[petsc-users] Segmentation Violation error using SuperLU_DIST in ex 19.c
maitri ksh maitri.ksh at gmail.com
Sat Nov 25 03:44:27 CST 2023
ok, thanks.
On Fri, Nov 24, 2023 at 10:16 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Do you really need this combination of pkgs?
> Matlab is distributed with ILP64 MKL - so it doesn't really work with
> LP64 blas/lapack that most external packages require - i.e you can't
> really use use matlab and other external-packages.
> [also it might not work with complex]
> To get a successful matlab build - try:
> ./configure PETSC_ARCH=arch-linux-matlab --download-mpich
> --with-matlab-dir=/usr/local/matlab --with-matlab-engine=1
> --with-blaslapack-dir=/usr/local/matlab --known-64-bit-blas-indices=1
> Satish
> On Fri, 24 Nov 2023, maitri ksh wrote:
> > Hi Satish,
> > Yes, that simple build works with no error. I configured petsc again with
> > the configure options:
> >  PETSC_ARCH=linux-gnu-c-debug -start-in-debugger[noxterm]
> > --with-cc=/usr/local/gcc11/bin/gcc --with-cxx=/usr/local/gcc11/bin/g++
> > --with-fc=gfortran --with-debugging=1 --with-scalar-type=complex
> > --download-mpich --download-fblaslapack
> > --download-superlu --download-superlu_dist --download-hdf5
> --download-mumps
> > --download-scalapack --download--parmetis --download-metis
> > --download-ptscotch --download-bison --download-cmake --download-make
> > Now, it runs the superLU_dist test successfully but it gives an error
> with
> > MATLAB engine 'Possible error running C/C++ src/vec/vec/tutorials/ex31
> with
> > MATLAB engine' and also an error with MAKE check.
> > On Thu, Nov 23, 2023 at 10:26 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > Can you do a simple build with only superlu-dist and see if the error
> > > persists?
> > > ./configure PETSC_ARCH=linux-slu --with-cc=/usr/local/gcc11/bin/gcc
> > > --with-cxx=/usr/local/gcc11/bin/g++ --with-fc=gfortran
> --with-debugging=1
> > > --with-scalar-type=complex --download-mpich --download-fblaslapack
> > > make
> > > make PETSC_ARCH=linux-slu check
> > > Satish
> > > On Thu, 23 Nov 2023, maitri ksh wrote:
> > > > Hi,
> > > > I ran into an error while using SuperLU_DIST in ex 19.c, I am not
> sure
> > > how
> > > > to debug this, can anyone please help. The 'configure.log' file is
> > > attached
> > > > for your reference.
> > > > Thanks,
> > > > Maitri
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231125/7bd056f7/attachment.html>
