[petsc-users] [petsc-maint] Assistance Needed with PETSc KSPSolve Performance Issue
Junchao Zhang
junchao.zhang at gmail.com
Thu Jun 27 09:18:31 CDT 2024
Yongzhong,
VecMDot(x, m, y[], ...) will be called multiple times in GMRES, with an
increasing m up to 30. If you continue running, you should hit the
breakpoint with m > 1.
--Junchao Zhang
On Wed, Jun 26, 2024 at 11:40 PM Yongzhong Li <yongzhong.li at mail.utoronto.ca>
wrote:
> Hi Barry, I used gdb to debug my program, set a breakpoint to
> VecMultiDot_Seq_GEMV function. I did see when I debug this function, it
> will call BLAS (but not always, only if m > 1), as shown below. However, I
> still didn’t see any MKL outputs
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> still didn’t see any MKL outputs even if I set MKLK_VERBOSE=1.
> *(gdb) *
> *550 PetscCall(VecRestoreArrayRead(yin[i], &yfirst));*
> *(gdb) *
> *553 m = j - i;*
> *(gdb) *
> *554 if (m > 1) {*
> *(gdb) *
> *555 PetscBLASInt ione = 1, lda2 = (PetscBLASInt)lda; // the
> cast is safe since we've screened out those lda > PETSC_BLAS_INT_MAX above*
> *(gdb) *
> *556 PetscScalar one = 1, zero = 0;*
> *(gdb) *
> *558 PetscCallBLAS("BLASgemv", BLASgemv_(trans, &n, &m, &one,
> yarray, &lda2, xarray, &ione, &zero, z + i, &ione));*
> *(gdb) s*
> *PetscMallocValidate (line=558, function=0x7ffff68a11a0 <__func__.18210>
> "VecMultiDot_Seq_GEMV", *
> * file=0x7ffff68a1078
> "/gpfs/s4h/scratch/t/triverio/modelics/workplace/rebel/build_debug/external/petsc-3.21.0/src/vec/vec/impls/seq/dvec2.c")*
> * at
> /gpfs/s4h/scratch/t/triverio/modelics/workplace/rebel/build_debug/external/petsc-3.21.0/src/sys/memory/mtr.c:106*
> *106 if (!TRdebug) return PETSC_SUCCESS;*
> *(gdb) *
> *154 }*
> Am I not using MKL BLAS, is that why I didn’t see multithreading speed up
> for KSPGMRESOrthog? What do you think could be the potential reasons? Is
> there any silent mode that will possibly affect the MKL Verbose.
> Thank you and best regards,
> Yongzhong
> *From: *Barry Smith <bsmith at petsc.dev>
> *Date: *Wednesday, June 26, 2024 at 8:15 PM
> *To: *Yongzhong Li <yongzhong.li at mail.utoronto.ca>
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] [petsc-maint] Assistance Needed with PETSc
> if (m > 1) {
> PetscBLASInt ione = 1, lda2 = (PetscBLASInt)lda; // the cast is safe
> PetscCallBLAS("BLASgemv", BLASgemv_(trans, &n, &m, &one, yarray,
> PetscCall(PetscLogFlops(PetscMax(m * (2.0 * n - 1), 0.0)));
> The call to BLAS above is where it uses MKL.
> On Jun 26, 2024, at 6:59 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
> wrote:
> Hi Barry, I am looking into the source codes of VecMultiDot_Seq_GEMV
> https://urldefense.us/v3/__https://petsc.org/release/src/vec/vec/impls/seq/dvec2.c.html*VecMDot_Seq__;Iw!!G_uCfscf7eWS!fXzW07uptbVnpewjH3Gn1K7QwYw0tD9yNS7qkulS__TDbnWy2tZNakl7i46b_GUg_fdSr7oBEfVlTZ8cz-fxxmj_HT2Z$
> <https://urldefense.us/v3/__https://petsc.org/release/src/vec/vec/impls/seq/dvec2.c.html*VecMDot_Seq__;Iw!!G_uCfscf7eWS!YUfsVRoVQQfGeK-iIORKffgc0-KL_n2OafjYnTsZGQRuWDiAbJ4RwqB3SmhIIvM83o5y6AP1fc_gaJVsJ8Fk2-2ihVffczoTXjA$>
> Can I ask which lines of codes suggest the use of intel mkl?
