[petsc-users] Galerkin projection using petsc4py
Pierre Jolivet pierre at joliv.et
Wed Oct 11 02:04:51 CDT 2023
That’s because:
    size = ((None, global_rows), (global_cols, global_cols))
should be:
    size = ((None, global_rows), (None, global_cols))
Then, it will work.
$ ~/repo/petsc/arch-darwin-c-debug-real/bin/mpirun -n 4 python3.12 test.py && echo $?
0
Pierre
> On 11 Oct 2023, at 8:58 AM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
> Pierre, I see your point, but my experiment shows that it does not even run due to size mismatch, so I don’t see how being sparse would change things here. There must be some kind of problem with the parallel ptap(), because it does run sequentially. In order to test that, I changed the flags of the matrix creation to sparse=True and ran it again. Here is the code
> """Experimenting with PETSc mat-mat multiplication"""
> import numpy as np
> from firedrake import COMM_WORLD
> from firedrake.petsc import PETSc
> from utilities import Print
> nproc = COMM_WORLD.size
> rank = COMM_WORLD.rank
> def create_petsc_matrix(input_array, sparse=True):
>     """Create a PETSc matrix from an input_array
>     Args:
>         input_array (np array): Input array
>         partition_like (PETSc mat, optional): Petsc matrix. Defaults to None.
>         sparse (bool, optional): Toggle for sparese or dense. Defaults to True.
>     Returns:
>         PETSc mat: PETSc mpi matrix
>     # Check if input_array is 1D and reshape if necessary
>     assert len(input_array.shape) == 2, "Input array should be 2-dimensional"
>     global_rows, global_cols = input_array.shape
>     # Create a sparse or dense matrix based on the 'sparse' argument
>     if sparse:
>         matrix = PETSc.Mat().createAIJ(size=size, comm=COMM_WORLD)
>     else:
>         matrix = PETSc.Mat().createDense(size=size, comm=COMM_WORLD)
>     matrix.setUp()
>     local_rows_start, local_rows_end = matrix.getOwnershipRange()
>     for counter, i in enumerate(range(local_rows_start, local_rows_end)):
>         # Calculate the correct row in the array for the current process
>         row_in_array = counter + local_rows_start
>         matrix.setValues(
>             i, range(global_cols), input_array[row_in_array, :], addv=False
>     # Assembly the matrix to compute the final structure
>     matrix.assemblyBegin()
>     matrix.assemblyEnd()
>     return matrix
> # EXP: Galerkin projection of an mpi PETSc matrix A with an mpi PETSc matrix Phi
> #  A' = Phi.T * A * Phi
> # [k x k] <- [k x m] x [m x m] x [m x k]
> m, k = 100, 7
> # Generate the random numpy matrices
> np.random.seed(0)  # sets the seed to 0
> A_np = np.random.randint(low=0, high=6, size=(m, m))
> Phi_np = np.random.randint(low=0, high=6, size=(m, k))
> # TEST: Galerking projection of numpy matrices A_np and Phi_np
> Aprime_np = Phi_np.T @ A_np @ Phi_np
> # Create A as an mpi matrix distributed on each process
> A = create_petsc_matrix(A_np, sparse=True)
> # Create Phi as an mpi matrix distributed on each process
> Phi = create_petsc_matrix(Phi_np, sparse=True)
> # Create an empty PETSc matrix object to store the result of the PtAP operation.
> # This will hold the result A' = Phi.T * A * Phi after the computation.
> A_prime = create_petsc_matrix(np.zeros((k, k)), sparse=True)
> # Perform the PtAP (Phi Transpose times A times Phi) operation.
> # In mathematical terms, this operation is A' = Phi.T * A * Phi.
> # A_prime will store the result of the operation.
