday, June 27, 2024 11:10 AM
>>>>> To: Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>>
>>>>> Cc: Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>; petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
>>>>> Subject: Re: [petsc-users] [petsc-maint] Assistance Needed with PETSc KSPSolve Performance Issue
>>>>> How big is the n when you call PetscCallBLAS("BLASgemv", BLASgemv_(trans, &n, &m, &one, yarray, &lda2, xarray, &ione, &zero, z + i, &ione))? n is the vector length in VecMDot.
>>>>> it is strange with MKL_VERBOSE=1 you did not see MKL_VERBOSE ZGEMV..., since the code did call gemv. Perhaps you need to double check your spelling etc.
>>>>> If you also use ex2k, and potentially modify Ms[] and Ns[] to match the sizes in your code, to see if there is a speedup with more threads.
>>>>> --Junchao Zhang
>>>>> On Thu, Jun 27, 2024 at 9:39 AM Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> Mostly 3, maximum 7, but definitely hit the point when m > 1, I can see the PetscCallBLAS("BLASgemv", BLASgemv_(trans, &n, &m, &one, yarray, &lda2, xarray, &ione, &zero, z + i, &ione)); is called multiple
>>>>> ZjQcmQRYFpfptBannerStart
>>>>> ZjQcmQRYFpfptBannerEnd
>>>>> I can see the PetscCallBLAS("BLASgemv", BLASgemv_(trans, &n, &m, &one, yarray, &lda2, xarray, &ione, &zero, z + i, &ione)); is called multiple times
>>>>> From: Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>
>>>>> Date: Thursday, June 27, 2024 at 1:12 AM
>>>>> Cc: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
>>>>> How big are the m's getting in your code?
>>>>> On Jun 27, 2024, at 12:40 AM, Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> Hi Barry, I used gdb to debug my program, set a breakpoint to VecMultiDot_Seq_GEMV function. I did see when I debug this function, it will call BLAS (but not always, only if m > 1), as shown below. However, I still didn’t see any MKL outputs even if I set MKLK_VERBOSE=1.
>>>>> (gdb)
>>>>> 550 PetscCall(VecRestoreArrayRead(yin[i], &yfirst));
>>>>> (gdb)
>>>>> 553 m = j - i;
>>>>> (gdb)
>>>>> 554 if (m > 1) {
>>>>> (gdb)
>>>>> 555 PetscBLASInt ione = 1, lda2 = (PetscBLASInt)lda; // the cast is safe since we've screened out those lda > PETSC_BLAS_INT_MAX above
>>>>> (gdb)
>>>>> 556 PetscScalar one = 1, zero = 0;
>>>>> (gdb)
>>>>> 558 PetscCallBLAS("BLASgemv", BLASgemv_(trans, &n, &m, &one, yarray, &lda2, xarray, &ione, &zero, z + i, &ione));
>>>>> (gdb) s
>>>>> PetscMallocValidate (line=558, function=0x7ffff68a11a0 <__func__.18210> "VecMultiDot_Seq_GEMV",
>>>>> file=0x7ffff68a1078 "/gpfs/s4h/scratch/t/triverio/modelics/workplace/rebel/build_debug/external/petsc-3.21.0/src/vec/vec/impls/seq/dvec2.c")
>>>>> at /gpfs/s4h/scratch/t/triverio/modelics/workplace/rebel/build_debug/external/petsc-3.21.0/src/sys/memory/mtr.c:106
>>>>> 106 if (!TRdebug) return PETSC_SUCCESS;
>>>>> (gdb)
>>>>> 154 }
>>>>> Am I not using MKL BLAS, is that why I didn’t see multithreading speed up for KSPGMRESOrthog? What do you think could be the potential reasons? Is there any silent mode that will possibly affect the MKL Verbose.
>>>>> Thank you and best regards,
>>>>> Yongzhong
>>>>> Date: Wednesday, June 26, 2024 at 8:15 PM
>>>>> if (m > 1) {
>>>>> PetscCall(PetscLogFlops(PetscMax(m * (2.0 * n - 1), 0.0)));
>>>>> The call to BLAS above is where it uses MKL.
