[petsc-users] Segmentation Violation error using SuperLU_DIST in ex 19.c
maitri ksh
maitri.ksh at gmail.com
Fri Nov 24 00:59:17 CST 2023
ok, thanks
On Thu, Nov 23, 2023 at 10:49 PM Barry Smith <bsmith at petsc.dev> wrote:
> Try option -start_in_debugger noxterm
> then when the debugger starts up
> c
> to continue the run. Then when the program crashes you can do
> bt
> to see exactly where the crash happens in SuperLU_DIST
> and
> print "some variable name in the routine"
> to check if the variables there look reasonable or if memory looks
> corrupted.
> You can also run with valgrind to check for memory corruption.
> https://petsc.org/release/faq/#what-does-corrupt-argument-or-caught-signal-or-segv-or-segmentation-violation-or-bus-error-mean-can-i-use-valgrind-or-cuda-memcheck-to-debug-memory-corruption-issues
> On Nov 23, 2023, at 11:38 AM, maitri ksh <maitri.ksh at gmail.com> wrote:
> Hi,
> I ran into an error while using SuperLU_DIST in ex 19.c, I am not sure how
> to debug this, can anyone please help. The 'configure.log' file is attached
> for your reference.
> Thanks,
> Maitri
> <ERROR_ex19_SuperLU_DIST.txt><configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231124/2836c355/attachment.html>
