[petsc-users] Weird handling of compiler flags by the build system
    Barry Smith
    bsmith at petsc.dev
    Mon Jul  1 11:37:36 CDT 2024
   I have added two MR to hopefully improve PETSc usability based on your issues
https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7663__;!!G_uCfscf7eWS!efrDwkgUkc276It23vyi4kUxZ3ieab1AgseqAOCvE-K9-nLNjd6aad4rmdaRExARms_zfeExsNtm5lRx_b5ezSM$
Add information to template Makefile.user indicating what parts can easily be... (!7663) · Merge requests · PETSc / petsc · GitLab
gitlab.com
to clarify in Makefile.User how to remove the PETSc build compiler flags and
https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7662__;!!G_uCfscf7eWS!efrDwkgUkc276It23vyi4kUxZ3ieab1AgseqAOCvE-K9-nLNjd6aad4rmdaRExARms_zfeExsNtm5lRxbVNm9-g$
Additional documentation in configure for CFLAGS and friends (!7662) · Merge requests · PETSc / petsc · GitLab
gitlab.com
additional clarification in the docs for CFLAGS and friends and how they work
Barry
> On Jul 1, 2024, at 12:08 PM, meator <meator.dev at gmail.com> wrote:
> On 7/1/24 5:23 PM, Stefano Zampini wrote:
>>    This is unfortunate. I assume that patching the buildsystem or some
>>    other trickery will be necessary if what you're saying is true.
>> I admit it is not so standard, but Satish always opposed this.
>> No need to hack the buildsystem, just use COPTFLAGS, CXXOPTFLAGS and FOPTFLAGS
> I will try using *OPTFLAGS, thanks!
>> I don't think you should use Makefile.user. That is there as a sort of template/placeholder. The extra variables are not included in a standard usage of pkgconfig, so I don't think this issue is "severe"
> This is not a choice I get to make. The users of my package may choose to use PETSc however they want. And /usr/share/petsc/Makefile.user or /usr/share/petsc/CMakeLists.txt are officially supported ways of using PETSc, so deciding to ignore these use cases and leaving junk flags in /usr/lib/pkgconfig/petsc.pc is not tolerable for me.
> <OpenPGP_0x1A14CB3464CBE5BF.asc>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240701/e46fee27/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240701/e46fee27/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240701/e46fee27/attachment-0003.png>