>>>>> On Jun 26, 2024, at 6:59 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> Hi Barry, I am looking into the source codes of VecMultiDot_Seq_GEMV https://urldefense.us/v3/__https://petsc.org/release/src/vec/vec/impls/seq/dvec2.c.html*VecMDot_Seq__;Iw!!G_uCfscf7eWS!bDIUaHqh4wl1qOCJcAguXJHWFoOm4VTVCLhaVCpC9UKNvTShW_jjtq_DiWBWpbj0cSsF0wPyRAJm2hzpCCxkPcI$ <https://urldefense.us/v3/__https://petsc.org/release/src/vec/vec/impls/seq/dvec2.c.html*VecMDot_Seq__;Iw!!G_uCfscf7eWS!ZshPGnAUymZ7rmZ8Cq0JR23FBhEioHOuAq-lFnn4iQn1bK8ioexLwIQVLSQNCfmBaWWExCcshZ6KphgTYR6kv18wg0MHEITtuVo$>
>>>>> Can I ask which lines of codes suggest the use of intel mkl?
>>>>> Thanks,
>>>>> Yongzhong
>>>>> Date: Wednesday, June 26, 2024 at 10:30 AM
>>>>> In a debug version of PETSc run your application in a debugger and put a break point in VecMultiDot_Seq_GEMV. Then next through the code from that point to see what decision it makes about using dgemv() to see why it is not getting into the Intel code.
>>>>> On Jun 25, 2024, at 11:19 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> Hi Junchao, thank you for your help for these benchmarking test!
>>>>> I check out to petsc/main and did a few things to verify from my side,
>>>>> 1. I ran the microbenchmark (vec/vec/tests/ex2k.c) test on my compute node. The results are as follow,
>>>>> $ MKL_NUM_THREADS=64 ./ex2k -n 15 -m 4
>>>>> Vector(N) VecMDot-1 VecMDot-3 VecMDot-8 VecMDot-30 (us)
>>>>> 128 14.5 1.2 1.8 5.2
>>>>> 256 1.5 0.9 1.6 4.7
>>>>> 512 2.7 2.8 6.1 13.2
>>>>> 1024 4.0 4.0 9.3 16.4
>>>>> 2048 7.4 7.3 11.3 39.3
>>>>> 4096 14.2 13.9 19.1 93.4
>>>>> 8192 28.8 26.3 25.4 31.3
>>>>> 16384 54.1 25.8 26.7 33.8
>>>>> 32768 109.8 25.7 24.2 56.0
>>>>> 65536 220.2 24.4 26.5 89.0
>>>>> 131072 424.1 31.5 36.1 149.6
>>>>> 262144 898.1 37.1 53.9 286.1
>>>>> 524288 1754.6 48.7 100.3 1122.2
>>>>> 1048576 3645.8 86.5 347.9 2950.4
>>>>> 2097152 7371.4 308.7 1440.6 6874.9
>>>>> $ MKL_NUM_THREADS=1 ./ex2k -n 15 -m 4
>>>>> 128 14.9 1.2 1.9 5.2
>>>>> 256 1.5 1.0 1.7 4.7
>>>>> 512 2.7 2.8 6.1 12.0
>>>>> 1024 3.9 4.0 9.3 16.8
>>>>> 2048 7.4 7.3 10.4 41.3
>>>>> 4096 14.0 13.8 18.6 84.2
>>>>> 8192 27.0 21.3 43.8 177.5
>>>>> 16384 54.1 34.1 89.1 330.4
>>>>> 32768 110.4 82.1 203.5 781.1
>>>>> 65536 213.0 191.8 423.9 1696.4
>>>>> 131072 428.7 360.2 934.0 4080.0
>>>>> 262144 883.4 723.2 1745.6 10120.7
>>>>> 524288 1817.5 1466.1 4751.4 23217.2
>>>>> 1048576 3611.0 3796.5 11814.9 48687.7
>>>>> 2097152 7401.9 10592.0 27543.2 106565.4
>>>>> I can see the speed up brought by more MKL threads, and if I set NKL_VERBOSE to 1, I can see something like
>>>>> MKL_VERBOSE ZGEMV(C,262144,8,0x7ffd375d6470,0x2ac76e7fb010,262144,0x16d0f40,1,0x7ffd375d6480,0x16435d0,1) 32.70us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:6 ca
>>>>> From my understanding, the VecMDot()/VecMAXPY() can benefit from more MKL threads in my compute node and is using ZGEMV MKL BLAS.
>>>>> However, when I ran my own program and set MKL_VERBOSE to 1, it is very strange that I still can’t find any MKL outputs, though I can see from the PETSc log that VecMDot and VecMAXPY() are called.
