[petsc-users] Segmentation Violation error using SuperLU_DIST in ex 19.c
Barry Smith
bsmith at petsc.dev
Thu Nov 23 11:18:48 CST 2023
Try option -start_in_debugger noxterm
then when the debugger starts up
c
to continue the run. Then when the program crashes you can do
bt
to see exactly where the crash happens in SuperLU_DIST
and
print "some variable name in the routine"
to check if the variables there look reasonable or if memory looks corrupted.
You can also run with valgrind to check for memory corruption. https://petsc.org/release/faq/#what-does-corrupt-argument-or-caught-signal-or-segv-or-segmentation-violation-or-bus-error-mean-can-i-use-valgrind-or-cuda-memcheck-to-debug-memory-corruption-issues
> On Nov 23, 2023, at 11:38 AM, maitri ksh <maitri.ksh at gmail.com> wrote:
> Hi,
> I ran into an error while using SuperLU_DIST in ex 19.c, I am not sure how to debug this, can anyone please help. The 'configure.log' file is attached for your reference.
> Thanks,
> Maitri
> <ERROR_ex19_SuperLU_DIST.txt><configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231123/ab73ae44/attachment.html>
