[petsc-users] VecScatter() causing processes hanging
Qiyue Lu qiyuelu1 at gmail.com
Sun Dec 8 16:40:53 CST 2024
Yes, it seems the global_vec has some problems. It is passed by as a
function parameter. And the original vector is declared as in the code.
However, I got some print-out as below, while I am expecting to get
evenly-distributed values.
process 0 has 5422 entries.
process 1 has 0 entries.
process 2 has 0 entries.
process 3 has 0 entries.
process 4 has 0 entries.
process 5 has 0 entries.
process 6 has 0 entries.
process 7 has 0 entries.
process 8 has 0 entries.
process 9 has 0 entries.
process 10 has 0 entries.
process 11 has 0 entries.
process 12 has 0 entries.
Vec sol_vector_rp1;
VecCreate(MPI_COMM_WORLD, &sol_vector_rp1);
VecSetType(sol_vector_rp1, VECMPI);
VecSetSizes(sol_vector_rp1, PETSC_DECIDE, numNodesTotal*numDOFs);
VecSet(sol_vector_rp1, 0.0);
VecAssemblyBegin(sol_vector_rp1);
VecAssemblyEnd(sol_vector_rp1);
int *vec_local_size = nullptr;
vec_local_size = new int[world_size];
VecGetLocalSize(sol_vector_rp1, vec_local_size);
for (int i = 0; i < world_size; i++){
std::cout << "process " << i << " has " << vec_local_size[i] << " entries."
<< std::endl;
On Sun, Dec 8, 2024 at 4:00 PM Barry Smith <bsmith at petsc.dev> wrote:
>    Where does global_vec come from, and are you sure that all MPI
> processes that share global_vec enter this code region?
> On Dec 8, 2024, at 4:52 PM, Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> Thank you all for the reply. Here is the code. Since I need to fetch data
> from the local_vec, so I set the type as VECSEQ, so I can use
> VecGetValues().
> std::vector<std::vector<double>> vc(numNodesSurface, std::vector<double
> >(numDimsProb)); // 2-D matrix storing velocity u, v.
> PetscScalar *ptr_vc = NULL; // memory storing the fetched values
> ptr_vc = new double[numNodesSurface*numDimsProb]; // numNodesSurfac = 6,
> numDimsProb = 2, are number of nodes per element and problem dimension
> PetscInt idx_global[numNodesSurface*numDimsProb]; // for creating global
> Index Set
> PetscInt idx_local[numNodesSurface*numDimsProb]; // for creating local
> Index Set
> for (int i = 0; i < numNodesSurface; i++){
> for (int j = 0; j < numDimsProb; j++){
> idx_local[i*numDimsProb + j] = i*numDimsProb + j; // local index
> idx_global[i*numDimsProb + j] = node_el[i]*numDOFs + j; // global index
> // global_vec is distributed, and uses MPI_COMM_WORLD as a communicator
> which includes all processes.
> // I want to fetch 12 (numNodesSurface*numDimsProb) values from global_vec
> and put them in a local vector,
> // Therefore, I set up this local_vec as VECSEQ and using PETSC_COMM_SELF.
> IS is_source, is_dest;
> ISCreateGeneral(PETSC_COMM_SELF, numNodesSurface*numDimsProb, idx_global,
> PETSC_COPY_VALUES, &is_source);
> ISCreateGeneral(PETSC_COMM_SELF, numNodesSurface*numDimsProb, idx_local,
> PETSC_COPY_VALUES, &is_dest);
> Vec local_vec;
> VecCreate(PETSC_COMM_SELF, &local_vec);
> VecSetSizes(local_vec, PETSC_DECIDE, numNodesSurface*numDimsProb);
> VecSetType(local_vec, VECSEQ);
> VecScatter scat;
> VecScatterCreate(global_vec, is_source, local_vec, is_dest, &scat); //
> Got Stuck here
> VecScatterBegin(scat, global_vec, local_vec, INSERT_VALUES,
> SCATTER_FORWARD);
> VecScatterEnd(scat, global_vec, local_vec, INSERT_VALUES,
> SCATTER_FORWARD);
> VecGetValues(local_vec, numNodesSurface*numDimsProb, idx_local, ptr_vc);
> vc[i][j] = ptr_vc[i*numDimsProb + j]; // From 1-D to 2-D
> ISDestroy(&is_source);
> ISDestroy(&is_dest);
> VecDestroy(&local_vec);
> VecScatterDestroy(&scat);
> On Sun, Dec 8, 2024 at 11:12 AM Barry Smith <bsmith at petsc.dev> wrote:
>>    You can scatter from a global vector to a local vector; numerous PETSc
>> examples demonstrate this. So hanging here is surprising. Please display
>> the entire code so we can see the context of the VecScatterCreate() usage.
>> Perhaps not all the MPI process that are in the global_vec communicator are
>> involved in the call to VecScatterCreate().
>>   To determine where the hang occurs you can run with -start_in_debugger
>> use c for continue in each debugger window and then after a long time of
>> hanging do control d in the hanging windows and then type bt to see where
>> the code is hanging.
>>   Barry
>> On Dec 7, 2024, at 9:47 PM, Qiyue Lu <qiyuelu1 at gmail.com> wrote:
>> Hello,
>> I am trying to fetch 12 entries from a distributed vector global_vec and
>> put them into a local vector on each process.
>> ISCreateGeneral(PETSC_COMM_SELF, 12, idx_global, PETSC_COPY_VALUES, &
>> is_source);
>> ISCreateGeneral(PETSC_COMM_SELF, 12, idx_local, PETSC_COPY_VALUES, &
>> is_dest);
>> Vec local_vec;
>> VecSetSizes(local_vec, PETSC_DECIDE, 12);
>> VecScatter scat;
>> I create the local vector as sequential. However, the last two lines
>> which create a scatter object, will cause more than half processes to hang
>> and no error pops out.
>> Does the scatter have to be VECMPI to VECMPI and cannot VECMPI to VECSEQ?
>> Thanks,
>> Qiyue Lu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241208/5fdf0d8f/attachment.html>
