[petsc-users] pc_redistribute issue
Matthew Knepley
knepley at gmail.com
Sat Jan 27 09:24:22 CST 2024
View the solver.
Matt
On Sat, Jan 27, 2024 at 9:43 AM Mark Adams <mfadams at lbl.gov> wrote:
> I am not getting ksp_rtol 1e-12 into pc_redistribute correctly?
> * Linear redistribute_ solve converged due to CONVERGED_RTOL iterations 1
> 0 KSP Residual norm 2.182384017537e+02 1 KSP Residual norm
> 1.889764161573e-04 *
> Number of iterations = 1 N = 47628
> Residual norm 8.65917e-07
> #PETSc Option Table entries:
> -f S.bin # (source: command line)
> -ksp_monitor # (source: command line)
> -ksp_type preonly # (source: command line)
> -mat_block_size 36 # (source: command line)
> -mat_view ascii::ascii_info # (source: command line)
> -options_left # (source: command line)
> -pc_type redistribute # (source: command line)
> -redistribute_ksp_converged_reason # (source: command line)
> *-redistribute_ksp_rtol 1e-12 # (source: command line)*-redistribute_ksp_type
> gmres # (source: command line)
> -redistribute_pc_type bjacobi # (source: command line)
> -redistribute_sub_pc_factor_mat_solver_type mumps # (source: command line)
> -redistribute_sub_pc_type lu # (source: command line)
> #End of PETSc Option Table entries
> *There are no unused options.*
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240127/b3229d1d/attachment.html>