> A_prime = A.ptap(Phi)
> I got
> Traceback (most recent call last):
>   File "/Users/boutsitron/petsc-experiments/mat_vec_multiplication2.py", line 89, in <module>
>   File "petsc4py/PETSc/Mat.pyx", line 1525, in petsc4py.PETSc.Mat.ptap
> petsc4py.PETSc.Error: error code 60
> [0] MatPtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9896
> [0] MatProductSetFromOptions() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:541
> [0] MatProductSetFromOptions_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:435
> [0] MatProductSetFromOptions_MPIAIJ() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2372
> [0] MatProductSetFromOptions_MPIAIJ_PtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2266
> [0] Nonconforming object sizes
> [0] Matrix local dimensions are incompatible, Acol (0, 100) != Prow (0,34)
> Abort(1) on node 0 (rank 0 in comm 496): application called MPI_Abort(PYOP2_COMM_WORLD, 1) - process 0
> [1] MatPtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9896
> [1] MatProductSetFromOptions() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:541
> [1] MatProductSetFromOptions_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:435
> [1] MatProductSetFromOptions_MPIAIJ() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2372
> [1] MatProductSetFromOptions_MPIAIJ_PtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2266
> [1] Nonconforming object sizes
> [1] Matrix local dimensions are incompatible, Acol (100, 200) != Prow (34,67)
> Abort(1) on node 1 (rank 1 in comm 496): application called MPI_Abort(PYOP2_COMM_WORLD, 1) - process 1
> [2] MatPtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9896
> [2] MatProductSetFromOptions() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:541
> [2] MatProductSetFromOptions_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:435
> [2] MatProductSetFromOptions_MPIAIJ() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2372
> [2] MatProductSetFromOptions_MPIAIJ_PtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2266
> [2] Nonconforming object sizes
> [2] Matrix local dimensions are incompatible, Acol (200, 300) != Prow (67,100)
> Abort(1) on node 2 (rank 2 in comm 496): application called MPI_Abort(PYOP2_COMM_WORLD, 1) - process 2
>> On 11 Oct 2023, at 07:18, Pierre Jolivet <pierre at joliv.et> wrote:
>> I disagree with what Mark and Matt are saying: your code is fine, the error message is fine, petsc4py is fine (in this instance).
>> It’s not a typical use case of MatPtAP(), which is mostly designed for MatAIJ, not MatDense.
>> On the one hand, in the MatDense case, indeed there will be a mismatch between the number of columns of A and the number of rows of P, as written in the error message.
>> On the other hand, there is not much to optimize when computing C = P’ A P with everything being dense.
>> I would just write this as B = A P and then C = P’ B (but then you may face the same issue as initially reported, please let us know then).
>> Thanks,
>> Pierre
>>> On 11 Oct 2023, at 2:42 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> This looks like a false positive or there is some subtle bug here that we are not seeing.
>>> Could this be the first time parallel PtAP has been used (and reported) in petsc4py?
>>> Mark
>>> On Tue, Oct 10, 2023 at 8:27 PM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>> On Tue, Oct 10, 2023 at 5:34 PM Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>>> Hi all,
>>>>> Revisiting my code and the proposed solution from Pierre, I realized this works only in sequential. The reason is that PETSc partitions those matrices only row-wise, which leads to an error due to the mismatch between number of columns of A (non-partitioned) and the number of rows of Phi (partitioned).
>>>> Are you positive about this? P^T A P is designed to run in this scenario, so either we have a bug or the diagnosis is wrong.
>>>>   Thanks,
>>>>      Matt
>>>>> import time
>>>>> import numpy as np
>>>>> from colorama import Fore
>>>>> from firedrake import COMM_SELF, COMM_WORLD
>>>>> from mpi4py import MPI
>>>>> from numpy.testing import assert_array_almost_equal
>>>>>     Args:
>>>>>     Returns:
>>>>>     if sparse:
>>>>>     else:
>>>>>     matrix.setUp()
>>>>>         matrix.setValues(
>>>>>     return matrix
>>>>> m, k = 100, 7
>>>>> Print(f"MATRIX Aprime_np [{Aprime_np.shape[0]}x{Aprime_np.shape[1]}]")
>>>>> Print(f"{Aprime_np}")
>>>>> A = create_petsc_matrix(A_np, sparse=False)
>>>>> Phi = create_petsc_matrix(Phi_np, sparse=False)
>>>>> A_prime = create_petsc_matrix(np.zeros((k, k)), sparse=False)
>>>>> Here is the error
>>>>> MATRIX mpiaij A [100x100]
>>>>> Assembled
>>>>> Partitioning for A:
>>>>>   Rank 0: Rows [0, 34)
>>>>>   Rank 1: Rows [34, 67)
>>>>>   Rank 2: Rows [67, 100)
>>>>> MATRIX mpiaij Phi [100x7]
>>>>> Assembled
>>>>> Partitioning for Phi:
>>>>>   File "/Users/boutsitron/work/galerkin_projection.py", line 87, in <module>
>>>>> Any thoughts?