> Thanks,
> Yongzhong
> *Date: *Wednesday, June 26, 2024 at 10:30 AM
> In a debug version of PETSc run your application in a debugger and put
> a break point in VecMultiDot_Seq_GEMV. Then next through the code from
> that point to see what decision it makes about using dgemv() to see why it
> is not getting into the Intel code.
> On Jun 25, 2024, at 11:19 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
> Hi Junchao, thank you for your help for these benchmarking test!
> I check out to petsc/main and did a few things to verify from my side,
> 1. I ran the microbenchmark (vec/vec/tests/ex2k.c) test on my compute
> node. The results are as follow,
> $ MKL_NUM_THREADS=64 ./ex2k -n 15 -m 4
> Vector(N) VecMDot-1 VecMDot-3 VecMDot-8 VecMDot-30 (us)
> 128 14.5 1.2 1.8 5.2
> 256 1.5 0.9 1.6 4.7
> 512 2.7 2.8 6.1 13.2
> 1024 4.0 4.0 9.3 16.4
> 2048 7.4 7.3 11.3 39.3
> 4096 14.2 13.9 19.1 93.4
> 8192 28.8 26.3 25.4 31.3
> 16384 54.1 25.8 26.7 33.8
> 32768 109.8 25.7 24.2 56.0
> 65536 220.2 24.4 26.5 89.0
> 131072 424.1 31.5 36.1 149.6
> 262144 898.1 37.1 53.9 286.1
> 524288 1754.6 48.7 100.3 1122.2
> 1048576 3645.8 86.5 347.9 2950.4
> 2097152 7371.4 308.7 1440.6 6874.9
> $ MKL_NUM_THREADS=1 ./ex2k -n 15 -m 4
> 128 14.9 1.2 1.9 5.2
> 256 1.5 1.0 1.7 4.7
> 512 2.7 2.8 6.1 12.0
> 1024 3.9 4.0 9.3 16.8
> 2048 7.4 7.3 10.4 41.3
> 4096 14.0 13.8 18.6 84.2
> 8192 27.0 21.3 43.8 177.5
> 16384 54.1 34.1 89.1 330.4
> 32768 110.4 82.1 203.5 781.1
> 65536 213.0 191.8 423.9 1696.4
> 131072 428.7 360.2 934.0 4080.0
> 262144 883.4 723.2 1745.6 10120.7
> 524288 1817.5 1466.1 4751.4 23217.2
> 1048576 3611.0 3796.5 11814.9 48687.7
> 2097152 7401.9 10592.0 27543.2 106565.4
> I can see the speed up brought by more MKL threads, and if I set
> NKL_VERBOSE to 1, I can see something like
> *MKL_VERBOSE
> ZGEMV(C,262144,8,0x7ffd375d6470,0x2ac76e7fb010,262144,0x16d0f40,1,0x7ffd375d6480,0x16435d0,1)
> 32.70us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:6 ca *From my understanding,
> the VecMDot()/VecMAXPY() can benefit from more MKL threads in my compute
> node and is using ZGEMV MKL BLAS.
> However, when I ran my own program and set MKL_VERBOSE to 1, it is very
> strange that I still can’t find any MKL outputs, though I can see from the
> PETSc log that VecMDot and VecMAXPY() are called.
> I am wondering are VecMDot and VecMAXPY in KSPGMRESOrthog optimized in a
> way that is similar to ex2k test? Should I expect to see MKL outputs for
> whatever linear system I solve with KSPGMRES? Does it relate to if it is
> dense matrix or sparse matrix, although I am not really understand why
> VecMDot/MAXPY() have something to do with dense matrix-vector
> multiplication.
