[petsc-users] Read/Write large dense matrix
Sreeram R Venkat
srvenkat at utexas.edu
Mon Aug 5 12:10:26 CDT 2024
I have a large dense matrix (size ranging from 5e4 to 1e5) that arises as a
result of doing MatComputeOperator() on a MatShell. When the total number
of nonzeros exceeds the 32 bit integer value, I get an error (MPI buffer
size too big) when trying to do MatView() on this to save to binary. Is
there a way I can save this matrix to load again for later use?
The other thing I tried was to save each column as a separate dataset in an
hdf5 file. Then, I tried to load this in python, combine them to an np
array, and then create/save a dense matrix with petsc4py. I was able to
create the dense Mat, but the MatView() once again resulted in an error
(out of memory).
Sreeram
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240805/ab64250e/attachment.html>
