[petsc-users] [petsc-maint] Assistance Needed with PETSc KSPSolve Performance Issue
Junchao Zhang
junchao.zhang at gmail.com
Fri Jun 28 13:33:00 CDT 2024
OK, then you need '--with-mkl_pardiso-dir='+os.environ['MKLROOT'] in petsc
configure
--Junchao Zhang
On Fri, Jun 28, 2024 at 1:05 PM Pierre Jolivet <pierre.jolivet at lip6.fr>
wrote:
> On 28 Jun 2024, at 7:20 PM, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Hi, Yongzhong,
> It is great to see you have made such good progress. Barry is right,
> you need -vec_maxpy_use_gemv 1. It's my mistake for not mentioning it
> earlier. But even with that, there are still problems.
> petsc tries to optimize VecMDot/MAXPY with BLAS GEMV, with hope that
> vendors' BLAS library would be highly optimized on that. However, we found
> though they were good with VecMDot, but not with VecMAXPY. So by default
> in petsc, we disabled the GEMV optimization for VecMAXPY. One can use
> -vec_maxpy_use_gemv 1 to turn on it.
> I turned it on and tested VecMAXPY with ex2k and MKL, but failed to see
> any improvement with multiple threads. I could not understand why MKL is
> so bad on it. You can try it yourself in your environment.
> Without the GEMV optimization, VecMAXPY() is implemented by petsc with
> a batch of PetscKernelAXPY() kernels, which contain simple for loops but
> not OpenMP parallelized (since petsc does not support OpenMP outright) . I
> added "omp parallel for" pragma in PetscKernelAXPY() kernels, and tested
> ex2k again with now parallelized petsc. Here is the result.
> $ OMP_PLACES=cores OMP_PROC_BIND=spread OMP_NUM_THREADS=1 ./ex2k -n 15 -m
> 2 -test_name VecMAXPY -vec_maxpy_use_gemv 0
> Vector(N) VecMAXPY-1 VecMAXPY-3 VecMAXPY-8 VecMAXPY-30 (us)
> 128 7.0 10.1 21.4 72.7
> 256 7.9 12.9 29.5 101.0
> 512 9.4 17.2 40.5 136.2
> 1024 15.9 27.3 67.5 249.3
> 2048 26.5 48.7 139.6 432.7
> 4096 47.1 77.3 186.4 710.3
> 8192 84.8 152.2 423.9 1580.6
> 16384 154.9 298.5 792.1 2889.2
> 32768 183.7 338.7 893.9 3436.2
> 65536 639.1 1247.8 3219.1 12494.8
> 131072 1125.2 1856.2 6843.0 23653.7
> 262144 2603.2 4948.4 13259.4 51287.7
> 524288 5093.6 10305.0 26451.7 96919.6
> 1048576 5898.6 10947.2 45486.4 127352.8
> 2097152 11845.4 21912.5 57999.6 331403.4
> $ OMP_PLACES=cores OMP_PROC_BIND=spread OMP_NUM_THREADS=16 ./ex2k -n 15 -m
> 128 17.0 16.1 31.5 112.9
> 256 13.7 16.8 31.2 120.2
> 512 14.5 18.1 33.9 129.9
> 1024 16.5 21.0 38.5 150.4
> 2048 18.5 22.1 41.8 171.4
> 4096 21.0 25.4 55.3 212.3
> 8192 27.0 30.3 68.6 251.9
> 16384 32.2 44.5 93.3 350.5
> 32768 45.8 65.0 149.8 558.8
> 65536 59.7 102.8 247.1 946.0
> 131072 100.7 186.4 485.3 1898.1
> 262144 183.4 345.2 922.2 3567.0
> 524288 339.6 676.8 1820.7 7530.4
> 1048576 662.0 1364.7 3585.3 13969.1
> 2097152 1379.7 2788.6 7414.0 28275.3
> We can see VecMAXPY() can be easily speeded up with multithreading.
> For MatSolve, I checked petsc's aijmkl.c, and found we don't have
> interface to MKL's sparse solve.
> We do, it’s in src/mat/impls/aij/seq/mkl_pardiso, and it’s threaded (the
> distributed version is in src/mat/impls/aij/mpi/mkl_cpardiso).
> Thanks,
> Pierre
> I checked
> https://urldefense.us/v3/__https://www.intel.com/content/www/us/en/docs/onemkl/developer-guide-linux/2023-0/openmp-threaded-functions-and-problems.html__;!!G_uCfscf7eWS!cw4NqFC1djrGs8b1mL87vRIl7UhAC-HTBFefyAgrI5AoRpxI-JFc1ejwiH0LcrfhGr0_nA_giCdoDZLyYbpe_-ec-aQc$
> <https://urldefense.us/v3/__https://www.intel.com/content/www/us/en/docs/onemkl/developer-guide-linux/2023-0/openmp-threaded-functions-and-problems.html__;!!G_uCfscf7eWS!bT8Fh0B1GB5nDS3DTpc--fcfGuqOeym0MPwCORXl6F2Sy8A0GFIbVFQUT0J54XZ5Ds7eG_kLdQ-s6tD0GVEQIgTsoHmt$>,
> but confused with MKL's list of threaded function
> - Direct sparse solver.
> - All Level 3 BLAS and all Sparse BLAS routines except Level 2 Sparse
> Triangular solvers.
> I don't know whether MKL has threaded sparse solver.
> --Junchao Zhang
> On Fri, Jun 28, 2024 at 11:35 AM Barry Smith <bsmith at petsc.dev> wrote:
>> Are you running with -vec_maxpy_use_gemv ?
>> On Jun 28, 2024, at 1:46 AM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>> wrote:
>> Thanks all for your help!!!