> Thank you,
> Yongzhong
> *From: *Junchao Zhang <junchao.zhang at gmail.com>
> *Date: *Tuesday, June 25, 2024 at 6:34 PM
> *To: *Matthew Knepley <knepley at gmail.com>
> *Cc: *Yongzhong Li <yongzhong.li at mail.utoronto.ca>, Pierre Jolivet <
> pierre at joliv.et>, petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> Hi, Yongzhong,
> Since the two kernels of KSPGMRESOrthog are VecMDot and VecMAXPY, if we
> can speed up the two with OpenMP threads, then we can speed up
> KSPGMRESOrthog. We recently added an optimization to do VecMDot/MAXPY() in
> dense matrix-vector multiplication (i.e., BLAS2 GEMV, with tall-and-skinny
> matrices ). So with MKL_VERBOSE=1, you should see something like
> "MKL_VERBOSE ZGEMV ..." in output. If not, could you try again with
> petsc/main?
> petsc has a microbenchmark (vec/vec/tests/ex2k.c) to test them. I ran
> VecMDot with multithreaded oneMKL (via setting MKL_NUM_THREADS), it was
> strange to see no speedup. I then configured petsc with openblas, I did
> see better performance with more threads
> $ OMP_PROC_BIND=spread OMP_NUM_THREADS=1 ./ex2k -n 15 -m 4
> Vector(N) VecMDot-3 VecMDot-8 VecMDot-30 (us)
> 128 2.0 2.5 6.1
> 256 1.8 2.7 7.0
> 512 2.1 3.1 8.6
> 1024 2.7 4.0 12.3
> 2048 3.8 6.3 28.0
> 4096 6.1 10.6 42.4
> 8192 10.9 21.8 79.5
> 16384 21.2 39.4 149.6
> 32768 45.9 75.7 224.6
> 65536 142.2 215.8 732.1
> 131072 169.1 233.2 1729.4
> 262144 367.5 830.0 4159.2
> 524288 999.2 1718.1 8538.5
> 1048576 2113.5 4082.1 18274.8
> 2097152 5392.6 10273.4 43273.4
> $ OMP_PROC_BIND=spread OMP_NUM_THREADS=8 ./ex2k -n 15 -m 4
> 128 2.0 2.5 6.0
> 256 1.8 2.7 15.0
> 512 2.1 9.0 16.6
> 1024 2.6 8.7 16.1
> 2048 7.7 10.3 20.5
> 4096 9.9 11.4 25.9
> 8192 14.5 22.1 39.6
> 16384 25.1 27.8 67.8
> 32768 44.7 95.7 91.5
> 65536 82.1 156.8 165.1
> 131072 194.0 335.1 341.5
> 262144 388.5 380.8 612.9
> 524288 1046.7 967.1 1653.3
> 1048576 1997.4 2169.0 4034.4
> 2097152 5502.9 5787.3 12608.1
> The tall-and-skinny matrices in KSPGMRESOrthog vary in width. The average
> speedup depends on components. So I suggest you run ex2k to see in your
> environment whether oneMKL can speedup the kernels.
> --Junchao Zhang
> On Mon, Jun 24, 2024 at 11:35 AM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> Let me run some examples on our end to see whether the code calls expected
> functions.
> --Junchao Zhang
> On Mon, Jun 24, 2024 at 10:46 AM Matthew Knepley <knepley at gmail.com>
> wrote:
> On Mon, Jun 24, 2024 at 11: 21 AM Yongzhong Li <yongzhong. li@ mail.
> utoronto. ca> wrote: Thank you Pierre for your information. Do we have a
> conclusion for my original question about the parallelization efficiency
> for different stages of
> *This Message Is From an External Sender*
> On Mon, Jun 24, 2024 at 11:21 AM Yongzhong Li <
> yongzhong.li at mail.utoronto.ca> wrote:
> Thank you Pierre for your information. Do we have a conclusion for my
> original question about the parallelization efficiency for different stages
> of KSP Solve? Do we need to do more testing to figure out the issues? Thank
> you, Yongzhong From:
> We have an extended discussion of this here:
> https://urldefense.us/v3/__https://petsc.org/release/faq/*what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup__;Iw!!G_uCfscf7eWS!fXzW07uptbVnpewjH3Gn1K7QwYw0tD9yNS7qkulS__TDbnWy2tZNakl7i46b_GUg_fdSr7oBEfVlTZ8cz-fxxpKPCDL9$
> <https://urldefense.us/v3/__https://petsc.org/release/faq/*what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup__;Iw!!G_uCfscf7eWS!aQJpmm5W6l6FUiumnIPmkouzwzNUfx-Dyq04i1O2KS_InQGk6qjI7wUir0Hx6QEUQE2AMiJDsez3x4zRO7V_$>
> The kinds of operations you are talking about (SpMV, VecDot, VecAXPY, etc)
> are memory bandwidth limited. If there is no more bandwidth to be
> marshalled on your board, then adding more processes does nothing at all.
