[petsc-users] PCFactorSetMatOrderingType not working with 3.21
Barry Smith
bsmith at petsc.dev
Sat Aug 17 12:07:46 CDT 2024
I have attached src/snes/tutorials/ex5.c in which I tried to reproduce your problem by inserting the code you've indicated.
However I am not getting the problem you see, I am seeing,
type: ilu
out-of-place factorization
0 levels of fill
tolerance for zero pivot 2.22045e-14
matrix ordering: rcm
when I run with -pc_type ilu -snes_view
Can you please confirm you get the same problem with the attached ex5.c ? You could send your code to see if I can reproduce the problem.
I am using the release branch of PETSc
Barry
> On Aug 17, 2024, at 12:35 PM, Zou, Ling via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi all,
> The following codes are how I used to setup PC mat ordering:
> // Setup KSP/PC (at this moment, user-input options and commandline options are available)
> SNESGetKSP(snes, &ksp);
> KSPSetFromOptions(ksp);
> PC pc;
> KSPGetPC(ksp, &pc);
> PCFactorSetMatOrderingType(pc, MATORDERINGRCM);
> // PCFactorSetLevels(pc, 5);
> SNESSetFromOptions(snes);
> After switching to PETSc 3.21, this no longer works, and can be confirmed from ‘-snes_view’ output:
> PC Object: 1 MPI process
> type: ilu
> 0 levels of fill
> using diagonal shift to prevent zero pivot [NONZERO]
> matrix ordering: natural
> The command line option still works, i.e., ‘-pc_factor_mat_ordering_type rcm’ gives me the correct behavior.
> Questions:
> Is this a bug introduced in the new version, or
> With the new version, I should call this function at a different time?
> Best,
> -Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240817/4e556b41/attachment-0002.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240817/4e556b41/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240817/4e556b41/attachment-0003.html>