>>>>> Thanks,
>>>>> Thanos
>>>>>> On 5 Oct 2023, at 14:23, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>>>> This works Pierre. Amazing input, thanks a lot!
>>>>>>> On 5 Oct 2023, at 14:17, Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
>>>>>>> Not a petsc4py expert here, but you may to try instead:
>>>>>>> Thanks,
>>>>>>> Pierre
>>>>>>>> On 5 Oct 2023, at 2:02 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>>>>>> Thanks Pierre! So I tried this and got a segmentation fault. Is this supposed to work right off the bat or am I missing sth?
>>>>>>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>>>>> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
>>>>>>>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>>>>>>>> [0]PETSC ERROR: to get more information on the crash.
>>>>>>>> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
>>>>>>>> Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>>>>>> import time
>>>>>>>> import numpy as np
>>>>>>>> from utilities import (
>>>>>>>>     Print,
>>>>>>>>     create_petsc_matrix,
>>>>>>>>     print_matrix_partitioning,
>>>>>>>> m, k = 11, 7
>>>>>>>> Phi.PtAP(A, A_prime)
>>>>>>>>> On 5 Oct 2023, at 13:22, Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
>>>>>>>>> How about using ptap which will use MatPtAP?
>>>>>>>>> It will be more efficient (and it will help you bypass the issue).
>>>>>>>>> Thanks,
>>>>>>>>> Pierre
>>>>>>>>>> On 5 Oct 2023, at 1:18 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>>>>>>>> Sorry, forgot function create_petsc_matrix()
>>>>>>>>>> def create_petsc_matrix(input_array sparse=True):
>>>>>>>>>>     Args:
>>>>>>>>>>     Returns:
>>>>>>>>>>         PETSc mat: PETSc matrix
>>>>>>>>>>     if sparse:
>>>>>>>>>>     else:
>>>>>>>>>>     matrix.setUp()
>>>>>>>>>>         matrix.setValues(
>>>>>>>>>>     return matrix
>>>>>>>>>>> On 5 Oct 2023, at 13:09, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>>>>>>>>> Hi everyone,
>>>>>>>>>>> I am trying a Galerkin projection (see MFE below) and I cannot get the Phi.transposeMatMult(A, A1) work. The error is
>>>>>>>>>>>   File "petsc4py/PETSc/Mat.pyx", line 1514, in petsc4py.PETSc.Mat.transposeMatMult
>>>>>>>>>>> petsc4py.PETSc.Error: error code 56
>>>>>>>>>>> [0] MatTransposeMatMult() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:10135
>>>>>>>>>>> [0] MatProduct_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9989
>>>>>>>>>>> [0] No support for this operation for this object type
>>>>>>>>>>> [0] Call MatProductCreate() first
>>>>>>>>>>> Do you know if these exposed to petsc4py or maybe there is another way? I cannot get the MFE to work (neither in sequential nor in parallel)
>>>>>>>>>>> import time
>>>>>>>>>>> import numpy as np
>>>>>>>>>>>     Print,
>>>>>>>>>>> m, k = 11, 7
>>>>>>>>>>> A = create_petsc_matrix(A_np)
>>>>>>>>>>> Phi = create_petsc_matrix(Phi_np)
>>>>>>>>>>> A1 = create_petsc_matrix(np.zeros((k, m)))
>>>>>>>>>>> # Now A1 contains the result of Phi^T * A
>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231011/17150218/attachment-0001.html>
