[petsc-users] Coordinate format internal reordering
Enrico degregori at dkrz.de
Thu Oct 19 10:33:16 CDT 2023
The layout is not poor, just the global indices are not contiguous,this
has nothing to do with the local memory layout which is extremely
optimized for different architectures. I can not change the layout
anyway because it's a climate model with a million lines of code.
I don't understand why Petsc is doing all this MPI communication under
the hood. I mean, it is changing the layout of the application and doing
a lot of communication. Is there no way to force the same layout and
provide info about how to do the halo exchange? In this way I can have
the same memory layout and there is no communication when I fill or
fetch the vectors and the matrix.
Cheers,
Enrico
On 19/10/2023 17:21, Matthew Knepley wrote:
> On Thu, Oct 19, 2023 at 10:51 AM Enrico <degregori at dkrz.de
> <mailto:degregori at dkrz.de>> wrote:
>     In the application the storage is contiguous but the global indexing is
>     not. I would like to use AO as a translation layer but I don't
>     understand it.
> Why would you choose to index differently from your storage?
>     My case is actually simple even if it is in a large application, I have
>     Mat A, Vec b and Vec x
>     After calling KSPSolve, I use VecGetArrayReadF90 to get a pointer to
>     the
>     data and they are in the wrong ordering, so for example the first
>     element of the solution array on process 0 belongs to process 1 in the
>     application.
> Again, this seems to be a poor choice of layout. What we typically do is
> to partition
> the data into chunks owned by each process first.
>     Is it at this point that I should use the AO translation layer? This
>     would be quite bad, it means to build Mat A and Vec b there is MPI
>     communication and also to get the data of Vec x back in the application.
> If you want to store data that process i updates on process j, this will
> need communication.
>     Anyway, I've tried to use AOPetscToApplicationPermuteReal on the
>     solution array but it doesn't work as I would like. Is this function
>     suppose to do MPI communication between processes and fetch the values
>     of the application ordering?
> There is no communication here. That function call just changes one
> integer into another.
> If you want to update values on another process, we recommend using
> VecScatter() or
> MatSetValues(), both of which take global indices and do communication
> if necessary.
>    Thanks,
>      Matt
>     Cheers,
>     Enrico
>     On 19/10/2023 15:25, Matthew Knepley wrote:
>      > On Thu, Oct 19, 2023 at 8:57 AM Enrico <degregori at dkrz.de
>      > <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>> wrote:
>      >     Maybe I wasn't clear enough. I would like to completely get
>     rid of
>      >     Petsc
>      >     ordering because I don't want extra communication between
>     processes to
>      >     construct the vector and the matrix (since I have to fill
>     them every
>      >     time step because I'm just using the linear solver with a Mat
>     and a Vec
>      >     data structure). I don't understand how I can do that.
>      > Any program you write to do linear algebra will have contiguous
>     storage
>      > because it
>      > is so much faster. Contiguous indexing makes sense for contiguous
>      > storage. If you
>      > want to use non-contiguous indexing for contiguous storage, you
>     would
>      > need some
>      > translation layer. The AO is such a translation, but you could do
>     this
>      > any way you want.
>      >    Thanks,
>      >       Matt
>      >     My initial idea was to create another global index ordering
>     within my
>      >     application to use only for the Petsc interface but then I
>     think that
>      >     the ghost cells are wrong.
>      >     On 19/10/2023 14:50, Matthew Knepley wrote:
>      >      > On Thu, Oct 19, 2023 at 6:51 AM Enrico <degregori at dkrz.de
>      >      > <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>
>     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>> wrote:
>      >      >     Hello,
>      >      >     if I create an application ordering using
>     AOCreateBasic, should I
>      >      >     provide the same array for const PetscInt myapp[] and
>     const
>      >     PetscInt
>      >      >     mypetsc[] in order to get the same ordering of the
>     application
>      >      >     within PETSC?
>      >      > Are you asking if the identity permutation can be constructed
>      >     using the
>      >      > same array twice? Yes.