>>>>> I am wondering are VecMDot and VecMAXPY in KSPGMRESOrthog optimized in a way that is similar to ex2k test? Should I expect to see MKL outputs for whatever linear system I solve with KSPGMRES? Does it relate to if it is dense matrix or sparse matrix, although I am not really understand why VecMDot/MAXPY() have something to do with dense matrix-vector multiplication.
>>>>> Thank you,
>>>>> Yongzhong
>>>>> Date: Tuesday, June 25, 2024 at 6:34 PM
>>>>> To: Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>
>>>>> Cc: Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>>, Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>>, petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
>>>>> Hi, Yongzhong,
>>>>> Since the two kernels of KSPGMRESOrthog are VecMDot and VecMAXPY, if we can speed up the two with OpenMP threads, then we can speed up KSPGMRESOrthog. We recently added an optimization to do VecMDot/MAXPY() in dense matrix-vector multiplication (i.e., BLAS2 GEMV, with tall-and-skinny matrices ). So with MKL_VERBOSE=1, you should see something like "MKL_VERBOSE ZGEMV ..." in output. If not, could you try again with petsc/main?
>>>>> petsc has a microbenchmark (vec/vec/tests/ex2k.c) to test them. I ran VecMDot with multithreaded oneMKL (via setting MKL_NUM_THREADS), it was strange to see no speedup. I then configured petsc with openblas, I did see better performance with more threads
>>>>> $ OMP_PROC_BIND=spread OMP_NUM_THREADS=1 ./ex2k -n 15 -m 4
>>>>> Vector(N) VecMDot-3 VecMDot-8 VecMDot-30 (us)
>>>>> 128 2.0 2.5 6.1
>>>>> 256 1.8 2.7 7.0
>>>>> 512 2.1 3.1 8.6
>>>>> 1024 2.7 4.0 12.3
>>>>> 2048 3.8 6.3 28.0
>>>>> 4096 6.1 10.6 42.4
>>>>> 8192 10.9 21.8 79.5
>>>>> 16384 21.2 39.4 149.6
>>>>> 32768 45.9 75.7 224.6
>>>>> 65536 142.2 215.8 732.1
>>>>> 131072 169.1 233.2 1729.4
>>>>> 262144 367.5 830.0 4159.2
>>>>> 524288 999.2 1718.1 8538.5
>>>>> 1048576 2113.5 4082.1 18274.8
>>>>> 2097152 5392.6 10273.4 43273.4
>>>>> $ OMP_PROC_BIND=spread OMP_NUM_THREADS=8 ./ex2k -n 15 -m 4
>>>>> 128 2.0 2.5 6.0
>>>>> 256 1.8 2.7 15.0
>>>>> 512 2.1 9.0 16.6
>>>>> 1024 2.6 8.7 16.1
>>>>> 2048 7.7 10.3 20.5
>>>>> 4096 9.9 11.4 25.9
>>>>> 8192 14.5 22.1 39.6
>>>>> 16384 25.1 27.8 67.8
>>>>> 32768 44.7 95.7 91.5
>>>>> 65536 82.1 156.8 165.1
>>>>> 131072 194.0 335.1 341.5
>>>>> 262144 388.5 380.8 612.9
>>>>> 524288 1046.7 967.1 1653.3
>>>>> 1048576 1997.4 2169.0 4034.4
>>>>> 2097152 5502.9 5787.3 12608.1
>>>>> The tall-and-skinny matrices in KSPGMRESOrthog vary in width. The average speedup depends on components. So I suggest you run ex2k to see in your environment whether oneMKL can speedup the kernels.
>>>>> --Junchao Zhang
>>>>> On Mon, Jun 24, 2024 at 11:35 AM Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>>>>> Let me run some examples on our end to see whether the code calls expected functions.