>> I think I find the issues. I am compiling a large CMake project that
>> relies on many external libraries (projects). Previously, I used OpenBLAS
>> as the BLAS for all the dependencies including PETSc. After I switched to
>> Intel MKL for PETSc, I still kept the OpenBLAS and use it as the BLAS for
>> all the other dependencies. I think somehow even when I specify the
>> blas-lapack-dir to the MKLROOT when PETSc is configured, the actual program
>> still use OpenBLAS as the BLAS for some PETSc functions, such as VecMDot()
>> and VecMAXPY(), so that’s why I didn’t see any MKL verbose during the
>> KSPSolve(). Now I remove the OpenBLAS and use Intel MKL as the BLAS for all
>> the dependencies. The issue is resolved, I can clearly see MKL routines are
>> called when KSP GMRES is running.
>> Back to my original questions, my goal is to achieve good parallelization
>> efficiency for KSP GMRES Solve. As I use multithreading-enabled MKL spmv
>> routines, the wall time for MatMult/MatMultAdd() has been greatly reduced.
>> However,the KSPGMRESOrthog and MatSolve in PCApply still take over 50% of
>> solving time and can’t benefit from multithreading. *After I fixed the
>> issue I mentioned, I found I got around 15% time reduced because of more
>> efficient VecMDot() calls*. I attach a petsc log comparison for your
>> reference (same settings, only difference is whether use MKL BLAS or not),
>> you can see the percentage of VecMDot() is reduced. However, here comes the
>> interesting part, *VecMAXPY() didn’t benefit from MKL BLAS, it still
>> takes almost 40% of solution when I use 64 MKL Threads*, which is a lot
>> for my program. And if I multiple this percentage with the actual wall time
>> against different # of threads, it stays the same. Then I used ex2k
>> benchmark to verify what I found. Here is the result,
>> $ MKL_NUM_THREADS=1 ./ex2k -n 15 -m 5 -test_name VecMAXPY
>> 128 0.4 0.9 2.4 8.8
>> 256 0.3 1.1 3.5 13.3
>> 512 0.5 4.4 6.7 26.5
>> 1024 0.9 4.8 13.3 51.0
>> 2048 3.5 12.3 37.1 94.7
>> 4096 4.3 24.5 73.6 179.6
>> 8192 6.3 48.7 98.9 380.8
>> 16384 9.3 99.2 200.2 774.0
>> 32768 30.6 155.4 421.2 1662.9
>> 65536 101.2 269.4 827.4 3565.0
>> 131072 206.9 551.0 1829.0 7580.5
>> 262144 450.2 1251.9 3986.2 15525.6
>> 524288 1322.1 2901.7 8567.1 31840.0
>> 1048576 2788.6 6190.6 16394.7 63514.9
>> 2097152 5534.8 12619.9 35427.4 130064.5
>> $ MKL_NUM_THREADS=8 ./ex2k -n 15 -m 5 -test_name VecMAXPY
>> 128 0.3 0.7 2.4 8.8
>> 256 0.3 1.1 3.6 13.5
>> 512 0.5 4.4 6.8 26.4
>> 1024 0.9 4.8 13.6 50.5
>> 2048 7.6 12.2 36.5 95.0
>> 4096 8.5 25.7 72.4 182.6
>> 8192 11.9 48.5 103.7 383.7
>> 16384 12.8 97.7 203.7 785.0
>> 32768 11.2 148.5 421.9 1681.5
>> 65536 15.5 271.2 843.8 3613.7
>> 131072 34.3 564.7 1905.2 7558.8
>> 262144 106.4 1334.5 4002.8 15458.3
>> 524288 217.2 2858.4 8407.9 31303.7
>> 1048576 701.5 6060.6 16947.3 64118.5
>> 2097152 1769.7 13218.3 36347.3 131062.9
>> It stays the same, no benefit from multithreading BLAS!! Unlike what I
>> found for VecMdot(), where I did see speed up for more #of threads. Then, I
>> dig deeper. *I learned that for VecMDot(), it calls ZGEMV while for
>> VecMAXPY(), it calls ZAXPY. This observation seems to indicate that ZAXPY
>> is not benefiting from MKL threads.*
>> My question is *do you know why ZAXPY is not multithreaded*? From my
>> perspective, VecMDot() and VecMAXPY() are very similar operations, the
>> only difference is whether we need to scale the vectors to be multiplied or
>> not. I think you have mentioned that recently you did some optimization to
>> these two routines*, from my above results and observations, are these
>> aligned with your expectations*? Could we further optimize the codes to
>> get more parallelization efficiency in my case?
>> *And another question, can MatSolve() in KSPSolve be multithreaded? Would
>> MUMPS help?*
>> Thank you and regards,
>> Yongzhong
>> *From:* Junchao Zhang <junchao.zhang at gmail.com>
>> *Sent:* Thursday, June 27, 2024 11:10 AM
>> *To:* Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>> *Cc:* Barry Smith <bsmith at petsc.dev>; petsc-users at mcs.anl.gov
>> *Subject:* Re: [petsc-users] [petsc-maint] Assistance Needed with PETSc
>> How big is the n when you call PetscCallBLAS("BLASgemv", BLASgemv_(trans,
>> &n, &m, &one, yarray, &lda2, xarray, &ione, &zero, z + i, &ione))? n is
>> the vector length in VecMDot.
>> it is strange with MKL_VERBOSE=1 you did not see MKL_VERBOSE *ZGEMV..., *since
>> the code did call gemv. Perhaps you need to double check your spelling etc.
>> If you also use ex2k, and potentially modify Ms[] and Ns[] to match the
>> sizes in your code, to see if there is a speedup with more threads.