> This is why people were asking about how many "nodes" you are running on,
> because that is the unit of memory bandwidth, not "cores" which make little
> difference.
> Thanks,
> Matt
> Thank you,
> Yongzhong
> *From: *Pierre Jolivet <pierre at joliv.et>
> *Date: *Sunday, June 23, 2024 at 12:41 AM
> On 23 Jun 2024, at 4:07 AM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
> Yeah, I ran my program again using -mat_view::ascii_info and set
> MKL_VERBOSE to be 1, then I noticed the outputs suggested that the matrix
> to be seqaijmkl type (I’ve attached a few as below)
> --> Setting up matrix-vector products...
> Mat Object: 1 MPI process
> type: seqaijmkl
> rows=16490, cols=35937
> total: nonzeros=128496, allocated nonzeros=128496
> total number of mallocs used during MatSetValues calls=0
> not using I-node routines
> type: seqaijmkl
> --> Solving the system...
> Excitation 1 of 1...
> Iterative solve completed in 7435 ms.
> CONVERGED: rtol.
> Iterations: 72
> Final relative residual norm: 9.22287e-07
> [CPU TIME] System solution: 2.27160000e+02 s.
> [WALL TIME] System solution: 7.44387218e+00 s.
> However, it seems to me that there were still no MKL outputs even I set
> MKL_VERBOSE to be 1. Although, I think it should be many spmv operations
> when doing KSPSolve(). Do you see the possible reasons?
> SPMV are not reported with MKL_VERBOSE (last I checked), only dense BLAS
> is.
> Thanks,
> Pierre
> Thanks,
> Yongzhong
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Saturday, June 22, 2024 at 5:56 PM
> *Cc: *Junchao Zhang <junchao.zhang at gmail.com>, Pierre Jolivet <
> 你通常不会收到来自 knepley at gmail.com 的电子邮件。了解这一点为什么很重要
> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!fVvbGldqcUV5ju4jpu5oGmt-VjITi5JpCJzhHxpbgsERLVYZzglpxKOOyrBRGxjRxp7vWHwt3SnINFOQErR1Z8kcDcf3qwbYRxM$>
> On Sat, Jun 22, 2024 at 5:03 PM Yongzhong Li <
> MKL_VERBOSE=1 ./ex1 matrix nonzeros = 100, allocated nonzeros = 100
> MKL_VERBOSE Intel(R) MKL 2019. 0 Update 4 Product build 20190411 for
> Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 512 (Intel(R)
> AVX-512) with support of Vector
> MKL_VERBOSE=1 ./ex1
> MKL_VERBOSE Intel(R) MKL 2019.0 Update 4 Product build 20190411 for
> AVX-512) with support of Vector Neural Network Instructions enabled
> processors, Lnx 2.50GHz lp64 gnu_thread
> MKL_VERBOSE
> ZGEMV(N,10,10,0x7ffd9d7078f0,0x187eb20,10,0x187f7c0,1,0x7ffd9d707900,0x187ff70,1)
> 167.34ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x7ffd9d7078c0,-1,0)
> 77.19ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x1894490,10,0) 83.97ms
> MKL_VERBOSE ZSYTRS(L,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 44.94ms
> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 20.72us
> MKL_VERBOSE ZSYTRS(L,10,2,0x1894b50,10,0x1893df0,0x187d2a0,10,0) 4.22us
> MKL_VERBOSE
> ZGEMM(N,N,10,2,10,0x7ffd9d707790,0x187eb20,10,0x187d2a0,10,0x7ffd9d7077a0,0x1896a70,10)
> 1.41ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE ZAXPY(20,0x7ffd9d7078a0,0x1896a70,1,0x187b650,1) 381ns CNR:OFF
> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x7ffd9d707840,-1,0) 742ns
> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x18951a0,10,0) 4.20us
