[petsc-users] Weird handling of compiler flags by the build system resolved
    meator
    meator.dev at gmail.com
    Mon Jul  1 14:09:57 CDT 2024
On 7/1/24 6:22 PM, Satish Balay wrote:
> And for your desired use case: "I need to specify flags to PETSc build - and they should not bleed to dependent pkgs" I've indicated one mode for this.
> i.e - do not specify them with configure - only list them with make.
> ./configure
> make CFLAGS='only-for-petsc-library-build'
Thank you for your answers! A combination of this approach and the
*OPTFLAGS approach mentioned before allowed me to pass all the relevant
flags while building PETSc without overriding preset ones and without
polluting the pkg-config file. PETSc build flags will now not bleed to
dependent pkgs.
I was also not aware of some of the flags which you have mentioned
(--with-visibility, --with-pic). I have now made use of these.
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240701/cb904dcd/attachment.bin>
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240701/cb904dcd/attachment.sig>