>> --Junchao Zhang
>> On Thu, Jun 27, 2024 at 9:39 AM Yongzhong Li <
>> yongzhong.li at mail.utoronto.ca> wrote:
>> Mostly 3, maximum 7, but definitely hit the point when m > 1, I can see
>> the PetscCallBLAS("BLASgemv", BLASgemv_(trans, &n, &m, &one, yarray, &lda2,
>> xarray, &ione, &zero, z + i, &ione)); is called multiple
>> ZjQcmQRYFpfptBannerStart
>> *This Message Is From an External Sender*
>> ZjQcmQRYFpfptBannerEnd
>> I can see the PetscCallBLAS("BLASgemv", BLASgemv_(trans, &n, &m, &one,
>> yarray, &lda2, xarray, &ione, &zero, z + i, &ione)); is called multiple
>> times
>> *From: *Barry Smith <bsmith at petsc.dev>
>> *Date: *Thursday, June 27, 2024 at 1:12 AM
>> *To: *Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>> *Subject: *Re: [petsc-users] [petsc-maint] Assistance Needed with PETSc
>> How big are the m's getting in your code?
>> On Jun 27, 2024, at 12:40 AM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>> wrote:
>> Hi Barry, I used gdb to debug my program, set a breakpoint to
>> VecMultiDot_Seq_GEMV function. I did see when I debug this function, it
>> will call BLAS (but not always, only if m > 1), as shown below. However, I
>> still didn’t see any MKL outputs even if I set MKLK_VERBOSE=1.
>> *(gdb) *
>> *550 PetscCall(VecRestoreArrayRead(yin[i], &yfirst));*
>> *(gdb) *
>> *553 m = j - i;*
>> *(gdb) *
>> *554 if (m > 1) {*
>> *(gdb) *
>> *555 PetscBLASInt ione = 1, lda2 = (PetscBLASInt)lda; // the
>> cast is safe since we've screened out those lda > PETSC_BLAS_INT_MAX above*
>> *(gdb) *
>> *556 PetscScalar one = 1, zero = 0;*
>> *(gdb) *
>> *558 PetscCallBLAS("BLASgemv", BLASgemv_(trans, &n, &m,
>> &one, yarray, &lda2, xarray, &ione, &zero, z + i, &ione));*
>> *(gdb) s*
>> *PetscMallocValidate (line=558, function=0x7ffff68a11a0 <__func__.18210>
>> "VecMultiDot_Seq_GEMV",*
>> * file=0x7ffff68a1078
>> "/gpfs/s4h/scratch/t/triverio/modelics/workplace/rebel/build_debug/external/petsc-3.21.0/src/vec/vec/impls/seq/dvec2.c")*
>> * at
>> /gpfs/s4h/scratch/t/triverio/modelics/workplace/rebel/build_debug/external/petsc-3.21.0/src/sys/memory/mtr.c:106*
>> *106 if (!TRdebug) return PETSC_SUCCESS;*
>> *(gdb) *
>> *154 }*
>> Am I not using MKL BLAS, is that why I didn’t see multithreading speed up
>> for KSPGMRESOrthog? What do you think could be the potential reasons? Is
>> there any silent mode that will possibly affect the MKL Verbose.
>> Thank you and best regards,
>> Yongzhong
>> *Date: *Wednesday, June 26, 2024 at 8:15 PM
>> if (m > 1) {
>> PetscBLASInt ione = 1, lda2 = (PetscBLASInt)lda; // the cast is
>> PetscCall(PetscLogFlops(PetscMax(m * (2.0 * n - 1), 0.0)));
>> The call to BLAS above is where it uses MKL.
>> On Jun 26, 2024, at 6:59 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>> wrote:
>> Hi Barry, I am looking into the source codes of VecMultiDot_Seq_GEMV
>> https://urldefense.us/v3/__https://petsc.org/release/src/vec/vec/impls/seq/dvec2.c.html*VecMDot_Seq__;Iw!!G_uCfscf7eWS!cw4NqFC1djrGs8b1mL87vRIl7UhAC-HTBFefyAgrI5AoRpxI-JFc1ejwiH0LcrfhGr0_nA_giCdoDZLyYbpe_wPb-7VN$
>> <https://urldefense.us/v3/__https://petsc.org/release/src/vec/vec/impls/seq/dvec2.c.html*VecMDot_Seq__;Iw!!G_uCfscf7eWS!ZshPGnAUymZ7rmZ8Cq0JR23FBhEioHOuAq-lFnn4iQn1bK8ioexLwIQVLSQNCfmBaWWExCcshZ6KphgTYR6kv18wg0MHEITtuVo$>
>> Can I ask which lines of codes suggest the use of intel mkl?
>> Thanks,
>> Yongzhong
>> *Date: *Wednesday, June 26, 2024 at 10:30 AM
>> In a debug version of PETSc run your application in a debugger and put
>> a break point in VecMultiDot_Seq_GEMV. Then next through the code from
>> that point to see what decision it makes about using dgemv() to see why it
>> is not getting into the Intel code.
>> On Jun 25, 2024, at 11:19 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>> Hi Junchao, thank you for your help for these benchmarking test!
