[petsc-users] Error during code compile with MATGETOWNERSHIPRANGE
Barry Smith bsmith at petsc.dev
Thu Aug 22 09:28:24 CDT 2024
  Should be PetscReal as it is a numerical value.
> On Aug 22, 2024, at 9:55 AM, TAY Wee Beng <zonexo at gmail.com> wrote:
> On 22/8/2024 9:54 pm, Barry Smith wrote:
>>   What is int_impl(k,5) defined type?
> PetscInt
>>> On Aug 22, 2024, at 9:45 AM, TAY Wee Beng <zonexo at gmail.com> <mailto:zonexo at gmail.com> wrote:
>>> Hi Barry,
>>> Do you mean that I change from:
>>> call MatSetValues(A_mat_uv,ione,II,ione,int_impl(k,5),impl_mat_A,INSERT_VALUES,ierr)
>>> to
>>> call MatSetValues(A_mat_uv,[ione],II,[ione],[int_impl(k,5)],impl_mat_A,INSERT_VALUES,ierr)
>>> I did it but the error is still there.
>>> On 22/8/2024 9:40 pm, Barry Smith wrote:
>>>>    Fortran 90 type checking is very tight; The dimension of the array, or scalar passed as arguments must match the expected dimension (f77 did not do this type checking). Thus the ione argument must be a 1-d array as well as the numerical values so do
>>>> See Fortran at https://urldefense.us/v3/__https://petsc.org/main/changes/dev/__;!!G_uCfscf7eWS!dNBzWkhJd-4jZyaRlnKfwEu7GsbCs6Akjkgm66N2JkhV3BIi2VMXqj5uIxaLfxLiJiHd7B0-jQmrxJNpdLCb00A$
>>>> I am trying to support the old-fashion F77 model, allowing miss-matches in the array dimensions while still doing proper type checking but it will take some time to simplify the API.
>>>>    Barry
>>>>> On Aug 21, 2024, at 9:44 PM, TAY Wee Beng <zonexo at gmail.com> <mailto:zonexo at gmail.com> wrote:
>>>>> Hi Barry,
>>>>> I have declared them as integers in Fortran. Is that different from PetscInt and how come it works in debug mode?
>>>>> Anyway, I changed them and it solved the problem. However, I have a similar problem in my boundary.F90:
>>>>> boundary.F90(6685): error #6285: There is no matching specific subroutine for this generic subroutine call.   [MATSETVALUES]
>>>>> I changed all to PetscInt and also PetscReal but I still got the error.
>>>>> Why is this so now? Any solution?
>>>>> Thanks!
>>>>> On 22/8/2024 12:03 am, Barry Smith wrote:
>>>>>>   You must declare as
>>>>>>   PetscInt ksta_p,kend_p
>>>>>>   Perhaps they are declared as arrays?
>>>>>>> On Aug 21, 2024, at 11:19 AM, TAY Wee Beng <zonexo at gmail.com> <mailto:zonexo at gmail.com> wrote:
>>>>>>> Hi,
>>>>>>> I am using the latest PETSc thru github. I compiled both the debug and rel ver of PETSc w/o problem.
>>>>>>> I then use it with my CFD code and the debug ver works.
>>>>>>> However, I have problems with the rel ver:
>>>>>>> ftn -o global.o -c -O3 -g -ip -ipo   -fPIC  -save -w -I/home/project/11003851/lib/petsc_210824_intel_rel/include    global.F90
>>>>>>> ifort: remark #10448: Intel(R) Fortran Compiler Classic (ifort) is now deprecated and will be discontinued late 2024. Intel recommends that customers transition now to using the LLVM-based Intel(R) Fortran Compiler (ifx) for continued Windows* and Linux* support, new language support, new language features, and optimizations. Use '-diag-disable=10448' to disable this message.
>>>>>>> global.F90(444): error #6285: There is no matching specific subroutine for this generic subroutine call.   [MATGETOWNERSHIPRANGE]
>>>>>>>         call MatGetOwnershipRange(A_mat,ksta_p,kend_p,ierr)
>>>>>>> global.F90(720): error #6285: There is no matching specific subroutine for this generic subroutine call.   [MATGETOWNERSHIPRANGE]
>>>>>>> call MatGetOwnershipRange(A_mat_uv,ksta_m,kend_m,ierr)
>>>>>>> global.F90(774): error #6285: There is no matching specific subroutine for this generic subroutine call.   [MATGETOWNERSHIPRANGE]
>>>>>>> call MatGetOwnershipRange(A_semi_x,ksta_mx,kend_mx,ierr)
>>>>>>> global.F90(776): error #6285: There is no matching specific subroutine for this generic subroutine call.   [MATGETOWNERSHIPRANGE]
>>>>>>> call MatGetOwnershipRange(A_semi_y,ksta_my,kend_my,ierr)
>>>>>>> global.F90(949): error #6285: There is no matching specific subroutine for this generic subroutine call.   [MATGETOWNERSHIPRANGE]
>>>>>>> global.F90(957): error #6285: There is no matching specific subroutine for this generic subroutine call.   [MATGETOWNERSHIPRANGE]
>>>>>>> compilation aborted for global.F90 (code 1)
>>>>>>> May I know what's the problem?
>>>>>>> Thank you very much.
>>>>>>> Yours sincerely,
>>>>>>> TAY Wee-Beng 郑伟明 (Zheng Weiming)
>>>>> Yours sincerely,
>>> Yours sincerely,
> Yours sincerely,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240822/2da08c65/attachment-0001.html>
