[petsc-users] Coordinate format internal reordering
Matthew Knepley
knepley at gmail.com
Thu Oct 19 10:21:33 CDT 2023
On Thu, Oct 19, 2023 at 10:51 AM Enrico <degregori at dkrz.de> wrote:
> In the application the storage is contiguous but the global indexing is
> not. I would like to use AO as a translation layer but I don't
> understand it.
Why would you choose to index differently from your storage?
> My case is actually simple even if it is in a large application, I have
> Mat A, Vec b and Vec x
> After calling KSPSolve, I use VecGetArrayReadF90 to get a pointer to the
> data and they are in the wrong ordering, so for example the first
> element of the solution array on process 0 belongs to process 1 in the
> application.
Again, this seems to be a poor choice of layout. What we typically do is to
partition
the data into chunks owned by each process first.
> Is it at this point that I should use the AO translation layer? This
> would be quite bad, it means to build Mat A and Vec b there is MPI
> communication and also to get the data of Vec x back in the application.
If you want to store data that process i updates on process j, this will
need communication.
> Anyway, I've tried to use AOPetscToApplicationPermuteReal on the
> solution array but it doesn't work as I would like. Is this function
> suppose to do MPI communication between processes and fetch the values
> of the application ordering?
There is no communication here. That function call just changes one integer
into another.
If you want to update values on another process, we recommend using
VecScatter() or
MatSetValues(), both of which take global indices and do communication if
necessary.
Matt
> Cheers,
> Enrico
> On 19/10/2023 15:25, Matthew Knepley wrote:
> > On Thu, Oct 19, 2023 at 8:57 AM Enrico <degregori at dkrz.de
> > <mailto:degregori at dkrz.de>> wrote:
> > Maybe I wasn't clear enough. I would like to completely get rid of
> > Petsc
> > ordering because I don't want extra communication between processes
> to
> > construct the vector and the matrix (since I have to fill them every
> > time step because I'm just using the linear solver with a Mat and a
> Vec
> > data structure). I don't understand how I can do that.
> > Any program you write to do linear algebra will have contiguous storage
> > because it
> > is so much faster. Contiguous indexing makes sense for contiguous
> > storage. If you
> > want to use non-contiguous indexing for contiguous storage, you would
> > need some
> > translation layer. The AO is such a translation, but you could do this
> > any way you want.
> > Thanks,
> > Matt
> > My initial idea was to create another global index ordering within my
> > application to use only for the Petsc interface but then I think that
> > the ghost cells are wrong.
> > On 19/10/2023 14:50, Matthew Knepley wrote:
> > > On Thu, Oct 19, 2023 at 6:51 AM Enrico <degregori at dkrz.de
> > > <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>> wrote:
> > > Hello,
> > > if I create an application ordering using AOCreateBasic,
> should I
> > > provide the same array for const PetscInt myapp[] and const
> > PetscInt
> > > mypetsc[] in order to get the same ordering of the application
> > > within PETSC?
> > > Are you asking if the identity permutation can be constructed
> > using the
> > > same array twice? Yes.
> > > And once I define the ordering so that the local vector and
> > matrix are
> > > defined in PETSC as in my application, how can I use it to
> > create the
> > > actual vector and matrix?
> > > The vectors and matrices do not change. The AO is a permutation.
> > You can
> > > use it to permute
> > > a vector into another order, or to convert on index to another.
> > > Thanks,
> > > Matt
> > > Thanks in advance for the help.
> > > Cheers,
> > > Enrico
> > > On 18/10/2023 13:39, Matthew Knepley wrote:
> > > > On Wed, Oct 18, 2023 at 5:55 AM Enrico <degregori at dkrz.de
> > <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>> wrote:
> > > > Hello,
> > > > I'm trying to use Petsc to solve a linear system in an
> > > application. I'm
> > > > using the coordinate format to define the matrix and
> the
> > > vector (it
> > > > should work better on GPU but at the moment every test
> > is on
> > > CPU).
> > > > After
> > > > the call to VecSetValuesCOO, I've noticed that the
> > vector is
> > > storing
> > > > the
> > > > data in a different way from my application. For
> > example with two
> > > > processes in the application
> > > > process 0 owns cells 2, 3, 4
> > > > process 1 owns cells 0, 1, 5
> > > > But in the vector data structure of Petsc
> > > > process 0 owns cells 0, 1, 2
> > > > process 1 owns cells 3, 4, 5
> > > > This is in principle not a big issue, but after
> > solving the
> > > linear
> > > > system I get the solution vector x and I want to get
> the
> > > values in the
> > > > correct processes. Is there a way to get vector values
> > from other
> > > > processes or to get a mapping so that I can do it
> myself?
> > > > By definition, PETSc vectors and matrices own contiguous
> row
> > > blocks. If
> > > > you want to have another,
> > > > global ordering, we support that with
> > > > https://petsc.org/main/manualpages/AO/
> > <https://petsc.org/main/manualpages/AO/>
> > <https://petsc.org/main/manualpages/AO/>>
> > <https://petsc.org/main/manualpages/AO/>>>
> > > > Thanks,
> > > > Matt
> > > > Cheers,
> > > > Enrico Degregori
> > > > What most experimenters take for granted before they begin
> > their
> > > > experiments is infinitely more interesting than any
> > results to which
> > > > their experiments lead.
> > > > -- Norbert Wiener
> > > > https://www.cse.buffalo.edu/~knepley/
> > <https://www.cse.buffalo.edu/~knepley/>
> > <https://www.cse.buffalo.edu/~knepley/>>
> > > <http://www.cse.buffalo.edu/~knepley/
> > <http://www.cse.buffalo.edu/~knepley/>
> > <http://www.cse.buffalo.edu/~knepley/>>>
> > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to
> which
> > > -- Norbert Wiener
> > experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231019/ca1f2156/attachment-0001.html>