>> I check out to petsc/main and did a few things to verify from my side,
>> 1. I ran the microbenchmark (vec/vec/tests/ex2k.c) test on my compute
>> node. The results are as follow,
>> $ MKL_NUM_THREADS=64 ./ex2k -n 15 -m 4
>> Vector(N) VecMDot-1 VecMDot-3 VecMDot-8 VecMDot-30 (us)
>> 128 14.5 1.2 1.8 5.2
>> 256 1.5 0.9 1.6 4.7
>> 512 2.7 2.8 6.1 13.2
>> 1024 4.0 4.0 9.3 16.4
>> 2048 7.4 7.3 11.3 39.3
>> 4096 14.2 13.9 19.1 93.4
>> 8192 28.8 26.3 25.4 31.3
>> 16384 54.1 25.8 26.7 33.8
>> 32768 109.8 25.7 24.2 56.0
>> 65536 220.2 24.4 26.5 89.0
>> 131072 424.1 31.5 36.1 149.6
>> 262144 898.1 37.1 53.9 286.1
>> 524288 1754.6 48.7 100.3 1122.2
>> 1048576 3645.8 86.5 347.9 2950.4
>> 2097152 7371.4 308.7 1440.6 6874.9
>> $ MKL_NUM_THREADS=1 ./ex2k -n 15 -m 4
>> 128 14.9 1.2 1.9 5.2
>> 256 1.5 1.0 1.7 4.7
>> 512 2.7 2.8 6.1 12.0
>> 1024 3.9 4.0 9.3 16.8
>> 2048 7.4 7.3 10.4 41.3
>> 4096 14.0 13.8 18.6 84.2
>> 8192 27.0 21.3 43.8 177.5
>> 16384 54.1 34.1 89.1 330.4
>> 32768 110.4 82.1 203.5 781.1
>> 65536 213.0 191.8 423.9 1696.4
>> 131072 428.7 360.2 934.0 4080.0
>> 262144 883.4 723.2 1745.6 10120.7
>> 524288 1817.5 1466.1 4751.4 23217.2
>> 1048576 3611.0 3796.5 11814.9 48687.7
>> 2097152 7401.9 10592.0 27543.2 106565.4
>> I can see the speed up brought by more MKL threads, and if I set
>> NKL_VERBOSE to 1, I can see something like
>> *MKL_VERBOSE
>> ZGEMV(C,262144,8,0x7ffd375d6470,0x2ac76e7fb010,262144,0x16d0f40,1,0x7ffd375d6480,0x16435d0,1)
>> 32.70us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:6 ca*From my understanding,
>> the VecMDot()/VecMAXPY() can benefit from more MKL threads in my compute
>> node and is using ZGEMV MKL BLAS.
>> However, when I ran my own program and set MKL_VERBOSE to 1, it is very
>> strange that I still can’t find any MKL outputs, though I can see from the
>> PETSc log that VecMDot and VecMAXPY() are called.
>> I am wondering are VecMDot and VecMAXPY in KSPGMRESOrthog optimized in a
>> way that is similar to ex2k test? Should I expect to see MKL outputs for
>> whatever linear system I solve with KSPGMRES? Does it relate to if it is
>> dense matrix or sparse matrix, although I am not really understand why
>> VecMDot/MAXPY() have something to do with dense matrix-vector
>> multiplication.
>> Thank you,
>> Yongzhong
>> *From: *Junchao Zhang <junchao.zhang at gmail.com>
>> *Date: *Tuesday, June 25, 2024 at 6:34 PM
>> *To: *Matthew Knepley <knepley at gmail.com>
>> *Cc: *Yongzhong Li <yongzhong.li at mail.utoronto.ca>, Pierre Jolivet <
>> pierre at joliv.et>, petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>> Hi, Yongzhong,
>> Since the two kernels of KSPGMRESOrthog are VecMDot and VecMAXPY, if
>> we can speed up the two with OpenMP threads, then we can speed up
>> KSPGMRESOrthog. We recently added an optimization to do VecMDot/MAXPY() in
>> dense matrix-vector multiplication (i.e., BLAS2 GEMV, with tall-and-skinny
>> matrices ). So with MKL_VERBOSE=1, you should see something like
>> "MKL_VERBOSE ZGEMV ..." in output. If not, could you try again with
>> petsc/main?
>> petsc has a microbenchmark (vec/vec/tests/ex2k.c) to test them. I ran
>> VecMDot with multithreaded oneMKL (via setting MKL_NUM_THREADS), it was
>> strange to see no speedup. I then configured petsc with openblas, I did
>> see better performance with more threads
>> $ OMP_PROC_BIND=spread OMP_NUM_THREADS=1 ./ex2k -n 15 -m 4
>> Vector(N) VecMDot-3 VecMDot-8 VecMDot-30 (us)
>> 128 2.0 2.5 6.1
>> 256 1.8 2.7 7.0
>> 512 2.1 3.1 8.6
>> 1024 2.7 4.0 12.3
>> 2048 3.8 6.3 28.0
>> 4096 6.1 10.6 42.4
>> 8192 10.9 21.8 79.5
>> 16384 21.2 39.4 149.6
>> 32768 45.9 75.7 224.6
>> 65536 142.2 215.8 732.1
>> 131072 169.1 233.2 1729.4
>> 262144 367.5 830.0 4159.2
>> 524288 999.2 1718.1 8538.5
>> 1048576 2113.5 4082.1 18274.8
>> 2097152 5392.6 10273.4 43273.4
>> $ OMP_PROC_BIND=spread OMP_NUM_THREADS=8 ./ex2k -n 15 -m 4
>> 128 2.0 2.5 6.0
>> 256 1.8 2.7 15.0
>> 512 2.1 9.0 16.6
>> 1024 2.6 8.7 16.1
>> 2048 7.7 10.3 20.5
>> 4096 9.9 11.4 25.9
>> 8192 14.5 22.1 39.6
>> 16384 25.1 27.8 67.8
>> 32768 44.7 95.7 91.5
>> 65536 82.1 156.8 165.1
>> 131072 194.0 335.1 341.5
>> 262144 388.5 380.8 612.9
>> 524288 1046.7 967.1 1653.3
>> 1048576 1997.4 2169.0 4034.4
>> 2097152 5502.9 5787.3 12608.1
>> The tall-and-skinny matrices in KSPGMRESOrthog vary in width. The
>> average speedup depends on components. So I suggest you run ex2k to see in
>> your environment whether oneMKL can speedup the kernels.
>> --Junchao Zhang
>> On Mon, Jun 24, 2024 at 11:35 AM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>> Let me run some examples on our end to see whether the code calls
>> expected functions.
