[petsc-users] VecScatter() causing processes hanging
Barry Smith
bsmith at petsc.dev
Sun Dec 8 16:00:18 CST 2024
Where does global_vec come from, and are you sure that all MPI processes that share global_vec enter this code region?
> On Dec 8, 2024, at 4:52 PM, Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> Thank you all for the reply. Here is the code. Since I need to fetch data from the local_vec, so I set the type as VECSEQ, so I can use VecGetValues().
> std::vector<std::vector<double>> vc(numNodesSurface, std::vector<double>(numDimsProb)); // 2-D matrix storing velocity u, v.
> PetscScalar *ptr_vc = NULL; // memory storing the fetched values
> ptr_vc = new double[numNodesSurface*numDimsProb]; // numNodesSurfac = 6, numDimsProb = 2, are number of nodes per element and problem dimension
> PetscInt idx_global[numNodesSurface*numDimsProb]; // for creating global Index Set
> PetscInt idx_local[numNodesSurface*numDimsProb]; // for creating local Index Set
> for (int i = 0; i < numNodesSurface; i++){
> for (int j = 0; j < numDimsProb; j++){
> idx_local[i*numDimsProb + j] = i*numDimsProb + j; // local index
> idx_global[i*numDimsProb + j] = node_el[i]*numDOFs + j; // global index
> // global_vec is distributed, and uses MPI_COMM_WORLD as a communicator which includes all processes.
> // I want to fetch 12 (numNodesSurface*numDimsProb) values from global_vec and put them in a local vector,
> // Therefore, I set up this local_vec as VECSEQ and using PETSC_COMM_SELF.
> IS is_source, is_dest;
> ISCreateGeneral(PETSC_COMM_SELF, numNodesSurface*numDimsProb, idx_global, PETSC_COPY_VALUES, &is_source);
> ISCreateGeneral(PETSC_COMM_SELF, numNodesSurface*numDimsProb, idx_local, PETSC_COPY_VALUES, &is_dest);
> Vec local_vec;
> VecCreate(PETSC_COMM_SELF, &local_vec);
> VecSetSizes(local_vec, PETSC_DECIDE, numNodesSurface*numDimsProb);
> VecSetType(local_vec, VECSEQ);
> VecScatter scat;
> VecScatterCreate(global_vec, is_source, local_vec, is_dest, &scat); // Got Stuck here
> VecScatterBegin(scat, global_vec, local_vec, INSERT_VALUES, SCATTER_FORWARD);
> VecScatterEnd(scat, global_vec, local_vec, INSERT_VALUES, SCATTER_FORWARD);
> VecGetValues(local_vec, numNodesSurface*numDimsProb, idx_local, ptr_vc);
> vc[i][j] = ptr_vc[i*numDimsProb + j]; // From 1-D to 2-D
> ISDestroy(&is_source);
> ISDestroy(&is_dest);
> VecDestroy(&local_vec);
> VecScatterDestroy(&scat);
> On Sun, Dec 8, 2024 at 11:12 AM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>> You can scatter from a global vector to a local vector; numerous PETSc examples demonstrate this. So hanging here is surprising. Please display the entire code so we can see the context of the VecScatterCreate() usage. Perhaps not all the MPI process that are in the global_vec communicator are involved in the call to VecScatterCreate().
>> To determine where the hang occurs you can run with -start_in_debugger use c for continue in each debugger window and then after a long time of hanging do control d in the hanging windows and then type bt to see where the code is hanging.
>> Barry
>>> On Dec 7, 2024, at 9:47 PM, Qiyue Lu <qiyuelu1 at gmail.com <mailto:qiyuelu1 at gmail.com>> wrote:
>>> Hello,
>>> I am trying to fetch 12 entries from a distributed vector global_vec and put them into a local vector on each process.
>>> ISCreateGeneral(PETSC_COMM_SELF, 12, idx_global, PETSC_COPY_VALUES, &is_source);
>>> ISCreateGeneral(PETSC_COMM_SELF, 12, idx_local, PETSC_COPY_VALUES, &is_dest);
>>> Vec local_vec;
>>> VecSetSizes(local_vec, PETSC_DECIDE, 12);
>>> VecScatter scat;
>>> I create the local vector as sequential. However, the last two lines which create a scatter object, will cause more than half processes to hang and no error pops out.
>>> Does the scatter have to be VECMPI to VECMPI and cannot VECMPI to VECSEQ?
>>> Thanks,
>>> Qiyue Lu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241208/fc881fd3/attachment-0001.html>
