[petsc-users] PCFactorSetMatOrderingType not working with 3.21
Zou, Ling lzou at anl.gov
Sat Aug 17 14:44:25 CDT 2024
Barry, thanks.
I am accessing PETSc through MOOSE. I need to figure out if the versions are consistent and how to test it.
-Ling
Date: Saturday, August 17, 2024 at 12:08 PM
To: Zou, Ling <lzou at anl.gov>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] PCFactorSetMatOrderingType not working with 3.21
I have attached src/snes/tutorials/ex5. c in which I tried to reproduce your problem by inserting the code you've indicated. However I am not getting the problem you see, I am seeing, type: ilu out-of-place factorization 0 levels of fill tolerance
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
   I have attached src/snes/tutorials/ex5.c in which I tried to reproduce your problem by inserting the code you've indicated.
    type: ilu
      0 levels of fill
      tolerance for zero pivot 2.22045e-14
      matrix ordering: rcm
when I run with -pc_type ilu -snes_view
 Can you please confirm you get the same problem with the attached ex5.c ?  You could send your code to see if I can reproduce the problem.
  I am using the release branch of PETSc
  Barry
On Aug 17, 2024, at 12:35 PM, Zou, Ling via petsc-users <petsc-users at mcs.anl.gov> wrote:
Hi all,
The following codes are how I used to setup PC mat ordering:
  // Setup KSP/PC (at this moment, user-input options and commandline options are available)
  SNESGetKSP(snes, &ksp);
  KSPSetFromOptions(ksp);
  PC pc;
  KSPGetPC(ksp, &pc);
  PCFactorSetMatOrderingType(pc, MATORDERINGRCM);
  // PCFactorSetLevels(pc, 5);
  SNESSetFromOptions(snes);
After switching to PETSc 3.21, this no longer works, and can be confirmed from ‘-snes_view’ output:
  PC Object: 1 MPI process
    type: ilu
      0 levels of fill
      using diagonal shift to prevent zero pivot [NONZERO]
      matrix ordering: natural
The command line option still works, i.e., ‘-pc_factor_mat_ordering_type rcm’ gives me the correct behavior.
Questions:
  *   Is this a bug introduced in the new version, or
  *   With the new version, I should call this function at a different time?
Best,
-Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240817/a5c1b7b6/attachment.html>