>> --Junchao Zhang
>> On Mon, Jun 24, 2024 at 10:46 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>> On Mon, Jun 24, 2024 at 11: 21 AM Yongzhong Li <yongzhong. li@ mail.
>> utoronto. ca> wrote: Thank you Pierre for your information. Do we have a
>> conclusion for my original question about the parallelization efficiency
>> for different stages of
>> On Mon, Jun 24, 2024 at 11:21 AM Yongzhong Li <
>> Thank you Pierre for your information. Do we have a conclusion for my
>> original question about the parallelization efficiency for different stages
>> of KSP Solve? Do we need to do more testing to figure out the issues? Thank
>> you, Yongzhong From:
>> We have an extended discussion of this here:
>> https://urldefense.us/v3/__https://petsc.org/release/faq/*what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup__;Iw!!G_uCfscf7eWS!cw4NqFC1djrGs8b1mL87vRIl7UhAC-HTBFefyAgrI5AoRpxI-JFc1ejwiH0LcrfhGr0_nA_giCdoDZLyYbpe_5b-GJoq$
>> <https://urldefense.us/v3/__https://petsc.org/release/faq/*what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup__;Iw!!G_uCfscf7eWS!aQJpmm5W6l6FUiumnIPmkouzwzNUfx-Dyq04i1O2KS_InQGk6qjI7wUir0Hx6QEUQE2AMiJDsez3x4zRO7V_$>
>> The kinds of operations you are talking about (SpMV, VecDot, VecAXPY,
>> etc) are memory bandwidth limited. If there is no more bandwidth to be
>> marshalled on your board, then adding more processes does nothing at all.
>> This is why people were asking about how many "nodes" you are running on,
>> because that is the unit of memory bandwidth, not "cores" which make little
>> difference.
>> Thanks,
>> Matt
>> Thank you,
>> Yongzhong
>> *From: *Pierre Jolivet <pierre at joliv.et>
>> *Date: *Sunday, June 23, 2024 at 12:41 AM
>> On 23 Jun 2024, at 4:07 AM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>> Yeah, I ran my program again using -mat_view::ascii_info and set
>> MKL_VERBOSE to be 1, then I noticed the outputs suggested that the matrix
>> to be seqaijmkl type (I’ve attached a few as below)
>> --> Setting up matrix-vector products...
>> Mat Object: 1 MPI process
>> type: seqaijmkl
>> rows=16490, cols=35937
>> total: nonzeros=128496, allocated nonzeros=128496
>> total number of mallocs used during MatSetValues calls=0
>> not using I-node routines
>> type: seqaijmkl
>> --> Solving the system...
>> Excitation 1 of 1...
>> Iterative solve completed in 7435 ms.
>> CONVERGED: rtol.
>> Iterations: 72
>> Final relative residual norm: 9.22287e-07
>> [CPU TIME] System solution: 2.27160000e+02 s.
>> [WALL TIME] System solution: 7.44387218e+00 s.
>> However, it seems to me that there were still no MKL outputs even I set
>> MKL_VERBOSE to be 1. Although, I think it should be many spmv operations
>> when doing KSPSolve(). Do you see the possible reasons?
>> SPMV are not reported with MKL_VERBOSE (last I checked), only dense BLAS
>> is.
>> Thanks,
>> Pierre
>> Thanks,
>> Yongzhong
>> *From: *Matthew Knepley <knepley at gmail.com>
>> *Date: *Saturday, June 22, 2024 at 5:56 PM
>> *Cc: *Junchao Zhang <junchao.zhang at gmail.com>, Pierre Jolivet <
>> 你通常不会收到来自 knepley at gmail.com 的电子邮件。了解这一点为什么很重要
>> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!fVvbGldqcUV5ju4jpu5oGmt-VjITi5JpCJzhHxpbgsERLVYZzglpxKOOyrBRGxjRxp7vWHwt3SnINFOQErR1Z8kcDcf3qwbYRxM$>
>> On Sat, Jun 22, 2024 at 5:03 PM Yongzhong Li <
>> MKL_VERBOSE=1 ./ex1 matrix nonzeros = 100, allocated nonzeros = 100
>> MKL_VERBOSE Intel(R) MKL 2019. 0 Update 4 Product build 20190411 for
>> Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 512 (Intel(R)
>> AVX-512) with support of Vector
>> MKL_VERBOSE=1 ./ex1
>> MKL_VERBOSE Intel(R) MKL 2019.0 Update 4 Product build 20190411 for
>> AVX-512) with support of Vector Neural Network Instructions enabled
>> processors, Lnx 2.50GHz lp64 gnu_thread
>> MKL_VERBOSE
>> ZGEMV(N,10,10,0x7ffd9d7078f0,0x187eb20,10,0x187f7c0,1,0x7ffd9d707900,0x187ff70,1)
>> 167.34ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x7ffd9d7078c0,-1,0)
>> 77.19ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x1894490,10,0) 83.97ms
>> MKL_VERBOSE ZSYTRS(L,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 44.94ms
>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 20.72us
>> MKL_VERBOSE ZSYTRS(L,10,2,0x1894b50,10,0x1893df0,0x187d2a0,10,0) 4.22us
>> MKL_VERBOSE
>> ZGEMM(N,N,10,2,10,0x7ffd9d707790,0x187eb20,10,0x187d2a0,10,0x7ffd9d7077a0,0x1896a70,10)