>>>>> --Junchao Zhang
>>>>> On Mon, Jun 24, 2024 at 10:46 AM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>>> On Mon, Jun 24, 2024 at 11: 21 AM Yongzhong Li <yongzhong. li@ mail. utoronto. ca> wrote: Thank you Pierre for your information. Do we have a conclusion for my original question about the parallelization efficiency for different stages of
>>>>> On Mon, Jun 24, 2024 at 11:21 AM Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> Thank you Pierre for your information. Do we have a conclusion for my original question about the parallelization efficiency for different stages of KSP Solve? Do we need to do more testing to figure out the issues? Thank you, Yongzhong From:
>>>>> We have an extended discussion of this here: https://urldefense.us/v3/__https://petsc.org/release/faq/*what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup__;Iw!!G_uCfscf7eWS!bDIUaHqh4wl1qOCJcAguXJHWFoOm4VTVCLhaVCpC9UKNvTShW_jjtq_DiWBWpbj0cSsF0wPyRAJm2hzpA6bJvC4$ <https://urldefense.us/v3/__https://petsc.org/release/faq/*what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup__;Iw!!G_uCfscf7eWS!aQJpmm5W6l6FUiumnIPmkouzwzNUfx-Dyq04i1O2KS_InQGk6qjI7wUir0Hx6QEUQE2AMiJDsez3x4zRO7V_$>
>>>>> The kinds of operations you are talking about (SpMV, VecDot, VecAXPY, etc) are memory bandwidth limited. If there is no more bandwidth to be marshalled on your board, then adding more processes does nothing at all. This is why people were asking about how many "nodes" you are running on, because that is the unit of memory bandwidth, not "cores" which make little difference.
>>>>> Thanks,
>>>>> Matt
>>>>> Thank you,
>>>>> Yongzhong
>>>>> From: Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>>
>>>>> Date: Sunday, June 23, 2024 at 12:41 AM
>>>>> On 23 Jun 2024, at 4:07 AM, Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> Yeah, I ran my program again using -mat_view::ascii_info and set MKL_VERBOSE to be 1, then I noticed the outputs suggested that the matrix to be seqaijmkl type (I’ve attached a few as below)
>>>>> --> Setting up matrix-vector products...
>>>>> Mat Object: 1 MPI process
>>>>> type: seqaijmkl
>>>>> rows=16490, cols=35937
>>>>> total: nonzeros=128496, allocated nonzeros=128496
>>>>> total number of mallocs used during MatSetValues calls=0
>>>>> not using I-node routines
>>>>> type: seqaijmkl
>>>>> --> Solving the system...
>>>>> Excitation 1 of 1...
>>>>> Iterative solve completed in 7435 ms.
>>>>> CONVERGED: rtol.
>>>>> Iterations: 72
>>>>> Final relative residual norm: 9.22287e-07
>>>>> [CPU TIME] System solution: 2.27160000e+02 s.
>>>>> [WALL TIME] System solution: 7.44387218e+00 s.
>>>>> However, it seems to me that there were still no MKL outputs even I set MKL_VERBOSE to be 1. Although, I think it should be many spmv operations when doing KSPSolve(). Do you see the possible reasons?
>>>>> SPMV are not reported with MKL_VERBOSE (last I checked), only dense BLAS is.
>>>>> Thanks,
>>>>> Pierre
>>>>> Thanks,
>>>>> Yongzhong
>>>>> From: Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>
>>>>> Date: Saturday, June 22, 2024 at 5:56 PM
>>>>> Cc: Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>>, Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>>, petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
>>>>> 你通常不会收到来自 knepley at gmail.com <mailto:knepley at gmail.com> 的电子邮件。了解这一点为什么很重要 <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!fVvbGldqcUV5ju4jpu5oGmt-VjITi5JpCJzhHxpbgsERLVYZzglpxKOOyrBRGxjRxp7vWHwt3SnINFOQErR1Z8kcDcf3qwbYRxM$>
>>>>> On Sat, Jun 22, 2024 at 5:03 PM Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> MKL_VERBOSE=1 ./ex1 matrix nonzeros = 100, allocated nonzeros = 100 MKL_VERBOSE Intel(R) MKL 2019. 0 Update 4 Product build 20190411 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) with support of Vector
>>>>> MKL_VERBOSE=1 ./ex1
>>>>> MKL_VERBOSE Intel(R) MKL 2019.0 Update 4 Product build 20190411 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) with support of Vector Neural Network Instructions enabled processors, Lnx 2.50GHz lp64 gnu_thread
