[petsc-users] pc_redistribute issue
Matthew Knepley
knepley at gmail.com
Sat Jan 27 11:51:42 CST 2024
Okay, so the tolerance is right. It must be using ||b|| instead of ||r0||.
Run with
-redistribute_ksp_monitor_true_residual
You might have to force r0.
Matt
On Sat, Jan 27, 2024 at 11:44 AM Mark Adams <mfadams at lbl.gov> wrote:
> KSP Object: (redistribute_) 1 MPI process
> type: gmres
> restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> * tolerances: relative=1e-12, absolute=1e-50, divergence=10000.* left
> preconditioning
> using PRECONDITIONED norm type for convergence test
> PC Object: (redistribute_) 1 MPI process
> type: bjacobi
> number of blocks = 1
> Local solver information for first block is in the following KSP and
> PC objects on rank 0:
> Use -redistribute_ksp_view ::ascii_info_detail to display information
> for all blocks
> KSP Object: (redistribute_sub_) 1 MPI process
> type: preonly
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> left preconditioning
> using NONE norm type for convergence test
> PC Object: (redistribute_sub_) 1 MPI process
> type: lu
> out-of-place factorization
> tolerance for zero pivot 2.22045e-14
> On Sat, Jan 27, 2024 at 10:24 AM Matthew Knepley <knepley at gmail.com>
> wrote:
>> View the solver.
>> Matt
>> On Sat, Jan 27, 2024 at 9:43 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> I am not getting ksp_rtol 1e-12 into pc_redistribute correctly?
>>> * Linear redistribute_ solve converged due to CONVERGED_RTOL iterations
>>> 1 0 KSP Residual norm 2.182384017537e+02 1 KSP Residual norm
>>> 1.889764161573e-04 *
>>> Number of iterations = 1 N = 47628
>>> Residual norm 8.65917e-07
>>> #PETSc Option Table entries:
>>> -f S.bin # (source: command line)
>>> -ksp_monitor # (source: command line)
>>> -ksp_type preonly # (source: command line)
>>> -mat_block_size 36 # (source: command line)
>>> -mat_view ascii::ascii_info # (source: command line)
>>> -options_left # (source: command line)
>>> -pc_type redistribute # (source: command line)
>>> -redistribute_ksp_converged_reason # (source: command line)
>>> *-redistribute_ksp_rtol 1e-12 # (source: command line)*-redistribute_ksp_type
>>> gmres # (source: command line)
>>> -redistribute_pc_type bjacobi # (source: command line)
>>> -redistribute_sub_pc_factor_mat_solver_type mumps # (source: command
>>> line)
>>> -redistribute_sub_pc_type lu # (source: command line)
>>> #End of PETSc Option Table entries
>>> *There are no unused options.*
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240127/916c4493/attachment-0001.html>