>> 1.41ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE ZAXPY(20,0x7ffd9d7078a0,0x1896a70,1,0x187b650,1) 381ns
>> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x7ffd9d707840,-1,0) 742ns
>> MKL_VERBOSE ZSYTRF(L,10,0x1894b50,10,0x1893df0,0x18951a0,10,0) 4.20us
>> MKL_VERBOSE ZSYTRS(L,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 2.94us
>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 292ns
>> MKL_VERBOSE
>> 1.17us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE ZGETRF(10,10,0x1894b50,10,0x1893df0,0) 202.48ms CNR:OFF Dyn:1
>> MKL_VERBOSE ZGETRS(N,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 20.78ms
>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 954ns
>> MKL_VERBOSE ZGETRS(N,10,2,0x1894b50,10,0x1893df0,0x187d2a0,10,0) 30.74ms
>> MKL_VERBOSE
>> ZGEMM(N,N,10,2,10,0x7ffd9d707790,0x187eb20,10,0x187d2a0,10,0x7ffd9d7077a0,0x18969c0,10)
>> 3.95us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE ZAXPY(20,0x7ffd9d7078a0,0x18969c0,1,0x187b650,1) 995ns
>> MKL_VERBOSE ZGETRF(10,10,0x1894b50,10,0x1893df0,0) 4.09us CNR:OFF Dyn:1
>> MKL_VERBOSE ZGETRS(N,10,1,0x1894b50,10,0x1893df0,0x1880720,10,0) 3.92us
>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187f7c0,1,0x1880720,1) 274ns
>> MKL_VERBOSE
>> ZGEMV(N,15,10,0x7ffd9d7078f0,0x187ec70,15,0x187fc30,1,0x7ffd9d707900,0x1880400,1)
>> 1.59us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x1894550,0x7ffd9d707900,-1,0)
>> 47.07us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x1894550,0x1895cb0,10,0) 26.62us
>> MKL_VERBOSE
>> ZUNMQR(L,C,15,1,10,0x1894b40,15,0x1894550,0x1895b00,15,0x7ffd9d7078b0,-1,0)
>> 35.32us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE
>> ZUNMQR(L,C,15,1,10,0x1894b40,15,0x1894550,0x1895b00,15,0x1895cb0,10,0)
>> 42.33ms CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE ZTRTRS(U,N,N,10,1,0x1894b40,15,0x1895b00,15,0) 16.11us
>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187fc30,1,0x1880c70,1) 395ns
>> MKL_VERBOSE
>> ZGEMM(N,N,15,2,10,0x7ffd9d707790,0x187ec70,15,0x187d310,10,0x7ffd9d7077a0,0x187b5b0,15)
>> 3.22us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE
>> ZUNMQR(L,C,15,2,10,0x1894b40,15,0x1894550,0x1897760,15,0x7ffd9d7078c0,-1,0)
>> 730ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE
>> ZUNMQR(L,C,15,2,10,0x1894b40,15,0x1894550,0x1897760,15,0x1895cb0,10,0)
>> 4.42us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE ZTRTRS(U,N,N,10,2,0x1894b40,15,0x1897760,15,0) 5.96us CNR:OFF
>> MKL_VERBOSE ZAXPY(20,0x7ffd9d7078a0,0x187d310,1,0x1897610,1) 222ns
>> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x18954b0,0x7ffd9d707820,-1,0)
>> 685ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE ZGEQRF(15,10,0x1894b40,15,0x18954b0,0x1895d60,10,0) 6.11us
>> MKL_VERBOSE
>> ZUNMQR(L,C,15,1,10,0x1894b40,15,0x18954b0,0x1895bb0,15,0x7ffd9d7078b0,-1,0)
>> 390ns CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE
>> ZUNMQR(L,C,15,1,10,0x1894b40,15,0x18954b0,0x1895bb0,15,0x1895d60,10,0)
>> 3.09us CNR:OFF Dyn:1 FastMM:1 TID:0 NThr:1
>> MKL_VERBOSE ZTRTRS(U,N,N,10,1,0x1894b40,15,0x1895bb0,15,0) 1.05us CNR:OFF
>> MKL_VERBOSE ZAXPY(10,0x7ffd9d7078f0,0x187fc30,1,0x1880c70,1) 257ns
>> Yes, for petsc example, there are MKL outputs, but for my own program.
>> All I did is to change the matrix type from MATAIJ to MATAIJMKL to get
>> optimized performance for spmv from MKL. Should I expect to see any MKL
>> outputs in this case?
>> Are you sure that the type changed? You can MatView() the matrix with
>> format ascii_info to see.
>> Thanks,
>> Matt
>> Thanks,
>> Yongzhong
>> *Date: *Saturday, June 22, 2024 at 9:40 AM
>> *Cc: *Pierre Jolivet <pierre at joliv.et>, petsc-users at mcs.anl.gov <
>> No, you don't. It is strange. Perhaps you can you run a petsc example
>> first and see if MKL is really used
>> $ cd src/mat/tests
>> $ make ex1
>> $ MKL_VERBOSE=1 ./ex1
>> --Junchao Zhang
>> On Fri, Jun 21, 2024 at 4:03 PM Yongzhong Li <
>> I am using
>> export MKL_VERBOSE=1
>> ./xx
>> in the bash file, do I have to use - ksp_converged_reason?
>> Thanks,
>> Yongzhong
>> *Date: *Friday, June 21, 2024 at 1:47 PM
>> *Cc: *Junchao Zhang <junchao.zhang at gmail.com>, petsc-users at mcs.anl.gov <
>> 你通常不会收到来自 pierre at joliv.et 的电子邮件。了解这一点为什么很重要
>> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!flsZMI97ne0yyxHhLda3hROB9qsgstuZS-jPinxGIzFCCSdn1ujdoMR8dyz-5_kVqqMM-12Lt0dTdjKrx3wXhHZmBhNydvFQeSY$>
>> How do you set the variable?