>>>>> MKL_VERBOSE ZGEMV(N,10,10,0x7ffd9d7078f0,0x187eb20,10,0x187f7c0,1,0x7ffd9d707900,0x187ff70,1) 167.34ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x7ffd9d7078c0,-1,0) 77.19ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x1894490,10,0) 83.97ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZSYTRS(L,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 44.94ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 20.72us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZSYTRS(L,10,2,0x1894b50,10,0x1893df0,0x187d2a0,10,0) 4.22us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGEMM(N,N,10,2,10,0x7ffd9d707790,0x187eb20,10,0x187d2a0,10,0x7ffd9d7077a0,0x1896a70,10) 1.41ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZAXPY(20,0x7ffd9d7078a0,0x1896a70,1,0x187b650,1) 381ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x7ffd9d707840,-1,0) 742ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x18951a0,10,0) 4.20us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZSYTRS(L,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 2.94us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 292ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGEMV(N,10,10,0x7ffd9d7078f0,0x187eb20,10,0x187f7c0,1,0x7ffd9d707900,0x187ff70,1) 1.17us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGETRF(10,10,0x1894b50,10,0x1893df0,0) 202.48ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGETRS(N,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 20.78ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 954ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGETRS(N,10,2,0x1894b50,10,0x1893df0,0x187d2a0,10,0) 30.74ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGEMM(N,N,10,2,10,0x7ffd9d707790,0x187eb20,10,0x187d2a0,10,0x7ffd9d7077a0,0x18969c0,10) 3.95us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZAXPY(20,0x7ffd9d7078a0,0x18969c0,1,0x187b650,1) 995ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGETRF(10,10,0x1894b50,10,0x1893df0,0) 4.09us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGETRS(N,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 3.92us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 274ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGEMV(N,15,10,0x7ffd9d7078f0,0x187ec70,15,0x187fc30,1,0x7ffd9d707900,0x1880400,1) 1.59us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x1894550,0x7ffd9d707900,-1,0) 47.07us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x1894550,0x1895cb0,10,0) 26.62us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZUNMQR(L,C,15,1,10,0x1894b40,15,0x1894550,0x1895b00,15,0x7ffd9d7078b0,-1,0) 35.32us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZUNMQR(L,C,15,1,10,0x1894b40,15,0x1894550,0x1895b00,15,0x1895cb0,10,0) 42.33ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZTRTRS(U,N,N,10,1,0x1894b40,15,0x1895b00,15,0) 16.11us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187fc30,1,0x1880c70,1) 395ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGEMM(N,N,15,2,10,0x7ffd9d707790,0x187ec70,15,0x187d310,10,0x7ffd9d7077a0,0x187b5b0,15) 3.22us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZUNMQR(L,C,15,2,10,0x1894b40,15,0x1894550,0x1897760,15,0x7ffd9d7078c0,-1,0) 730ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZUNMQR(L,C,15,2,10,0x1894b40,15,0x1894550,0x1897760,15,0x1895cb0,10,0) 4.42us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZTRTRS(U,N,N,10,2,0x1894b40,15,0x1897760,15,0) 5.96us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZAXPY(20,0x7ffd9d7078a0,0x187d310,1,0x1897610,1) 222ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x18954b0,0x7ffd9d707820,-1,0) 685ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x18954b0,0x1895d60,10,0) 6.11us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZUNMQR(L,C,15,1,10,0x1894b40,15,0x18954b0,0x1895bb0,15,0x7ffd9d7078b0,-1,0) 390ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZUNMQR(L,C,15,1,10,0x1894b40,15,0x18954b0,0x1895bb0,15,0x1895d60,10,0) 3.09us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZTRTRS(U,N,N,10,1,0x1894b40,15,0x1895bb0,15,0) 1.05us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187fc30,1,0x1880c70,1) 257ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> Yes, for petsc example, there are MKL outputs, but for my own program. All I did is to change the matrix type from MATAIJ to MATAIJMKL to get optimized performance for spmv from MKL. Should I expect to see any MKL outputs in this case?
>>>>> Are you sure that the type changed? You can MatView() the matrix with format ascii_info to see.
>>>>> Thanks,
>>>>> Matt
>>>>> Thanks,
>>>>> Yongzhong
>>>>> Date: Saturday, June 22, 2024 at 9:40 AM
>>>>> Cc: Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>>, petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
>>>>> No, you don't. It is strange. Perhaps you can you run a petsc example first and see if MKL is really used
>>>>> $ cd src/mat/tests
>>>>> $ make ex1
>>>>> $ MKL_VERBOSE=1 ./ex1
>>>>> --Junchao Zhang
>>>>> On Fri, Jun 21, 2024 at 4:03 PM Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> I am using
>>>>> export MKL_VERBOSE=1
>>>>> ./xx
>>>>> in the bash file, do I have to use - ksp_converged_reason?