> MKL_VERBOSE ZSYTRS(L,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 2.94us
> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 292ns CNR:OFF
> MKL_VERBOSE
> 1.17us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE ZGETRF(10,10,0x1894b50,10,0x1893df0,0) 202.48ms CNR:OFF Dyn:1
> MKL_VERBOSE ZGETRS(N,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 20.78ms
> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 954ns CNR:OFF
> MKL_VERBOSE ZGETRS(N,10,2,0x1894b50,10,0x1893df0,0x187d2a0,10,0) 30.74ms
> MKL_VERBOSE
> ZGEMM(N,N,10,2,10,0x7ffd9d707790,0x187eb20,10,0x187d2a0,10,0x7ffd9d7077a0,0x18969c0,10)
> 3.95us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE ZAXPY(20,0x7ffd9d7078a0,0x18969c0,1,0x187b650,1) 995ns CNR:OFF
> MKL_VERBOSE ZGETRF(10,10,0x1894b50,10,0x1893df0,0) 4.09us CNR:OFF Dyn:1
> MKL_VERBOSE ZGETRS(N,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 3.92us
> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 274ns CNR:OFF
> MKL_VERBOSE
> ZGEMV(N,15,10,0x7ffd9d7078f0,0x187ec70,15,0x187fc30,1,0x7ffd9d707900,0x1880400,1)
> 1.59us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x1894550,0x7ffd9d707900,-1,0)
> 47.07us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x1894550,0x1895cb0,10,0) 26.62us
> MKL_VERBOSE
> ZUNMQR(L,C,15,1,10,0x1894b40,15,0x1894550,0x1895b00,15,0x7ffd9d7078b0,-1,0)
> 35.32us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE
> ZUNMQR(L,C,15,1,10,0x1894b40,15,0x1894550,0x1895b00,15,0x1895cb0,10,0)
> 42.33ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE ZTRTRS(U,N,N,10,1,0x1894b40,15,0x1895b00,15,0) 16.11us CNR:OFF
> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187fc30,1,0x1880c70,1) 395ns CNR:OFF
> MKL_VERBOSE
> ZGEMM(N,N,15,2,10,0x7ffd9d707790,0x187ec70,15,0x187d310,10,0x7ffd9d7077a0,0x187b5b0,15)
> 3.22us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE
> ZUNMQR(L,C,15,2,10,0x1894b40,15,0x1894550,0x1897760,15,0x7ffd9d7078c0,-1,0)
> 730ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE
> ZUNMQR(L,C,15,2,10,0x1894b40,15,0x1894550,0x1897760,15,0x1895cb0,10,0)
> 4.42us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE ZTRTRS(U,N,N,10,2,0x1894b40,15,0x1897760,15,0) 5.96us CNR:OFF
> MKL_VERBOSE ZAXPY(20,0x7ffd9d7078a0,0x187d310,1,0x1897610,1) 222ns CNR:OFF
> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x18954b0,0x7ffd9d707820,-1,0) 685ns
> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x18954b0,0x1895d60,10,0) 6.11us
> MKL_VERBOSE
> ZUNMQR(L,C,15,1,10,0x1894b40,15,0x18954b0,0x1895bb0,15,0x7ffd9d7078b0,-1,0)
> 390ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE
> ZUNMQR(L,C,15,1,10,0x1894b40,15,0x18954b0,0x1895bb0,15,0x1895d60,10,0)
> 3.09us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
> MKL_VERBOSE ZTRTRS(U,N,N,10,1,0x1894b40,15,0x1895bb0,15,0) 1.05us CNR:OFF
> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187fc30,1,0x1880c70,1) 257ns CNR:OFF
> Yes, for petsc example, there are MKL outputs, but for my own program. All
> I did is to change the matrix type from MATAIJ to MATAIJMKL to get
> optimized performance for spmv from MKL. Should I expect to see any MKL
> outputs in this case?
> Are you sure that the type changed? You can MatView() the matrix with
> format ascii_info to see.