>> $ MKL_VERBOSE=1 ./ex1 -ksp_converged_reason
>> MKL_VERBOSE oneMKL 2024.0 Update 1 Product build 20240215 for Intel(R) 64
>> architecture Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2) enabled
>> processors, Lnx 2.80GHz lp64 intel_thread
>> MKL_VERBOSE DDOT(10,0x22127c0,1,0x22127c0,1) 2.02ms CNR:OFF Dyn:1
>> MKL_VERBOSE DSCAL(10,0x7ffc9fb4ff08,0x22127c0,1) 12.67us CNR:OFF Dyn:1
>> MKL_VERBOSE DDOT(10,0x22127c0,1,0x2212840,1) 1.52us CNR:OFF Dyn:1
>> MKL_VERBOSE DDOT(10,0x2212840,1,0x2212840,1) 167ns CNR:OFF Dyn:1 FastMM:1
>> TID:0 NThr:1
>> On 21 Jun 2024, at 7:37 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>> Hello all,
>> I set MKL_VERBOSE = 1, but observed no print output specific to the use
>> of MKL. Does PETSc enable this verbose output?
>> Best,
>> Yongzhong
>> *Date: *Friday, June 21, 2024 at 1:36 AM
>> *To: *Junchao Zhang <junchao.zhang at gmail.com>
>> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!eXBeeIXo9Yqgp2nypqwKYimLnGBZXnF4dXxgLM1UoOIO6n8nt3XlfgjVWLPWJh4UOa5NNpx-nrJb_H828XRQKUREfR2m69oCbxI$>
>> On 21 Jun 2024, at 6:42 AM, Junchao Zhang <junchao.zhang at gmail.com>
>> I remember there are some MKL env vars to print MKL routines called.
>> The environment variable is MKL_VERBOSE
>> Thanks,
>> Pierre
>> Maybe we can try it to see what MKL routines are really used and then we
>> can understand why some petsc functions did not speed up
>> --Junchao Zhang
>> On Thu, Jun 20, 2024 at 10:39 PM Yongzhong Li <
>> Hi Barry, sorry for my last results. I didn’t fully understand the stage
>> profiling and logging in PETSc, now I only record KSPSolve() stage of my
>> program. Some sample codes are as follow,
>> // Static variable to keep track of the stage counter
>> static int stageCounter = 1;
>> // Generate a unique stage name
>> std::ostringstream oss;
>> oss << "Stage " << stageCounter << " of Code";
>> std::string stageName = oss.str();
>> // Register the stage
>> PetscLogStage stagenum;
>> PetscLogStageRegister(stageName.c_str(), &stagenum);
>> PetscLogStagePush(stagenum);
>> *KSPSolve(*ksp_ptr, b, x);*
>> PetscLogStagePop();
>> stageCounter++;
>> I have attached my new logging results, there are 1 main stage and 4
>> other stages where each one is KSPSolve() call.
>> To provide some additional backgrounds, if you recall, I have been trying
>> to get efficient iterative solution using multithreading. I found out by
>> compiling PETSc with Intel MKL library instead of OpenBLAS, I am able to
>> perform sparse matrix-vector multiplication faster, I am using
>> MATSEQAIJMKL. This makes the shell matrix vector product in each iteration
>> scale well with the #of threads. However, I found out the total GMERS solve
>> time (~KSPSolve() time) is not scaling well the #of threads.
>> From the logging results I learned that when performing KSPSolve(), there
>> are some CPU overheads in PCApply() and KSPGMERSOrthog(). I ran my programs
>> using different number of threads and plotted the time consumption for
>> PCApply() and KSPGMERSOrthog() against #of thread. I found out these two
>> operations are not scaling with the threads at all! My results are attached
>> as the pdf to give you a clear view.
>> My questions is,
>> From my understanding, in PCApply, MatSolve() is involved,
>> KSPGMERSOrthog() will have many vector operations, so why these two parts
>> can’t scale well with the # of threads when the intel MKL library is linked?
>> Thank you,
>> Yongzhong
>> *Date: *Friday, June 14, 2024 at 11:36 AM
>> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>,
>> petsc-maint at mcs.anl.gov <petsc-maint at mcs.anl.gov>, Piero Triverio <
>> piero.triverio at utoronto.ca>
>> *Subject: *Re: [petsc-maint] Assistance Needed with PETSc KSPSolve
>> Performance Issue
>> I am a bit confused. Without the initial guess computation, there are
>> still a bunch of events I don't understand
>> MatTranspose 79 1.0 4.0598e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatMatMultSym 110 1.0 1.7419e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
>> MatMatMultNum 90 1.0 1.2640e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatMatMatMultSym 20 1.0 1.3049e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatRARtSym 25 1.0 1.2492e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatMatTrnMultSym 25 1.0 8.8265e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatMatTrnMultNum 25 1.0 2.4820e+02 1.0 6.83e+10 1.0 0.0e+00 0.0e+00
>> 0.0e+00 1 0 0 0 0 1 0 0 0 0 275
>> MatTrnMatMultSym 10 1.0 7.2984e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatTrnMatMultNum 10 1.0 9.3128e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> in addition there are many more VecMAXPY then VecMDot (in GMRES they are
>> each done the same number of times)
>> VecMDot 5588 1.0 1.7183e+03 1.0 2.06e+13 1.0 0.0e+00 0.0e+00
>> 0.0e+00 8 10 0 0 0 8 10 0 0 0 12016
>> VecMAXPY 22412 1.0 8.4898e+03 1.0 4.17e+13 1.0 0.0e+00 0.0e+00
>> 0.0e+00 39 20 0 0 0 39 20 0 0 0 4913
>> Finally there are a huge number of
>> MatMultAdd 258048 1.0 1.4178e+03 1.0 6.10e+13 1.0 0.0e+00 0.0e+00
>> 0.0e+00 7 29 0 0 0 7 29 0 0 0 43025
>> Are you making calls to all these routines? Are you doing this inside
>> your MatMult() or before you call KSPSolve?
>> The reason I wanted you to make a simpler run without the initial guess
>> code is that your events are far more complicated than would be produced by
>> GMRES alone so it is not possible to understand the behavior you are seeing
>> without fully understanding all the events happening in the code.