>>>>> Thanks,
>>>>> Yongzhong
>>>>> Date: Friday, June 21, 2024 at 1:47 PM
>>>>> Cc: Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>>, petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
>>>>> 你通常不会收到来自 pierre at joliv.et <mailto:pierre at joliv.et> 的电子邮件。了解这一点为什么很重要 <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!flsZMI97ne0yyxHhLda3hROB9qsgstuZS-jPinxGIzFCCSdn1ujdoMR8dyz-5_kVqqMM-12Lt0dTdjKrx3wXhHZmBhNydvFQeSY$>
>>>>> How do you set the variable?
>>>>> $ MKL_VERBOSE=1 ./ex1 -ksp_converged_reason
>>>>> MKL_VERBOSE oneMKL 2024.0 Update 1 Product build 20240215 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2) enabled processors, Lnx 2.80GHz lp64 intel_thread
>>>>> MKL_VERBOSE DDOT(10,0x22127c0,1,0x22127c0,1) 2.02ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE DSCAL(10,0x7ffc9fb4ff08,0x22127c0,1) 12.67us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE DDOT(10,0x22127c0,1,0x2212840,1) 1.52us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> MKL_VERBOSE DDOT(10,0x2212840,1,0x2212840,1) 167ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>>>>> On 21 Jun 2024, at 7:37 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> Hello all,
>>>>> I set MKL_VERBOSE = 1, but observed no print output specific to the use of MKL. Does PETSc enable this verbose output?
>>>>> Best,
>>>>> Yongzhong
>>>>> Date: Friday, June 21, 2024 at 1:36 AM
>>>>> To: Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>>
>>>>> Cc: Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>>, petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
>>>>> 你通常不会收到来自 pierre at joliv.et <mailto:pierre at joliv.et> 的电子邮件。了解这一点为什么很重要 <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!eXBeeIXo9Yqgp2nypqwKYimLnGBZXnF4dXxgLM1UoOIO6n8nt3XlfgjVWLPWJh4UOa5NNpx-nrJb_H828XRQKUREfR2m69oCbxI$>
>>>>> On 21 Jun 2024, at 6:42 AM, Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>>>>> I remember there are some MKL env vars to print MKL routines called.
>>>>> The environment variable is MKL_VERBOSE
>>>>> Thanks,
>>>>> Pierre
>>>>> Maybe we can try it to see what MKL routines are really used and then we can understand why some petsc functions did not speed up
>>>>> --Junchao Zhang
>>>>> On Thu, Jun 20, 2024 at 10:39 PM Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> Hi Barry, sorry for my last results. I didn’t fully understand the stage profiling and logging in PETSc, now I only record KSPSolve() stage of my program. Some sample codes are as follow,
>>>>> // Static variable to keep track of the stage counter
>>>>> static int stageCounter = 1;
>>>>> // Generate a unique stage name
>>>>> std::ostringstream oss;
>>>>> oss << "Stage " << stageCounter << " of Code";
>>>>> std::string stageName = oss.str();
>>>>> // Register the stage
>>>>> PetscLogStage stagenum;
>>>>> PetscLogStageRegister(stageName.c_str(), &stagenum);
>>>>> PetscLogStagePush(stagenum);
>>>>> KSPSolve(*ksp_ptr, b, x);
>>>>> PetscLogStagePop();
>>>>> stageCounter++;
>>>>> I have attached my new logging results, there are 1 main stage and 4 other stages where each one is KSPSolve() call.
>>>>> To provide some additional backgrounds, if you recall, I have been trying to get efficient iterative solution using multithreading. I found out by compiling PETSc with Intel MKL library instead of OpenBLAS, I am able to perform sparse matrix-vector multiplication faster, I am using MATSEQAIJMKL. This makes the shell matrix vector product in each iteration scale well with the #of threads. However, I found out the total GMERS solve time (~KSPSolve() time) is not scaling well the #of threads.
>>>>> From the logging results I learned that when performing KSPSolve(), there are some CPU overheads in PCApply() and KSPGMERSOrthog(). I ran my programs using different number of threads and plotted the time consumption for PCApply() and KSPGMERSOrthog() against #of thread. I found out these two operations are not scaling with the threads at all! My results are attached as the pdf to give you a clear view.
>>>>> My questions is,
>>>>> From my understanding, in PCApply, MatSolve() is involved, KSPGMERSOrthog() will have many vector operations, so why these two parts can’t scale well with the # of threads when the intel MKL library is linked?
