[petsc-users] Error during code compile with MATGETOWNERSHIPRANGE
TAY Wee Beng zonexo at gmail.com
Thu Aug 22 08:55:53 CDT 2024
On 22/8/2024 9:54 pm, Barry Smith wrote:
>   What is int_impl(k,5) defined type?
PetscInt
>> On Aug 22, 2024, at 9:45 AM, TAY Wee Beng <zonexo at gmail.com> wrote:
>> Hi Barry,
>> Do you mean that I change from:
>> call
>> MatSetValues(A_mat_uv,ione,II,ione,int_impl(k,5),impl_mat_A,INSERT_VALUES,ierr)
>> to
>> call
>> MatSetValues(A_mat_uv,[ione],II,[ione],[int_impl(k,5)],impl_mat_A,INSERT_VALUES,ierr)
>> I did it but the error is still there.
>> On 22/8/2024 9:40 pm, Barry Smith wrote:
>>>    Fortran 90 type checking is very tight; The dimension of the
>>> array, or scalar passed as arguments must match the expected
>>> dimension (f77 did not do this type checking). Thus the ione
>>> argument must be a 1-d array as well as the numerical values so do
>>>> */call
>>>> MatSetValues(A_mat_uv,[ione],II,[ione],[int_impl(k,5)],impl_mat_A,INSERT_VALUES,ierr)/*
>>> See Fortran at https://urldefense.us/v3/__https://petsc.org/main/changes/dev/__;!!G_uCfscf7eWS!autVTPnQ7buLuq9rjvUR07AS8J_YKe2xLprKP48K_ELW64wGci2MCdQ2u2VxgZOFwjHSdmLTP8x3yfcAg30$
>>> I am trying to support the old-fashion F77 model, allowing
>>> miss-matches in the array dimensions while still doing proper type
>>> checking but it will take some time to simplify the API.
>>>    Barry
>>>> On Aug 21, 2024, at 9:44 PM, TAY Wee Beng <zonexo at gmail.com> wrote:
>>>> Hi Barry,
>>>> I have declared them as integers in Fortran. Is that different from
>>>> PetscInt and how come it works in debug mode?
>>>> Anyway, I changed them and it solved the problem. However, I have a
>>>> similar problem in my boundary.F90:
>>>> */boundary.F90(6685): error #6285: There is no matching specific
>>>> subroutine for this generic subroutine call. [MATSETVALUES]
>>>> call
>>>> MatSetValues(A_mat_uv,ione,II,ione,int_impl(k,5),impl_mat_A,INSERT_VALUES,ierr)/*
>>>> I changed all to PetscInt and also PetscReal but I still got the error.
>>>> Why is this so now? Any solution?
>>>> Thanks!
>>>> On 22/8/2024 12:03 am, Barry Smith wrote:
>>>>>   You must declare as
>>>>> */  PetscInt ksta_p,kend_p/*
>>>>>   Perhaps they are declared as arrays?
>>>>>> On Aug 21, 2024, at 11:19 AM, TAY Wee Beng <zonexo at gmail.com> wrote:
>>>>>> Hi,
>>>>>> I am using the latest PETSc thru github. I compiled both the
>>>>>> debug and rel ver of PETSc w/o problem.
>>>>>> I then use it with my CFD code and the debug ver works.
>>>>>> However, I have problems with the rel ver:
>>>>>> */ftn -o global.o -c -O3 -g -ip -ipo   -fPIC  -save -w
>>>>>> -I/home/project/11003851/lib/petsc_210824_intel_rel/include
>>>>>> global.F90
>>>>>> ifort: remark #10448: Intel(R) Fortran Compiler Classic (ifort)
>>>>>> is now deprecated and will be discontinued late 2024. Intel
>>>>>> recommends that customers transition now to using the LLVM-based
>>>>>> Intel(R) Fortran Compiler (ifx) for continued Windows* and Linux*
>>>>>> support, new language support, new language features, and
>>>>>> optimizations. Use '-diag-disable=10448' to disable this message.
>>>>>> global.F90(444): error #6285: There is no matching specific
>>>>>> subroutine for this generic subroutine call. [MATGETOWNERSHIPRANGE]
>>>>>>         call MatGetOwnershipRange(A_mat,ksta_p,kend_p,ierr)
>>>>>> global.F90(720): error #6285: There is no matching specific
>>>>>> call MatGetOwnershipRange(A_mat_uv,ksta_m,kend_m,ierr)
>>>>>> global.F90(774): error #6285: There is no matching specific
>>>>>> call MatGetOwnershipRange(A_semi_x,ksta_mx,kend_mx,ierr)
>>>>>> global.F90(776): error #6285: There is no matching specific
>>>>>> call MatGetOwnershipRange(A_semi_y,ksta_my,kend_my,ierr)
>>>>>> global.F90(949): error #6285: There is no matching specific
>>>>>> global.F90(957): error #6285: There is no matching specific
>>>>>> compilation aborted for global.F90 (code 1)/*
>>>>>> May I know what's the problem?
>>>>>> Thank you very much.
>>>>>> Yours sincerely,
>>>>>> TAY Wee-Beng 郑伟明 (Zheng Weiming)
>>>> Yours sincerely,
>> Yours sincerely,
Yours sincerely,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240822/8b64d7ee/attachment-0001.html>
