[petsc-users] VecScatter() causing processes hanging
Qiyue Lu
qiyuelu1 at gmail.com
Sun Dec 8 15:52:40 CST 2024
Thank you all for the reply. Here is the code. Since I need to fetch data
from the local_vec, so I set the type as VECSEQ, so I can use
VecGetValues().
std::vector<std::vector<double>> vc(numNodesSurface, std::vector<double
>(numDimsProb)); // 2-D matrix storing velocity u, v.
PetscScalar *ptr_vc = NULL; // memory storing the fetched values
ptr_vc = new double[numNodesSurface*numDimsProb]; // numNodesSurfac = 6,
numDimsProb = 2, are number of nodes per element and problem dimension
PetscInt idx_global[numNodesSurface*numDimsProb]; // for creating global
Index Set
PetscInt idx_local[numNodesSurface*numDimsProb]; // for creating local
Index Set
for (int i = 0; i < numNodesSurface; i++){
for (int j = 0; j < numDimsProb; j++){
idx_local[i*numDimsProb + j] = i*numDimsProb + j; // local index
idx_global[i*numDimsProb + j] = node_el[i]*numDOFs + j; // global index
// global_vec is distributed, and uses MPI_COMM_WORLD as a communicator
which includes all processes.
// I want to fetch 12 (numNodesSurface*numDimsProb) values from global_vec
and put them in a local vector,
// Therefore, I set up this local_vec as VECSEQ and using PETSC_COMM_SELF.
IS is_source, is_dest;
ISCreateGeneral(PETSC_COMM_SELF, numNodesSurface*numDimsProb, idx_global,
PETSC_COPY_VALUES, &is_source);
ISCreateGeneral(PETSC_COMM_SELF, numNodesSurface*numDimsProb, idx_local,
PETSC_COPY_VALUES, &is_dest);
Vec local_vec;
VecCreate(PETSC_COMM_SELF, &local_vec);
VecSetSizes(local_vec, PETSC_DECIDE, numNodesSurface*numDimsProb);
VecSetType(local_vec, VECSEQ);
VecScatter scat;
VecScatterCreate(global_vec, is_source, local_vec, is_dest, &scat); // Got
Stuck here
VecScatterBegin(scat, global_vec, local_vec, INSERT_VALUES,
SCATTER_FORWARD);
VecScatterEnd(scat, global_vec, local_vec, INSERT_VALUES, SCATTER_FORWARD);
VecGetValues(local_vec, numNodesSurface*numDimsProb, idx_local, ptr_vc);
vc[i][j] = ptr_vc[i*numDimsProb + j]; // From 1-D to 2-D
ISDestroy(&is_source);
ISDestroy(&is_dest);
VecDestroy(&local_vec);
VecScatterDestroy(&scat);
On Sun, Dec 8, 2024 at 11:12 AM Barry Smith <bsmith at petsc.dev> wrote:
> You can scatter from a global vector to a local vector; numerous PETSc
> examples demonstrate this. So hanging here is surprising. Please display
> the entire code so we can see the context of the VecScatterCreate() usage.
> Perhaps not all the MPI process that are in the global_vec communicator are
> involved in the call to VecScatterCreate().
> To determine where the hang occurs you can run with -start_in_debugger
> use c for continue in each debugger window and then after a long time of
> hanging do control d in the hanging windows and then type bt to see where
> the code is hanging.
> Barry
> On Dec 7, 2024, at 9:47 PM, Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> Hello,
> I am trying to fetch 12 entries from a distributed vector global_vec and
> put them into a local vector on each process.
> ISCreateGeneral(PETSC_COMM_SELF, 12, idx_global, PETSC_COPY_VALUES, &
> is_source);
> ISCreateGeneral(PETSC_COMM_SELF, 12, idx_local, PETSC_COPY_VALUES, &
> is_dest);
> Vec local_vec;
> VecSetSizes(local_vec, PETSC_DECIDE, 12);
> VecScatter scat;
> I create the local vector as sequential. However, the last two lines which
> create a scatter object, will cause more than half processes to hang and no
> error pops out.
> Does the scatter have to be VECMPI to VECMPI and cannot VECMPI to VECSEQ?
> Thanks,
> Qiyue Lu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241208/491bf07a/attachment.html>