>>>>> Thank you,
>>>>> Yongzhong
>>>>> Date: Friday, June 14, 2024 at 11:36 AM
>>>>> Cc: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>, petsc-maint at mcs.anl.gov <mailto:petsc-maint at mcs.anl.gov> <petsc-maint at mcs.anl.gov <mailto:petsc-maint at mcs.anl.gov>>, Piero Triverio <piero.triverio at utoronto.ca <mailto:piero.triverio at utoronto.ca>>
>>>>> Subject: Re: [petsc-maint] Assistance Needed with PETSc KSPSolve Performance Issue
>>>>> I am a bit confused. Without the initial guess computation, there are still a bunch of events I don't understand
>>>>> MatTranspose 79 1.0 4.0598e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>>>> MatMatMultSym 110 1.0 1.7419e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
>>>>> MatMatMultNum 90 1.0 1.2640e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
>>>>> MatMatMatMultSym 20 1.0 1.3049e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
>>>>> MatRARtSym 25 1.0 1.2492e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
>>>>> MatMatTrnMultSym 25 1.0 8.8265e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>>>> MatMatTrnMultNum 25 1.0 2.4820e+02 1.0 6.83e+10 1.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 275
>>>>> MatTrnMatMultSym 10 1.0 7.2984e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>>>> MatTrnMatMultNum 10 1.0 9.3128e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>>>> in addition there are many more VecMAXPY then VecMDot (in GMRES they are each done the same number of times)
>>>>> VecMDot 5588 1.0 1.7183e+03 1.0 2.06e+13 1.0 0.0e+00 0.0e+00 0.0e+00 8 10 0 0 0 8 10 0 0 0 12016
>>>>> VecMAXPY 22412 1.0 8.4898e+03 1.0 4.17e+13 1.0 0.0e+00 0.0e+00 0.0e+00 39 20 0 0 0 39 20 0 0 0 4913
>>>>> Finally there are a huge number of
>>>>> MatMultAdd 258048 1.0 1.4178e+03 1.0 6.10e+13 1.0 0.0e+00 0.0e+00 0.0e+00 7 29 0 0 0 7 29 0 0 0 43025
>>>>> Are you making calls to all these routines? Are you doing this inside your MatMult() or before you call KSPSolve?
>>>>> The reason I wanted you to make a simpler run without the initial guess code is that your events are far more complicated than would be produced by GMRES alone so it is not possible to understand the behavior you are seeing without fully understanding all the events happening in the code.
>>>>> Barry
>>>>> On Jun 14, 2024, at 1:19 AM, Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> Thanks, I have attached the results without using any KSPGuess. At low frequency, the iteration steps are quite close to the one with KSPGuess, specifically
>>>>> KSPGuess Object: 1 MPI process
>>>>> type: fischer
>>>>> Model 1, size 200
>>>>> However, I found at higher frequency, the # of iteration steps are significant higher than the one with KSPGuess, I have attahced both of the results for your reference.
>>>>> Moreover, could I ask why the one without the KSPGuess options can be used for a baseline comparsion? What are we comparing here? How does it relate to the performance issue/bottleneck I found? “I have noticed that the time taken by KSPSolve is almost two times greater than the CPU time for matrix-vector product multiplied by the number of iteration”
>>>>> Thank you!
>>>>> Yongzhong
>>>>> Date: Thursday, June 13, 2024 at 2:14 PM
>>>>> Can you please run the same thing without the KSPGuess option(s) for a baseline comparison?
>>>>> Thanks
>>>>> Barry
>>>>> On Jun 13, 2024, at 1:27 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> Hi Matt,
>>>>> I have rerun the program with the keys you provided. The system output when performing ksp solve and the final petsc log output were stored in a .txt file attached for your reference.
>>>>> Thanks!