>> Barry
>> On Jun 14, 2024, at 1:19 AM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>> wrote:
>> Thanks, I have attached the results without using any KSPGuess. At low
>> frequency, the iteration steps are quite close to the one with KSPGuess,
>> specifically
>> KSPGuess Object: 1 MPI process
>> type: fischer
>> Model 1, size 200
>> However, I found at higher frequency, the # of iteration steps are
>> significant higher than the one with KSPGuess, I have attahced both of the
>> results for your reference.
>> Moreover, could I ask why the one without the KSPGuess options can be
>> used for a baseline comparsion? What are we comparing here? How does it
>> relate to the performance issue/bottleneck I found? “*I have noticed
>> that the time taken by **KSPSolve** is **almost two times **greater than
>> the CPU time for matrix-vector product multiplied by the number of
>> iteration*”
>> Thank you!
>> Yongzhong
>> *Date: *Thursday, June 13, 2024 at 2:14 PM
>> Performance Issue
>> Can you please run the same thing without the KSPGuess option(s) for a
>> baseline comparison?
>> Thanks
>> Barry
>> On Jun 13, 2024, at 1:27 PM, Yongzhong Li <yongzhong.li at mail.utoronto.ca>
>> Hi Matt,
>> I have rerun the program with the keys you provided. The system output
>> when performing ksp solve and the final petsc log output were stored in a
>> .txt file attached for your reference.
>> Thanks!
>> Yongzhong
>> *Date: *Wednesday, June 12, 2024 at 6:46 PM
>> Performance Issue
>> <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!djGfJnEhNJROfsMsBJy5u_KoRKbug55xZ64oHKUFnH2cWku_Th1hwt4TDdoMd8pWYVDzJeqJslMNZwpO3y0Et94d31qk-oCEwo4$>
>> On Wed, Jun 12, 2024 at 6:36 PM Yongzhong Li <
>> Dear PETSc’s developers, I hope this email finds you well. I am currently
>> working on a project using PETSc and have encountered a performance issue
>> with the KSPSolve function. Specifically, I have noticed that the time
>> taken by KSPSolve is
>> I am currently working on a project using PETSc and have encountered a
>> performance issue with the KSPSolve function. Specifically, *I have
>> noticed that the time taken by **KSPSolve** is **almost two times **greater
>> than the CPU time for matrix-vector product multiplied by the number of
>> iteration steps*. I use C++ chrono to record CPU time.
>> For context, I am using a shell system matrix A. Despite my efforts to
>> parallelize the matrix-vector product (Ax), the overall solve time
>> remains higher than the matrix vector product per iteration indicates
>> when multiple threads were used. Here are a few details of my setup:
>> - *Matrix Type*: Shell system matrix
>> - *Preconditioner*: Shell PC
>> - *Parallel Environment*: Using Intel MKL as PETSc’s BLAS/LAPACK
>> library, multithreading is enabled
>> I have considered several potential reasons, such as preconditioner
>> setup, additional solver operations, and the inherent overhead of using a
>> shell system matrix. *However, since KSPSolve is a high-level API, I
>> have been unable to pinpoint the exact cause of the increased solve time.*
>> Have you observed the same issue? Could you please provide some
>> experience on how to diagnose and address this performance discrepancy?
>> Any insights or recommendations you could offer would be greatly
>> appreciated.
>> For any performance question like this, we need to see the output of your
>> code run with
>> -ksp_view -ksp_monitor_true_residual -ksp_converged_reason -log_view
>> Thanks,
>> Matt
>> Thank you for your time and assistance.
>> Best regards,
>> Yongzhong
>> *Yongzhong Li*
>> PhD student | Electromagnetics Group
>> Department of Electrical & Computer Engineering
>> University of Toronto
>> https://urldefense.us/v3/__http://www.modelics.org__;!!G_uCfscf7eWS!cw4NqFC1djrGs8b1mL87vRIl7UhAC-HTBFefyAgrI5AoRpxI-JFc1ejwiH0LcrfhGr0_nA_giCdoDZLyYbpe_92mZO9M$
>> <https://urldefense.us/v3/__http://www.modelics.org__;!!G_uCfscf7eWS!cuLttMJEcegaqu461Bt4QLsO4fASfLM5vjRbtyNhWJQiInbjgNwkGNdkFE1ebSbFjOUatYB0-jd2yQWMWzqkDFFjwMvNl3ZKAr8$>
>> experiments lead.
>> -- Norbert Wiener
>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cw4NqFC1djrGs8b1mL87vRIl7UhAC-HTBFefyAgrI5AoRpxI-JFc1ejwiH0LcrfhGr0_nA_giCdoDZLyYbpe_xKEEYRn$
>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!djGfJnEhNJROfsMsBJy5u_KoRKbug55xZ64oHKUFnH2cWku_Th1hwt4TDdoMd8pWYVDzJeqJslMNZwpO3y0Et94d31qkNOuenGA$>
>> <ksp_petsc_log.txt>
>> <ksp_petsc_log.txt><ksp_petsc_log_noguess.txt>
>> experiments lead.
>> -- Norbert Wiener
>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fVvbGldqcUV5ju4jpu5oGmt-VjITi5JpCJzhHxpbgsERLVYZzglpxKOOyrBRGxjRxp7vWHwt3SnINFOQErR1Z8kcDcf3cNeD9Gw$>
>> experiments lead.
>> -- Norbert Wiener
>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!aQJpmm5W6l6FUiumnIPmkouzwzNUfx-Dyq04i1O2KS_InQGk6qjI7wUir0Hx6QEUQE2AMiJDsez3x2Os2C2d$>
>> <petsc_log_comparison.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240628/7ef4aa71/attachment-0001.html>
