[petsc-users] pc_redistribute issue
Mark Adams
mfadams at lbl.gov
Sat Jan 27 10:44:13 CST 2024
KSP Object: (redistribute_) 1 MPI process
type: gmres
restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization
with no iterative refinement
happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
* tolerances: relative=1e-12, absolute=1e-50, divergence=10000.* left
preconditioning
using PRECONDITIONED norm type for convergence test
PC Object: (redistribute_) 1 MPI process
type: bjacobi
number of blocks = 1
Local solver information for first block is in the following KSP and PC
objects on rank 0:
Use -redistribute_ksp_view ::ascii_info_detail to display information
for all blocks
KSP Object: (redistribute_sub_) 1 MPI process
type: preonly
tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
left preconditioning
using NONE norm type for convergence test
PC Object: (redistribute_sub_) 1 MPI process
type: lu
out-of-place factorization
tolerance for zero pivot 2.22045e-14
On Sat, Jan 27, 2024 at 10:24 AM Matthew Knepley <knepley at gmail.com> wrote:
> View the solver.
> Matt
> On Sat, Jan 27, 2024 at 9:43 AM Mark Adams <mfadams at lbl.gov> wrote:
>> I am not getting ksp_rtol 1e-12 into pc_redistribute correctly?
>> * Linear redistribute_ solve converged due to CONVERGED_RTOL iterations
>> 1 0 KSP Residual norm 2.182384017537e+02 1 KSP Residual norm
>> 1.889764161573e-04 *
>> Number of iterations = 1 N = 47628
>> Residual norm 8.65917e-07
>> #PETSc Option Table entries:
>> -f S.bin # (source: command line)
>> -ksp_monitor # (source: command line)
>> -ksp_type preonly # (source: command line)
>> -mat_block_size 36 # (source: command line)
>> -mat_view ascii::ascii_info # (source: command line)
>> -options_left # (source: command line)
>> -pc_type redistribute # (source: command line)
>> -redistribute_ksp_converged_reason # (source: command line)
>> *-redistribute_ksp_rtol 1e-12 # (source: command line)*-redistribute_ksp_type
>> gmres # (source: command line)
>> -redistribute_pc_type bjacobi # (source: command line)
>> -redistribute_sub_pc_factor_mat_solver_type mumps # (source: command line)
>> -redistribute_sub_pc_type lu # (source: command line)
>> #End of PETSc Option Table entries
>> *There are no unused options.*
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240127/15b5dc80/attachment.html>
