[petsc-users] Galerkin projection using petsc4py
Thanasis Boutsikakis
thanasis.boutsikakis at corintis.com
Wed Oct 11 02:13:28 CDT 2023
Very good catch Pierre, thanks a lot!
This made everything work: the two-step process and the ptap(). I mistakenly thought that I should not let the local number of columns to be None, since the matrix is only partitioned row-wise. Could you please explain what happened because of my setting the local column number so that I get the philosophy behind this partitioning?
Thanks again,
Thanos
> On 11 Oct 2023, at 09:04, Pierre Jolivet <pierre at joliv.et> wrote:
> That’s because:
> size = ((None, global_rows), (global_cols, global_cols))
> should be:
> size = ((None, global_rows), (None, global_cols))
> Then, it will work.
> $ ~/repo/petsc/arch-darwin-c-debug-real/bin/mpirun -n 4 python3.12 test.py && echo $?
> 0
> Thanks,
> Pierre
>> On 11 Oct 2023, at 8:58 AM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
>> Pierre, I see your point, but my experiment shows that it does not even run due to size mismatch, so I don’t see how being sparse would change things here. There must be some kind of problem with the parallel ptap(), because it does run sequentially. In order to test that, I changed the flags of the matrix creation to sparse=True and ran it again. Here is the code
>> """Experimenting with PETSc mat-mat multiplication"""
>> import numpy as np
>> from firedrake import COMM_WORLD
>> from firedrake.petsc import PETSc
>> from utilities import Print
>> nproc = COMM_WORLD.size
>> rank = COMM_WORLD.rank
>> def create_petsc_matrix(input_array, sparse=True):
>> """Create a PETSc matrix from an input_array
>> Args:
>> input_array (np array): Input array
>> partition_like (PETSc mat, optional): Petsc matrix. Defaults to None.
>> sparse (bool, optional): Toggle for sparese or dense. Defaults to True.
>> Returns:
>> PETSc mat: PETSc mpi matrix
>> # Check if input_array is 1D and reshape if necessary
>> assert len(input_array.shape) == 2, "Input array should be 2-dimensional"
>> global_rows, global_cols = input_array.shape
>> # Create a sparse or dense matrix based on the 'sparse' argument
>> if sparse:
>> matrix = PETSc.Mat().createAIJ(size=size, comm=COMM_WORLD)
>> else:
>> matrix = PETSc.Mat().createDense(size=size, comm=COMM_WORLD)
>> matrix.setUp()
>> local_rows_start, local_rows_end = matrix.getOwnershipRange()
>> for counter, i in enumerate(range(local_rows_start, local_rows_end)):
>> # Calculate the correct row in the array for the current process
>> row_in_array = counter + local_rows_start
>> matrix.setValues(
>> i, range(global_cols), input_array[row_in_array, :], addv=False
>> # Assembly the matrix to compute the final structure
>> matrix.assemblyBegin()
>> matrix.assemblyEnd()
>> return matrix
>> # EXP: Galerkin projection of an mpi PETSc matrix A with an mpi PETSc matrix Phi
>> # A' = Phi.T * A * Phi
>> # [k x k] <- [k x m] x [m x m] x [m x k]
>> m, k = 100, 7
>> # Generate the random numpy matrices
>> np.random.seed(0) # sets the seed to 0
>> A_np = np.random.randint(low=0, high=6, size=(m, m))
>> Phi_np = np.random.randint(low=0, high=6, size=(m, k))
>> # TEST: Galerking projection of numpy matrices A_np and Phi_np
>> Aprime_np = Phi_np.T @ A_np @ Phi_np
>> # Create A as an mpi matrix distributed on each process
>> A = create_petsc_matrix(A_np, sparse=True)
>> # Create Phi as an mpi matrix distributed on each process
>> Phi = create_petsc_matrix(Phi_np, sparse=True)
>> # Create an empty PETSc matrix object to store the result of the PtAP operation.
>> # This will hold the result A' = Phi.T * A * Phi after the computation.
>> A_prime = create_petsc_matrix(np.zeros((k, k)), sparse=True)
>> # Perform the PtAP (Phi Transpose times A times Phi) operation.
>> # In mathematical terms, this operation is A' = Phi.T * A * Phi.
>> # A_prime will store the result of the operation.
