[petsc-users] PCFactorSetMatOrderingType not working with 3.21
Zou, Ling
lzou at anl.gov
Sat Aug 17 11:35:28 CDT 2024
Hi all,
The following codes are how I used to setup PC mat ordering:
// Setup KSP/PC (at this moment, user-input options and commandline options are available)
SNESGetKSP(snes, &ksp);
KSPSetFromOptions(ksp);
PC pc;
KSPGetPC(ksp, &pc);
PCFactorSetMatOrderingType(pc, MATORDERINGRCM);
// PCFactorSetLevels(pc, 5);
SNESSetFromOptions(snes);
After switching to PETSc 3.21, this no longer works, and can be confirmed from ‘-snes_view’ output:
PC Object: 1 MPI process
type: ilu
out-of-place factorization
0 levels of fill
tolerance for zero pivot 2.22045e-14
using diagonal shift to prevent zero pivot [NONZERO]
matrix ordering: natural
The command line option still works, i.e., ‘-pc_factor_mat_ordering_type rcm’ gives me the correct behavior.
Questions:
* Is this a bug introduced in the new version, or
* With the new version, I should call this function at a different time?
Best,
-Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240817/9a944b17/attachment-0001.html>
