[petsc-users] Coordinate format internal reordering
Enrico degregori at dkrz.de
Thu Oct 19 09:51:41 CDT 2023
In the application the storage is contiguous but the global indexing is
not. I would like to use AO as a translation layer but I don't
understand it.
My case is actually simple even if it is in a large application, I have
Mat A, Vec b and Vec x
After calling KSPSolve, I use VecGetArrayReadF90 to get a pointer to the
data and they are in the wrong ordering, so for example the first
element of the solution array on process 0 belongs to process 1 in the
application.
Is it at this point that I should use the AO translation layer? This
would be quite bad, it means to build Mat A and Vec b there is MPI
communication and also to get the data of Vec x back in the application.
Anyway, I've tried to use AOPetscToApplicationPermuteReal on the
solution array but it doesn't work as I would like. Is this function
suppose to do MPI communication between processes and fetch the values
of the application ordering?
Cheers,
Enrico
On 19/10/2023 15:25, Matthew Knepley wrote:
> On Thu, Oct 19, 2023 at 8:57 AM Enrico <degregori at dkrz.de
> <mailto:degregori at dkrz.de>> wrote:
>     Maybe I wasn't clear enough. I would like to completely get rid of
>     Petsc
>     ordering because I don't want extra communication between processes to
>     construct the vector and the matrix (since I have to fill them every
>     time step because I'm just using the linear solver with a Mat and a Vec
>     data structure). I don't understand how I can do that.
> Any program you write to do linear algebra will have contiguous storage
> because it
> is so much faster. Contiguous indexing makes sense for contiguous
> storage. If you
> want to use non-contiguous indexing for contiguous storage, you would
> need some
> translation layer. The AO is such a translation, but you could do this
> any way you want.
>    Thanks,
>       Matt
>     My initial idea was to create another global index ordering within my
>     application to use only for the Petsc interface but then I think that
>     the ghost cells are wrong.
>     On 19/10/2023 14:50, Matthew Knepley wrote:
>      > On Thu, Oct 19, 2023 at 6:51 AM Enrico <degregori at dkrz.de
>      > <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>> wrote:
>      >     Hello,
>      >     if I create an application ordering using AOCreateBasic, should I
>      >     provide the same array for const PetscInt myapp[] and const
>     PetscInt
>      >     mypetsc[] in order to get the same ordering of the application
>      >     within PETSC?
>      > Are you asking if the identity permutation can be constructed
>     using the
>      > same array twice? Yes.
>      >     And once I define the ordering so that the local vector and
>     matrix are
>      >     defined in PETSC as in my application, how can I use it to
>     create the
>      >     actual vector and matrix?
>      > The vectors and matrices do not change. The AO is a permutation.
>     You can
>      > use it to permute
>      > a vector into another order, or to convert on index to another.
>      >    Thanks,
>      >        Matt
>      >     Thanks in advance for the help.
>      >     Cheers,
>      >     Enrico
>      >     On 18/10/2023 13:39, Matthew Knepley wrote:
>      >      > On Wed, Oct 18, 2023 at 5:55 AM Enrico <degregori at dkrz.de
>      >      > <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>
>     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>> wrote:
>      >      >     Hello,
>      >      >     I'm trying to use Petsc to solve a linear system in an
>      >     application. I'm
>      >      >     using the coordinate format to define the matrix and the
>      >     vector (it
>      >      >     should work better on GPU but at the moment every test
>     is on
>      >     CPU).
>      >      >     After
>      >      >     the call to VecSetValuesCOO, I've noticed that the
>     vector is
>      >     storing
>      >      >     the
>      >      >     data in a different way from my application. For
>     example with two
>      >      >     processes in the application
>      >      >     process 0 owns cells 2, 3, 4
>      >      >     process 1 owns cells 0, 1, 5
>      >      >     But in the vector data structure of Petsc
>      >      >     process 0 owns cells 0, 1, 2
>      >      >     process 1 owns cells 3, 4, 5
>      >      >     This is in principle not a big issue, but after
>     solving the
>      >     linear
>      >      >     system I get the solution vector x and I want to get the
>      >     values in the
>      >      >     correct processes. Is there a way to get vector values
>     from other
>      >      >     processes or to get a mapping so that I can do it myself?
>      >      > By definition, PETSc vectors and matrices own contiguous row
>      >     blocks. If
>      >      > you want to have another,
>      >      > global ordering, we support that with
>      >      > https://petsc.org/main/manualpages/AO/
>     <https://petsc.org/main/manualpages/AO/>
>     <https://petsc.org/main/manualpages/AO/>>
>      >      > <https://petsc.org/main/manualpages/AO/
>     <https://petsc.org/main/manualpages/AO/>>>
>      >      >    Thanks,
>      >      >       Matt
>      >      >     Cheers,
>      >      >     Enrico Degregori
>      >      > What most experimenters take for granted before they begin
>     their
>      >      > experiments is infinitely more interesting than any
>     results to which
>      >      > their experiments lead.
>      >      > -- Norbert Wiener
>      >      > https://www.cse.buffalo.edu/~knepley/
>     <https://www.cse.buffalo.edu/~knepley/>
>     <https://www.cse.buffalo.edu/~knepley/>>
>      >     <http://www.cse.buffalo.edu/~knepley/
>     <http://www.cse.buffalo.edu/~knepley/>
>     <http://www.cse.buffalo.edu/~knepley/>>>
>      > What most experimenters take for granted before they begin their
>      > experiments is infinitely more interesting than any results to which
>      > -- Norbert Wiener
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