>> A_prime = A.ptap(Phi)
>> I got
>> Traceback (most recent call last):
>> File "/Users/boutsitron/petsc-experiments/mat_vec_multiplication2.py", line 89, in <module>
>> File "petsc4py/PETSc/Mat.pyx", line 1525, in petsc4py.PETSc.Mat.ptap
>> petsc4py.PETSc.Error: error code 60
>> [0] MatPtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9896
>> [0] MatProductSetFromOptions() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:541
>> [0] MatProductSetFromOptions_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:435
>> [0] MatProductSetFromOptions_MPIAIJ() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2372
>> [0] MatProductSetFromOptions_MPIAIJ_PtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2266
>> [0] Nonconforming object sizes
>> [0] Matrix local dimensions are incompatible, Acol (0, 100) != Prow (0,34)
>> Abort(1) on node 0 (rank 0 in comm 496): application called MPI_Abort(PYOP2_COMM_WORLD, 1) - process 0
>> [1] MatPtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9896
>> [1] MatProductSetFromOptions() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:541
>> [1] MatProductSetFromOptions_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:435
>> [1] MatProductSetFromOptions_MPIAIJ() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2372
>> [1] MatProductSetFromOptions_MPIAIJ_PtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2266
>> [1] Nonconforming object sizes
>> [1] Matrix local dimensions are incompatible, Acol (100, 200) != Prow (34,67)
>> Abort(1) on node 1 (rank 1 in comm 496): application called MPI_Abort(PYOP2_COMM_WORLD, 1) - process 1
>> [2] MatPtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9896
>> [2] MatProductSetFromOptions() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:541
>> [2] MatProductSetFromOptions_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:435
>> [2] MatProductSetFromOptions_MPIAIJ() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2372
>> [2] MatProductSetFromOptions_MPIAIJ_PtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2266
>> [2] Nonconforming object sizes
>> [2] Matrix local dimensions are incompatible, Acol (200, 300) != Prow (67,100)
>> Abort(1) on node 2 (rank 2 in comm 496): application called MPI_Abort(PYOP2_COMM_WORLD, 1) - process 2
>>> On 11 Oct 2023, at 07:18, Pierre Jolivet <pierre at joliv.et> wrote:
>>> I disagree with what Mark and Matt are saying: your code is fine, the error message is fine, petsc4py is fine (in this instance).
>>> It’s not a typical use case of MatPtAP(), which is mostly designed for MatAIJ, not MatDense.
>>> On the one hand, in the MatDense case, indeed there will be a mismatch between the number of columns of A and the number of rows of P, as written in the error message.
>>> On the other hand, there is not much to optimize when computing C = P’ A P with everything being dense.
>>> I would just write this as B = A P and then C = P’ B (but then you may face the same issue as initially reported, please let us know then).
>>> Thanks,
>>> Pierre
>>>> On 11 Oct 2023, at 2:42 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> This looks like a false positive or there is some subtle bug here that we are not seeing.
>>>> Could this be the first time parallel PtAP has been used (and reported) in petsc4py?
>>>> Mark
>>>> On Tue, Oct 10, 2023 at 8:27 PM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>>> On Tue, Oct 10, 2023 at 5:34 PM Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>>>> Hi all,
>>>>>> Revisiting my code and the proposed solution from Pierre, I realized this works only in sequential. The reason is that PETSc partitions those matrices only row-wise, which leads to an error due to the mismatch between number of columns of A (non-partitioned) and the number of rows of Phi (partitioned).
>>>>> Are you positive about this? P^T A P is designed to run in this scenario, so either we have a bug or the diagnosis is wrong.
>>>>> Thanks,
>>>>> Matt
>>>>>> import time
>>>>>> import numpy as np
>>>>>> from colorama import Fore
>>>>>> from firedrake import COMM_SELF, COMM_WORLD
>>>>>> from mpi4py import MPI
>>>>>> from numpy.testing import assert_array_almost_equal
>>>>>> Args:
>>>>>> Returns:
>>>>>> if sparse:
>>>>>> else:
>>>>>> matrix.setUp()
>>>>>> matrix.setValues(
>>>>>> return matrix
>>>>>> m, k = 100, 7
>>>>>> Print(f"MATRIX Aprime_np [{Aprime_np.shape[0]}x{Aprime_np.shape[1]}]")
>>>>>> Print(f"{Aprime_np}")
>>>>>> A = create_petsc_matrix(A_np, sparse=False)
>>>>>> Phi = create_petsc_matrix(Phi_np, sparse=False)
>>>>>> A_prime = create_petsc_matrix(np.zeros((k, k)), sparse=False)
>>>>>> Here is the error
>>>>>> MATRIX mpiaij A [100x100]
>>>>>> Assembled
>>>>>> Partitioning for A:
>>>>>> Rank 0: Rows [0, 34)
>>>>>> Rank 1: Rows [34, 67)
>>>>>> Rank 2: Rows [67, 100)
>>>>>> MATRIX mpiaij Phi [100x7]
>>>>>> Assembled
>>>>>> Partitioning for Phi:
>>>>>> File "/Users/boutsitron/work/galerkin_projection.py", line 87, in <module>
>>>>>> Any thoughts?