> Thanks,
> Matt
> Thanks,
> Yongzhong
> *Date: *Saturday, June 22, 2024 at 9:40 AM
> *Cc: *Pierre Jolivet <pierre at joliv.et>, petsc-users at mcs.anl.gov <
> No, you don't. It is strange. Perhaps you can you run a petsc example
> first and see if MKL is really used
> $ cd src/mat/tests
> $ make ex1
> $ MKL_VERBOSE=1 ./ex1
> --Junchao Zhang
> On Fri, Jun 21, 2024 at 4:03 PM Yongzhong Li <
> I am using
> export MKL_VERBOSE=1
> ./xx
> in the bash file, do I have to use - ksp_converged_reason?
> Thanks,
> Yongzhong
> *Date: *Friday, June 21, 2024 at 1:47 PM
> *Cc: *Junchao Zhang <junchao.zhang at gmail.com>, petsc-users at mcs.anl.gov <
> 你通常不会收到来自 pierre at joliv.et 的电子邮件。了解这一点为什么很重要
> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!flsZMI97ne0yyxHhLda3hROB9qsgstuZS-jPinxGIzFCCSdn1ujdoMR8dyz-5_kVqqMM-12Lt0dTdjKrx3wXhHZmBhNydvFQeSY$>
> How do you set the variable?
> $ MKL_VERBOSE=1 ./ex1 -ksp_converged_reason
> MKL_VERBOSE oneMKL 2024.0 Update 1 Product build 20240215 for Intel(R) 64
> architecture Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2) enabled
> processors, Lnx 2.80GHz lp64 intel_thread
> MKL_VERBOSE DDOT(10,0x22127c0,1,0x22127c0,1) 2.02ms CNR:OFF Dyn:1 FastMM:1
> TID:0 NThr:1
> MKL_VERBOSE DSCAL(10,0x7ffc9fb4ff08,0x22127c0,1) 12.67us CNR:OFF Dyn:1
> MKL_VERBOSE DDOT(10,0x22127c0,1,0x2212840,1) 1.52us CNR:OFF Dyn:1 FastMM:1
> TID:0 NThr:1
> MKL_VERBOSE DDOT(10,0x2212840,1,0x2212840,1) 167ns CNR:OFF Dyn:1 FastMM:1
> TID:0 NThr:1
> On 21 Jun 2024, at 7:37 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
> Hello all,
> I set MKL_VERBOSE = 1, but observed no print output specific to the use of
> MKL. Does PETSc enable this verbose output?
> Best,
> Yongzhong
> *Date: *Friday, June 21, 2024 at 1:36 AM
> *To: *Junchao Zhang <junchao.zhang at gmail.com>
> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!eXBeeIXo9Yqgp2nypqwKYimLnGBZXnF4dXxgLM1UoOIO6n8nt3XlfgjVWLPWJh4UOa5NNpx-nrJb_H828XRQKUREfR2m69oCbxI$>
> On 21 Jun 2024, at 6:42 AM, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> I remember there are some MKL env vars to print MKL routines called.
> The environment variable is MKL_VERBOSE
> Thanks,
> Pierre
> Maybe we can try it to see what MKL routines are really used and then we
> can understand why some petsc functions did not speed up
> --Junchao Zhang
> On Thu, Jun 20, 2024 at 10:39 PM Yongzhong Li <
> Hi Barry, sorry for my last results. I didn’t fully understand the stage
> profiling and logging in PETSc, now I only record KSPSolve() stage of my
> program. Some sample codes are as follow,
> // Static variable to keep track of the stage counter
> static int stageCounter = 1;
> // Generate a unique stage name
> std::ostringstream oss;
> oss << "Stage " << stageCounter << " of Code";
> std::string stageName = oss.str();
> // Register the stage
> PetscLogStage stagenum;
> PetscLogStageRegister(stageName.c_str(), &stagenum);
> PetscLogStagePush(stagenum);
> *KSPSolve(*ksp_ptr, b, x);*
> PetscLogStagePop();
> stageCounter++;
> I have attached my new logging results, there are 1 main stage and 4 other
> stages where each one is KSPSolve() call.