>      >      >     And once I define the ordering so that the local
>     vector and
>      >     matrix are
>      >      >     defined in PETSC as in my application, how can I use it to
>      >     create the
>      >      >     actual vector and matrix?
>      >      > The vectors and matrices do not change. The AO is a
>     permutation.
>      >     You can
>      >      > use it to permute
>      >      > a vector into another order, or to convert on index to
>     another.
>      >      >    Thanks,
>      >      >        Matt
>      >      >     Thanks in advance for the help.
>      >      >     Cheers,
>      >      >     Enrico
>      >      >     On 18/10/2023 13:39, Matthew Knepley wrote:
>      >      >      > On Wed, Oct 18, 2023 at 5:55 AM Enrico
>     <degregori at dkrz.de <mailto:degregori at dkrz.de>
>      >      >      > <mailto:degregori at dkrz.de
>     <mailto:degregori at dkrz.de> <mailto:degregori at dkrz.de
>     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>>> wrote:
>      >      >      >     Hello,
>      >      >      >     I'm trying to use Petsc to solve a linear
>     system in an
>      >      >     application. I'm
>      >      >      >     using the coordinate format to define the
>     matrix and the
>      >      >     vector (it
>      >      >      >     should work better on GPU but at the moment
>     every test
>      >     is on
>      >      >     CPU).
>      >      >      >     After
>      >      >      >     the call to VecSetValuesCOO, I've noticed that the
>      >     vector is
>      >      >     storing
>      >      >      >     the
>      >      >      >     data in a different way from my application. For
>      >     example with two
>      >      >      >     processes in the application
>      >      >      >     process 0 owns cells 2, 3, 4
>      >      >      >     process 1 owns cells 0, 1, 5
>      >      >      >     But in the vector data structure of Petsc
>      >      >      >     process 0 owns cells 0, 1, 2
>      >      >      >     process 1 owns cells 3, 4, 5
>      >      >      >     This is in principle not a big issue, but after
>      >     solving the
>      >      >     linear
>      >      >      >     system I get the solution vector x and I want
>     to get the
>      >      >     values in the
>      >      >      >     correct processes. Is there a way to get vector
>     values
>      >     from other
>      >      >      >     processes or to get a mapping so that I can do
>     it myself?
>      >      >      > By definition, PETSc vectors and matrices own
>     contiguous row
>      >      >     blocks. If
>      >      >      > you want to have another,
>      >      >      > global ordering, we support that with
>      >      >      > https://petsc.org/main/manualpages/AO/
>     <https://petsc.org/main/manualpages/AO/>
>     <https://petsc.org/main/manualpages/AO/>>
>      >      >     <https://petsc.org/main/manualpages/AO/
>     <https://petsc.org/main/manualpages/AO/>>>
>      >      >      > <https://petsc.org/main/manualpages/AO/
>     <https://petsc.org/main/manualpages/AO/>>>>
>      >      >      >    Thanks,
>      >      >      >       Matt
>      >      >      >     Cheers,
>      >      >      >     Enrico Degregori
>      >      >      > What most experimenters take for granted before
>     they begin
>      >     their
>      >      >      > experiments is infinitely more interesting than any
>      >     results to which
>      >      >      > their experiments lead.
>      >      >      > -- Norbert Wiener
>      >      >      > https://www.cse.buffalo.edu/~knepley/
>     <https://www.cse.buffalo.edu/~knepley/>
>     <https://www.cse.buffalo.edu/~knepley/>>
>      >      >     <https://www.cse.buffalo.edu/~knepley/
>     <https://www.cse.buffalo.edu/~knepley/>>>
>      >      >     <http://www.cse.buffalo.edu/~knepley/
>     <http://www.cse.buffalo.edu/~knepley/>
>     <http://www.cse.buffalo.edu/~knepley/>>
>     <http://www.cse.buffalo.edu/~knepley/>>>>
>      >      > What most experimenters take for granted before they begin
>     their
>     results to which
>      >      > -- Norbert Wiener
>      > What most experimenters take for granted before they begin their
>      > experiments is infinitely more interesting than any results to which
>      > -- Norbert Wiener
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