>>>>>> Thanks,
>>>>>> Thanos
>>>>>>> On 5 Oct 2023, at 14:23, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>>>>> This works Pierre. Amazing input, thanks a lot!
>>>>>>>> On 5 Oct 2023, at 14:17, Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
>>>>>>>> Not a petsc4py expert here, but you may to try instead:
>>>>>>>> Thanks,
>>>>>>>> Pierre
>>>>>>>>> On 5 Oct 2023, at 2:02 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>>>>>>> Thanks Pierre! So I tried this and got a segmentation fault. Is this supposed to work right off the bat or am I missing sth?
>>>>>>>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>>>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>>>>>> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
>>>>>>>>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>>>>>>>>> [0]PETSC ERROR: to get more information on the crash.
>>>>>>>>> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
>>>>>>>>> Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>>>>>>> import time
>>>>>>>>> import numpy as np
>>>>>>>>> from utilities import (
>>>>>>>>> Print,
>>>>>>>>> create_petsc_matrix,
>>>>>>>>> print_matrix_partitioning,
>>>>>>>>> m, k = 11, 7
>>>>>>>>> Phi.PtAP(A, A_prime)
>>>>>>>>>> On 5 Oct 2023, at 13:22, Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
>>>>>>>>>> How about using ptap which will use MatPtAP?
>>>>>>>>>> It will be more efficient (and it will help you bypass the issue).
>>>>>>>>>> Thanks,
>>>>>>>>>> Pierre
>>>>>>>>>>> On 5 Oct 2023, at 1:18 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>>>>>>>>> Sorry, forgot function create_petsc_matrix()
>>>>>>>>>>> def create_petsc_matrix(input_array sparse=True):
>>>>>>>>>>> Args:
>>>>>>>>>>> Returns:
>>>>>>>>>>> PETSc mat: PETSc matrix
>>>>>>>>>>> if sparse:
>>>>>>>>>>> else:
>>>>>>>>>>> matrix.setUp()
>>>>>>>>>>> matrix.setValues(
>>>>>>>>>>> return matrix
>>>>>>>>>>>> On 5 Oct 2023, at 13:09, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>>>>>>>>>> Hi everyone,
>>>>>>>>>>>> I am trying a Galerkin projection (see MFE below) and I cannot get the Phi.transposeMatMult(A, A1) work. The error is
>>>>>>>>>>>> File "petsc4py/PETSc/Mat.pyx", line 1514, in petsc4py.PETSc.Mat.transposeMatMult
>>>>>>>>>>>> petsc4py.PETSc.Error: error code 56
>>>>>>>>>>>> [0] MatTransposeMatMult() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:10135
>>>>>>>>>>>> [0] MatProduct_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9989
>>>>>>>>>>>> [0] No support for this operation for this object type
>>>>>>>>>>>> [0] Call MatProductCreate() first
>>>>>>>>>>>> Do you know if these exposed to petsc4py or maybe there is another way? I cannot get the MFE to work (neither in sequential nor in parallel)
>>>>>>>>>>>> import time
>>>>>>>>>>>> import numpy as np
>>>>>>>>>>>> Print,
>>>>>>>>>>>> m, k = 11, 7
>>>>>>>>>>>> A = create_petsc_matrix(A_np)
>>>>>>>>>>>> Phi = create_petsc_matrix(Phi_np)
>>>>>>>>>>>> A1 = create_petsc_matrix(np.zeros((k, m)))
>>>>>>>>>>>> # Now A1 contains the result of Phi^T * A
>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231011/b85869ef/attachment-0001.html>