>>>>> Yongzhong
>>>>> Date: Wednesday, June 12, 2024 at 6:46 PM
>>>>> 你通常不会收到来自 knepley at gmail.com <mailto:knepley at gmail.com> 的电子邮件。了解这一点为什么很重要 <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!djGfJnEhNJROfsMsBJy5u_KoRKbug55xZ64oHKUFnH2cWku_Th1hwt4TDdoMd8pWYVDzJeqJslMNZwpO3y0Et94d31qk-oCEwo4$>
>>>>> On Wed, Jun 12, 2024 at 6:36 PM Yongzhong Li <yongzhong.li at mail.utoronto.ca <mailto:yongzhong.li at mail.utoronto.ca>> wrote:
>>>>> Dear PETSc’s developers, I hope this email finds you well. I am currently working on a project using PETSc and have encountered a performance issue with the KSPSolve function. Specifically, I have noticed that the time taken by KSPSolve is
>>>>> I am currently working on a project using PETSc and have encountered a performance issue with the KSPSolve function. Specifically, I have noticed that the time taken by KSPSolve is almost two times greater than the CPU time for matrix-vector product multiplied by the number of iteration steps. I use C++ chrono to record CPU time.
>>>>> For context, I am using a shell system matrix A. Despite my efforts to parallelize the matrix-vector product (Ax), the overall solve time remains higher than the matrix vector product per iteration indicates when multiple threads were used. Here are a few details of my setup:
>>>>> Matrix Type: Shell system matrix
>>>>> Preconditioner: Shell PC
>>>>> Parallel Environment: Using Intel MKL as PETSc’s BLAS/LAPACK library, multithreading is enabled
>>>>> I have considered several potential reasons, such as preconditioner setup, additional solver operations, and the inherent overhead of using a shell system matrix. However, since KSPSolve is a high-level API, I have been unable to pinpoint the exact cause of the increased solve time.
>>>>> Have you observed the same issue? Could you please provide some experience on how to diagnose and address this performance discrepancy? Any insights or recommendations you could offer would be greatly appreciated.
>>>>> For any performance question like this, we need to see the output of your code run with
>>>>> -ksp_view -ksp_monitor_true_residual -ksp_converged_reason -log_view
>>>>> Thanks,
>>>>> Matt
>>>>> Thank you for your time and assistance.
>>>>> Best regards,
>>>>> Yongzhong
>>>>> Yongzhong Li
>>>>> PhD student | Electromagnetics Group
>>>>> Department of Electrical & Computer Engineering
>>>>> University of Toronto
>>>>> https://urldefense.us/v3/__http://www.modelics.org__;!!G_uCfscf7eWS!bDIUaHqh4wl1qOCJcAguXJHWFoOm4VTVCLhaVCpC9UKNvTShW_jjtq_DiWBWpbj0cSsF0wPyRAJm2hzp6WbSEQM$ <https://urldefense.us/v3/__http://www.modelics.org__;!!G_uCfscf7eWS!cuLttMJEcegaqu461Bt4QLsO4fASfLM5vjRbtyNhWJQiInbjgNwkGNdkFE1ebSbFjOUatYB0-jd2yQWMWzqkDFFjwMvNl3ZKAr8$>
>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bDIUaHqh4wl1qOCJcAguXJHWFoOm4VTVCLhaVCpC9UKNvTShW_jjtq_DiWBWpbj0cSsF0wPyRAJm2hzpUQSz1ow$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!djGfJnEhNJROfsMsBJy5u_KoRKbug55xZ64oHKUFnH2cWku_Th1hwt4TDdoMd8pWYVDzJeqJslMNZwpO3y0Et94d31qkNOuenGA$>
>>>>> <ksp_petsc_log.txt>
>>>>> <ksp_petsc_log.txt><ksp_petsc_log_noguess.txt>
>>>>> -- Norbert Wiener
>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bDIUaHqh4wl1qOCJcAguXJHWFoOm4VTVCLhaVCpC9UKNvTShW_jjtq_DiWBWpbj0cSsF0wPyRAJm2hzpUQSz1ow$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fVvbGldqcUV5ju4jpu5oGmt-VjITi5JpCJzhHxpbgsERLVYZzglpxKOOyrBRGxjRxp7vWHwt3SnINFOQErR1Z8kcDcf3cNeD9Gw$>
>>>>> -- Norbert Wiener
>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bDIUaHqh4wl1qOCJcAguXJHWFoOm4VTVCLhaVCpC9UKNvTShW_jjtq_DiWBWpbj0cSsF0wPyRAJm2hzpUQSz1ow$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!aQJpmm5W6l6FUiumnIPmkouzwzNUfx-Dyq04i1O2KS_InQGk6qjI7wUir0Hx6QEUQE2AMiJDsez3x2Os2C2d$>
>>>>> <petsc_log_comparison.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240628/2b07f268/attachment-0001.html>
