[petsc-users] Error running make check with OneAPI C/C++ and Fortran compilers on Windows
Barry Smith
bsmith at petsc.dev
Fri Nov 17 14:41:39 CST 2023
OneAPI has two sets of compilers, old icc and new icx.
Does it fail in this way for both? Can you try with the old?
> On Nov 17, 2023, at 12:59 PM, Maruthi NH <maruthinh at gmail.com> wrote:
> Hi Barry,
> It doesn't even start to run, I still get the same error. This is all the output I get.
> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> = RANK 0 PID 28192 RUNNING AT BLRLAP1521
> = EXIT STATUS: -1073741819 (c0000005)
> With Windows C compiler and Intel OneAPI Fortran, it works fine. But when I use the OneAPI C/C++ compiler it fails.
> Regards,
> Maruthi
> On Fri, Nov 17, 2023 at 11:25 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>> Please run
>> mpiexec -n 1 ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres -info
>> and send all the output
>>> On Nov 17, 2023, at 12:14 PM, Maruthi NH <maruthinh at gmail.com <mailto:maruthinh at gmail.com>> wrote:
>>> Hi Barry,
>>> I get the following error.
>>> ngh at ngh1 ~/petsc/src/snes/tutorials
>>> $ make ex19
>>> /home/ngh/petsc/lib/petsc/bin/win32fe/win32fe icl -Qwd10161 -Qstd=c99 -MT -O3 -I/home/ngh/petsc/include -I/home/ngh/petsc/intel-petsc-tag-v3.20.1/include -I/cygdrive/c/PROGRA~2/Intel/oneAPI/mpi/2021.6.0/include ex19.c -L/home/ngh/petsc/intel-petsc-tag-v3.20.1/lib -L/cygdrive/c/PROGRA~2/Intel/oneAPI/mkl/2022.1.0/lib/intel64 -lpetsc mkl_intel_lp64_dll.lib mkl_sequential_dll.lib mkl_core_dll.lib /cygdrive/c/PROGRA~2/Intel/oneAPI/mpi/2021.6.0/lib/release/impi.lib Gdi32.lib User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o ex19
>>> ex19.c
>>> $ mpiexec -n 1 ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres
>>> = RANK 0 PID 1768 RUNNING AT ngh1
>>> $ mpiexec -n 2 ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres
>>> = RANK 0 PID 25936 RUNNING AT ngh1
>>> = RANK 1 PID 5216 RUNNING AT ngh1
>>> Regards,
>>> Maruthi
>>> On Fri, Nov 17, 2023 at 9:26 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>> Please do
>>>> cd src/snes/tutorials
>>>> make ex19
>>>> then with -n 2
>>>> Cut and paste all the output and include it in your email response
>>>> Barry
>>>>> On Nov 17, 2023, at 12:57 AM, Maruthi NH <maruthinh at gmail.com <mailto:maruthinh at gmail.com>> wrote:
>>>>> Hi all,
>>>>> I could successfully compile PETSc on Windows with Intel OneAPI C/C++ and Fortran compilers, however, when I tried to make a check after the successful installation, I got the following error message. I have also attached the configuration file.
>>>>> make PETSC_DIR=/home/ngh/petsc PETSC_ARCH=intel-petsc-tag-v3.20.1 check
>>>>> Running PETSc check examples to verify correct installation
>>>>> Using PETSC_DIR=/home/ngh/petsc and PETSC_ARCH=intel-petsc-tag-v3.20.1
>>>>> Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
>>>>> See https://petsc.org/release/faq/
>>>>> = RANK 0 PID 13384 RUNNING AT BLRLAP1521
>>>>> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
>>>>> = RANK 0 PID 20616 RUNNING AT BLRLAP1521
>>>>> = RANK 1 PID 16900 RUNNING AT BLRLAP1521
>>>>> Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process
>>>>> forrtl: severe (157): Program Exception - access violation
>>>>> Image PC Routine Line Source
>>>>> ex5f.exe 00007FF661DB569B Unknown Unknown Unknown
>>>>> ex5f.exe 00007FF661A760AF Unknown Unknown Unknown
>>>>> ex5f.exe 00007FF6619E6EBD Unknown Unknown Unknown
>>>>> ex5f.exe 00007FF6619C6294 Unknown Unknown Unknown
>>>>> ex5f.exe 00007FF6619C3152 Unknown Unknown Unknown
>>>>> ex5f.exe 00007FF6619C1051 Unknown Unknown Unknown
>>>>> ex5f.exe 00007FF662C3C16E Unknown Unknown Unknown
>>>>> ex5f.exe 00007FF662C3CA50 Unknown Unknown Unknown
>>>>> KERNEL32.DLL 00007FFB12187344 Unknown Unknown Unknown
>>>>> ntdll.dll 00007FFB140C26B1 Unknown Unknown Unknown
>>>>> Completed PETSc check examples
>>>>> Error while running make check
>>>>> make[1]: *** [makefile:132: check] Error 1
>>>>> make: *** [GNUmakefile:17: check] Error 2
>>>>> Regards,
>>>>> mnh
>>>>> <intel-petsc-tag-v3.20.1.py <http://intel-petsc-tag-v3.20.1.py/>>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231117/8b19d5c3/attachment.html>
