[petsc-users] Error during code compile with MATGETOWNERSHIPRANGE
TAY Wee Beng zonexo at gmail.com
Thu Aug 22 09:33:44 CDT 2024
On 22/8/2024 10:28 pm, Barry Smith wrote:
>   Should be PetscReal as it is a numerical value.
Ok, I changed it but I still get the same error.
>> On Aug 22, 2024, at 9:55 AM, TAY Wee Beng <zonexo at gmail.com> wrote:
>> On 22/8/2024 9:54 pm, Barry Smith wrote:
>>>   What is int_impl(k,5) defined type?
>> PetscInt
>>>> On Aug 22, 2024, at 9:45 AM, TAY Wee Beng <zonexo at gmail.com> wrote:
>>>> Hi Barry,
>>>> Do you mean that I change from:
>>>> call
>>>> MatSetValues(A_mat_uv,ione,II,ione,int_impl(k,5),impl_mat_A,INSERT_VALUES,ierr)
>>>> to
>>>> call
>>>> MatSetValues(A_mat_uv,[ione],II,[ione],[int_impl(k,5)],impl_mat_A,INSERT_VALUES,ierr)
>>>> I did it but the error is still there.
>>>> On 22/8/2024 9:40 pm, Barry Smith wrote:
>>>>>    Fortran 90 type checking is very tight; The dimension of the
>>>>> array, or scalar passed as arguments must match the expected
>>>>> dimension (f77 did not do this type checking). Thus the ione
>>>>> argument must be a 1-d array as well as the numerical values so do
>>>>>> */call
>>>>>> MatSetValues(A_mat_uv,[ione],II,[ione],[int_impl(k,5)],impl_mat_A,INSERT_VALUES,ierr)/*
>>>>> See Fortran at https://urldefense.us/v3/__https://petsc.org/main/changes/dev/__;!!G_uCfscf7eWS!ceHG-n9LyJ3rsdpLe9UTHqjmAfS_mkeKJyn0NemRgYmtmmVJH-W2116HMDnQnrHJK4J7Vd8G9Z3Pqkcz9N8$
>>>>> I am trying to support the old-fashion F77 model, allowing
>>>>> miss-matches in the array dimensions while still doing proper type
>>>>> checking but it will take some time to simplify the API.
>>>>>    Barry
>>>>>> On Aug 21, 2024, at 9:44 PM, TAY Wee Beng <zonexo at gmail.com> wrote:
>>>>>> Hi Barry,
>>>>>> I have declared them as integers in Fortran. Is that different
>>>>>> from PetscInt and how come it works in debug mode?
>>>>>> Anyway, I changed them and it solved the problem. However, I have
>>>>>> a similar problem in my boundary.F90:
>>>>>> */boundary.F90(6685): error #6285: There is no matching specific
>>>>>> subroutine for this generic subroutine call. [MATSETVALUES]
>>>>>> call
>>>>>> MatSetValues(A_mat_uv,ione,II,ione,int_impl(k,5),impl_mat_A,INSERT_VALUES,ierr)/*
>>>>>> I changed all to PetscInt and also PetscReal but I still got the
>>>>>> error.
>>>>>> Why is this so now? Any solution?
>>>>>> Thanks!
>>>>>> On 22/8/2024 12:03 am, Barry Smith wrote:
>>>>>>>   You must declare as
>>>>>>> */  PetscInt ksta_p,kend_p/*
>>>>>>>   Perhaps they are declared as arrays?
>>>>>>>> On Aug 21, 2024, at 11:19 AM, TAY Wee Beng <zonexo at gmail.com>
>>>>>>>> wrote:
>>>>>>>> Hi,
>>>>>>>> I am using the latest PETSc thru github. I compiled both the
>>>>>>>> debug and rel ver of PETSc w/o problem.
>>>>>>>> I then use it with my CFD code and the debug ver works.
>>>>>>>> However, I have problems with the rel ver:
>>>>>>>> */ftn -o global.o -c -O3 -g -ip -ipo -fPIC  -save -w
>>>>>>>> -I/home/project/11003851/lib/petsc_210824_intel_rel/include
>>>>>>>> global.F90
>>>>>>>> ifort: remark #10448: Intel(R) Fortran Compiler Classic (ifort)
>>>>>>>> is now deprecated and will be discontinued late 2024. Intel
>>>>>>>> recommends that customers transition now to using the
>>>>>>>> LLVM-based Intel(R) Fortran Compiler (ifx) for continued
>>>>>>>> Windows* and Linux* support, new language support, new language
>>>>>>>> features, and optimizations. Use '-diag-disable=10448' to
>>>>>>>> disable this message.
>>>>>>>> global.F90(444): error #6285: There is no matching specific
>>>>>>>> subroutine for this generic subroutine call. [MATGETOWNERSHIPRANGE]
>>>>>>>>         call MatGetOwnershipRange(A_mat,ksta_p,kend_p,ierr)
>>>>>>>> global.F90(720): error #6285: There is no matching specific
>>>>>>>> call MatGetOwnershipRange(A_mat_uv,ksta_m,kend_m,ierr)
>>>>>>>> global.F90(774): error #6285: There is no matching specific
>>>>>>>> call MatGetOwnershipRange(A_semi_x,ksta_mx,kend_mx,ierr)
>>>>>>>> global.F90(776): error #6285: There is no matching specific
>>>>>>>> call MatGetOwnershipRange(A_semi_y,ksta_my,kend_my,ierr)
>>>>>>>> global.F90(949): error #6285: There is no matching specific
>>>>>>>> global.F90(957): error #6285: There is no matching specific
>>>>>>>> compilation aborted for global.F90 (code 1)/*
>>>>>>>> May I know what's the problem?
>>>>>>>> Thank you very much.
>>>>>>>> Yours sincerely,
>>>>>>>> TAY Wee-Beng 郑伟明 (Zheng Weiming)
>>>>>> Yours sincerely,
>>>> Yours sincerely,
>> Yours sincerely,
Yours sincerely,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240822/28cbf884/attachment-0001.html>