> To provide some additional backgrounds, if you recall, I have been trying
> to get efficient iterative solution using multithreading. I found out by
> compiling PETSc with Intel MKL library instead of OpenBLAS, I am able to
> perform sparse matrix-vector multiplication faster, I am using
> MATSEQAIJMKL. This makes the shell matrix vector product in each iteration
> scale well with the #of threads. However, I found out the total GMERS solve
> time (~KSPSolve() time) is not scaling well the #of threads.
> From the logging results I learned that when performing KSPSolve(), there
> are some CPU overheads in PCApply() and KSPGMERSOrthog(). I ran my programs
> using different number of threads and plotted the time consumption for
> PCApply() and KSPGMERSOrthog() against #of thread. I found out these two
> operations are not scaling with the threads at all! My results are attached
> as the pdf to give you a clear view.
> My questions is,
> From my understanding, in PCApply, MatSolve() is involved,
> KSPGMERSOrthog() will have many vector operations, so why these two parts
> can’t scale well with the # of threads when the intel MKL library is linked?
> Thank you,
> Yongzhong
> *Date: *Friday, June 14, 2024 at 11:36 AM
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>,
> petsc-maint at mcs.anl.gov <petsc-maint at mcs.anl.gov>, Piero Triverio <
> piero.triverio at utoronto.ca>
> *Subject: *Re: [petsc-maint] Assistance Needed with PETSc KSPSolve
> Performance Issue
> I am a bit confused. Without the initial guess computation, there are
> still a bunch of events I don't understand
> MatTranspose 79 1.0 4.0598e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> MatMatMultSym 110 1.0 1.7419e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
> MatMatMultNum 90 1.0 1.2640e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMatMatMultSym 20 1.0 1.3049e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatRARtSym 25 1.0 1.2492e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMatTrnMultSym 25 1.0 8.8265e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMatTrnMultNum 25 1.0 2.4820e+02 1.0 6.83e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 1 0 0 0 0 1 0 0 0 0 275
> MatTrnMatMultSym 10 1.0 7.2984e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatTrnMatMultNum 10 1.0 9.3128e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> in addition there are many more VecMAXPY then VecMDot (in GMRES they are
> each done the same number of times)
> VecMDot 5588 1.0 1.7183e+03 1.0 2.06e+13 1.0 0.0e+00 0.0e+00
> 0.0e+00 8 10 0 0 0 8 10 0 0 0 12016
> VecMAXPY 22412 1.0 8.4898e+03 1.0 4.17e+13 1.0 0.0e+00 0.0e+00
> 0.0e+00 39 20 0 0 0 39 20 0 0 0 4913
> Finally there are a huge number of
> MatMultAdd 258048 1.0 1.4178e+03 1.0 6.10e+13 1.0 0.0e+00 0.0e+00
> 0.0e+00 7 29 0 0 0 7 29 0 0 0 43025
> Are you making calls to all these routines? Are you doing this inside your
> MatMult() or before you call KSPSolve?
> The reason I wanted you to make a simpler run without the initial guess
> code is that your events are far more complicated than would be produced by
> GMRES alone so it is not possible to understand the behavior you are seeing
> without fully understanding all the events happening in the code.
> Barry
> On Jun 14, 2024, at 1:19 AM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
> wrote:
> Thanks, I have attached the results without using any KSPGuess. At low
> frequency, the iteration steps are quite close to the one with KSPGuess,
> specifically
> KSPGuess Object: 1 MPI process
> type: fischer
> Model 1, size 200
> However, I found at higher frequency, the # of iteration steps are
> significant higher than the one with KSPGuess, I have attahced both of the
> results for your reference.
> Moreover, could I ask why the one without the KSPGuess options can be used
> for a baseline comparsion? What are we comparing here? How does it relate
> to the performance issue/bottleneck I found? “*I have noticed that the
> time taken by **KSPSolve** is **almost two times **greater than the CPU
> time for matrix-vector product multiplied by the number of iteration*”
> Thank you!
> Yongzhong
> *Date: *Thursday, June 13, 2024 at 2:14 PM
> Performance Issue
> Can you please run the same thing without the KSPGuess option(s) for a
> baseline comparison?
