[petsc-users] Segmentation Violation error using SuperLU_DIST in ex 19.c
Fri Nov 24 10:46:30 CST 2023
Do you really need this combination of pkgs?
Matlab is distributed with ILP64 MKL - so it doesn't really work with
LP64 blas/lapack that most external packages require - i.e you can't
really use use matlab and other external-packages.
[also it might not work with complex]
To get a successful matlab build - try:
./configure PETSC_ARCH=arch-linux-matlab --download-mpich --with-matlab-dir=/usr/local/matlab --with-matlab-engine=1 --with-blaslapack-dir=/usr/local/matlab --known-64-bit-blas-indices=1
Satish
On Fri, 24 Nov 2023, maitri ksh wrote:
> Hi Satish,
> Yes, that simple build works with no error. I configured petsc again with
> the configure options:
>  PETSC_ARCH=linux-gnu-c-debug -start-in-debugger[noxterm]
> --with-cc=/usr/local/gcc11/bin/gcc --with-cxx=/usr/local/gcc11/bin/g++
> --with-fc=gfortran --with-debugging=1 --with-scalar-type=complex
> --download-mpich --download-fblaslapack --with-matlab-dir=/usr/local/matlab
> --download-superlu --download-superlu_dist --download-hdf5 --download-mumps
> --download-scalapack --download--parmetis --download-metis
> --download-ptscotch --download-bison --download-cmake --download-make
> Now, it runs the superLU_dist test successfully but it gives an error with
> MATLAB engine 'Possible error running C/C++ src/vec/vec/tutorials/ex31 with
> MATLAB engine' and also an error with MAKE check.
> On Thu, Nov 23, 2023 at 10:26 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > Can you do a simple build with only superlu-dist and see if the error
> > persists?
> > ./configure PETSC_ARCH=linux-slu --with-cc=/usr/local/gcc11/bin/gcc
> > --with-cxx=/usr/local/gcc11/bin/g++ --with-fc=gfortran --with-debugging=1
> > --with-scalar-type=complex --download-mpich --download-fblaslapack
> > make
> > make PETSC_ARCH=linux-slu check
> > Satish
> > On Thu, 23 Nov 2023, maitri ksh wrote:
> > > Hi,
> > > I ran into an error while using SuperLU_DIST in ex 19.c, I am not sure
> > how
> > > to debug this, can anyone please help. The 'configure.log' file is
> > attached
> > > for your reference.
> > > Thanks,
> > > Maitri
