[petsc-users] Coordinate format internal reordering
Thu Oct 19 08:25:40 CDT 2023
On Thu, Oct 19, 2023 at 8:57 AM Enrico <degregori at dkrz.de> wrote:
> Maybe I wasn't clear enough. I would like to completely get rid of Petsc
> ordering because I don't want extra communication between processes to
> construct the vector and the matrix (since I have to fill them every
> time step because I'm just using the linear solver with a Mat and a Vec
> data structure). I don't understand how I can do that.
Any program you write to do linear algebra will have contiguous storage
because it
is so much faster. Contiguous indexing makes sense for contiguous storage.
If you
want to use non-contiguous indexing for contiguous storage, you would need
some
translation layer. The AO is such a translation, but you could do this any
way you want.
     Matt
> My initial idea was to create another global index ordering within my
> application to use only for the Petsc interface but then I think that
> the ghost cells are wrong.
> On 19/10/2023 14:50, Matthew Knepley wrote:
> > On Thu, Oct 19, 2023 at 6:51 AM Enrico <degregori at dkrz.de
> > <mailto:degregori at dkrz.de>> wrote:
> >     Hello,
> >     if I create an application ordering using AOCreateBasic, should I
> >     provide the same array for const PetscInt myapp[] and const PetscInt
> >     mypetsc[] in order to get the same ordering of the application
> >     within PETSC?
> > Are you asking if the identity permutation can be constructed using the
> > same array twice? Yes.
> >     And once I define the ordering so that the local vector and matrix
> are
> >     defined in PETSC as in my application, how can I use it to create the
> >     actual vector and matrix?
> > The vectors and matrices do not change. The AO is a permutation. You can
> > use it to permute
> > a vector into another order, or to convert on index to another.
> >    Thanks,
> >        Matt
> >     Thanks in advance for the help.
> >     Cheers,
> >     Enrico
> >     On 18/10/2023 13:39, Matthew Knepley wrote:
> >      > On Wed, Oct 18, 2023 at 5:55 AM Enrico <degregori at dkrz.de
> >      > <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>> wrote:
> >      >     Hello,
> >      >     I'm trying to use Petsc to solve a linear system in an
> >     application. I'm
> >      >     using the coordinate format to define the matrix and the
> >     vector (it
> >      >     should work better on GPU but at the moment every test is on
> >     CPU).
> >      >     After
> >      >     the call to VecSetValuesCOO, I've noticed that the vector is
> >     storing
> >      >     the
> >      >     data in a different way from my application. For example with
> two
> >      >     processes in the application
> >      >     process 0 owns cells 2, 3, 4
> >      >     process 1 owns cells 0, 1, 5
> >      >     But in the vector data structure of Petsc
> >      >     process 0 owns cells 0, 1, 2
> >      >     process 1 owns cells 3, 4, 5
> >      >     This is in principle not a big issue, but after solving the
> >     linear
> >      >     system I get the solution vector x and I want to get the
> >     values in the
> >      >     correct processes. Is there a way to get vector values from
> other
> >      >     processes or to get a mapping so that I can do it myself?
> >      > By definition, PETSc vectors and matrices own contiguous row
> >     blocks. If
> >      > you want to have another,
> >      > global ordering, we support that with
> >      > https://petsc.org/main/manualpages/AO/
> >     <https://petsc.org/main/manualpages/AO/>
> >     <https://petsc.org/main/manualpages/AO/>>
> >      >    Thanks,
> >      >       Matt
> >      >     Cheers,
> >      >     Enrico Degregori
> >      > What most experimenters take for granted before they begin their
> >      > experiments is infinitely more interesting than any results to
> which
> >      > their experiments lead.
> >      > -- Norbert Wiener
> >      > https://www.cse.buffalo.edu/~knepley/
> >     <https://www.cse.buffalo.edu/~knepley/>
> >     <http://www.cse.buffalo.edu/~knepley/
> >     <http://www.cse.buffalo.edu/~knepley/>>
> > experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231019/d361b094/attachment-0001.html>