> Thanks
> Barry
> On Jun 13, 2024, at 1:27 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
> Hi Matt,
> I have rerun the program with the keys you provided. The system output
> when performing ksp solve and the final petsc log output were stored in a
> .txt file attached for your reference.
> Thanks!
> Yongzhong
> *Date: *Wednesday, June 12, 2024 at 6:46 PM
> Performance Issue
> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!djGfJnEhNJROfsMsBJy5u_KoRKbug55xZ64oHKUFnH2cWku_Th1hwt4TDdoMd8pWYVDzJeqJslMNZwpO3y0Et94d31qk-oCEwo4$>
> On Wed, Jun 12, 2024 at 6:36 PM Yongzhong Li <
> Dear PETSc’s developers, I hope this email finds you well. I am currently
> working on a project using PETSc and have encountered a performance issue
> with the KSPSolve function. Specifically, I have noticed that the time
> taken by KSPSolve is
> I am currently working on a project using PETSc and have encountered a
> performance issue with the KSPSolve function. Specifically, *I have
> noticed that the time taken by **KSPSolve** is **almost two times **greater
> than the CPU time for matrix-vector product multiplied by the number of
> iteration steps*. I use C++ chrono to record CPU time.
> For context, I am using a shell system matrix A. Despite my efforts to
> parallelize the matrix-vector product (Ax), the overall solve time
> remains higher than the matrix vector product per iteration indicates
> when multiple threads were used. Here are a few details of my setup:
> - *Matrix Type*: Shell system matrix
> - *Preconditioner*: Shell PC
> - *Parallel Environment*: Using Intel MKL as PETSc’s BLAS/LAPACK
> library, multithreading is enabled
> I have considered several potential reasons, such as preconditioner setup,
> additional solver operations, and the inherent overhead of using a shell
> system matrix. *However, since KSPSolve is a high-level API, I have been
> unable to pinpoint the exact cause of the increased solve time.*
> Have you observed the same issue? Could you please provide some
> experience on how to diagnose and address this performance discrepancy?
> Any insights or recommendations you could offer would be greatly
> appreciated.
> For any performance question like this, we need to see the output of your
> code run with
> -ksp_view -ksp_monitor_true_residual -ksp_converged_reason -log_view
> Thanks,
> Matt
> Thank you for your time and assistance.
> Best regards,
> Yongzhong
> *Yongzhong Li*
> PhD student | Electromagnetics Group
> Department of Electrical & Computer Engineering
> University of Toronto
> https://urldefense.us/v3/__http://www.modelics.org__;!!G_uCfscf7eWS!fXzW07uptbVnpewjH3Gn1K7QwYw0tD9yNS7qkulS__TDbnWy2tZNakl7i46b_GUg_fdSr7oBEfVlTZ8cz-fxxlUVQ5ec$
> <https://urldefense.us/v3/__http://www.modelics.org__;!!G_uCfscf7eWS!cuLttMJEcegaqu461Bt4QLsO4fASfLM5vjRbtyNhWJQiInbjgNwkGNdkFE1ebSbFjOUatYB0-jd2yQWMWzqkDFFjwMvNl3ZKAr8$>
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fXzW07uptbVnpewjH3Gn1K7QwYw0tD9yNS7qkulS__TDbnWy2tZNakl7i46b_GUg_fdSr7oBEfVlTZ8cz-fxxoToYAaW$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!djGfJnEhNJROfsMsBJy5u_KoRKbug55xZ64oHKUFnH2cWku_Th1hwt4TDdoMd8pWYVDzJeqJslMNZwpO3y0Et94d31qkNOuenGA$>
> <ksp_petsc_log.txt>
> <ksp_petsc_log.txt><ksp_petsc_log_noguess.txt>
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fVvbGldqcUV5ju4jpu5oGmt-VjITi5JpCJzhHxpbgsERLVYZzglpxKOOyrBRGxjRxp7vWHwt3SnINFOQErR1Z8kcDcf3cNeD9Gw$>
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!aQJpmm5W6l6FUiumnIPmkouzwzNUfx-Dyq04i1O2KS_InQGk6qjI7wUir0Hx6QEUQE2AMiJDsez3x2Os2C2d$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240627/cf385ca7/attachment-0001.html>
