[petsc-users] Error running make check with OneAPI C/C++ and Fortran compilers on Windows
Maruthi NH
maruthinh at gmail.com
Fri Nov 17 11:59:42 CST 2023
Hi Barry,
It doesn't even start to run, I still get the same error. This is all the
output I get.
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 28192 RUNNING AT BLRLAP1521
= EXIT STATUS: -1073741819 (c0000005)
With Windows C compiler and Intel OneAPI Fortran, it works fine. But when I
use the OneAPI C/C++ compiler it fails.
Maruthi
On Fri, Nov 17, 2023 at 11:25 PM Barry Smith <bsmith at petsc.dev> wrote:
> Please run
> mpiexec -n 1 ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres -info
> and send all the output
> On Nov 17, 2023, at 12:14 PM, Maruthi NH <maruthinh at gmail.com> wrote:
> Hi Barry,
> I get the following error.
> ngh at ngh1 ~/petsc/src/snes/tutorials
> $ make ex19
> /home/ngh/petsc/lib/petsc/bin/win32fe/win32fe icl -Qwd10161 -Qstd=c99 -MT
> -O3 -I/home/ngh/petsc/include
> -I/home/ngh/petsc/intel-petsc-tag-v3.20.1/include
> -I/cygdrive/c/PROGRA~2/Intel/oneAPI/mpi/2021.6.0/include ex19.c
> -L/home/ngh/petsc/intel-petsc-tag-v3.20.1/lib
> -L/cygdrive/c/PROGRA~2/Intel/oneAPI/mkl/2022.1.0/lib/intel64 -lpetsc
> mkl_intel_lp64_dll.lib mkl_sequential_dll.lib mkl_core_dll.lib
> /cygdrive/c/PROGRA~2/Intel/oneAPI/mpi/2021.6.0/lib/release/impi.lib
> Gdi32.lib User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o ex19
> ex19.c
> $ mpiexec -n 1 ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres
> = RANK 0 PID 1768 RUNNING AT ngh1
> $ mpiexec -n 2 ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres
> = RANK 0 PID 25936 RUNNING AT ngh1
> = RANK 1 PID 5216 RUNNING AT ngh1
> Regards,
> Maruthi
> On Fri, Nov 17, 2023 at 9:26 PM Barry Smith <bsmith at petsc.dev> wrote:
>> Please do
>> cd src/snes/tutorials
>> make ex19
>> then with -n 2
>> Cut and paste all the output and include it in your email response
>> Barry
>> On Nov 17, 2023, at 12:57 AM, Maruthi NH <maruthinh at gmail.com> wrote:
>> Hi all,
>> I could successfully compile PETSc on Windows with Intel OneAPI C/C++ and
>> Fortran compilers, however, when I tried to make a check after the
>> successful installation, I got the following error message. I have also
>> attached the configuration file.
>> make PETSC_DIR=/home/ngh/petsc PETSC_ARCH=intel-petsc-tag-v3.20.1 check
>> Running PETSc check examples to verify correct installation
>> Using PETSC_DIR=/home/ngh/petsc and PETSC_ARCH=intel-petsc-tag-v3.20.1
>> Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
>> See https://petsc.org/release/faq/
>> = RANK 0 PID 13384 RUNNING AT BLRLAP1521
>> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
>> = RANK 0 PID 20616 RUNNING AT BLRLAP1521
>> = RANK 1 PID 16900 RUNNING AT BLRLAP1521
>> Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI
>> process
>> forrtl: severe (157): Program Exception - access violation
>> Image PC Routine Line Source
>> ex5f.exe 00007FF661DB569B Unknown Unknown
>> Unknown
>> ex5f.exe 00007FF661A760AF Unknown Unknown
>> Unknown
>> ex5f.exe 00007FF6619E6EBD Unknown Unknown
>> Unknown
>> ex5f.exe 00007FF6619C6294 Unknown Unknown
>> Unknown
>> ex5f.exe 00007FF6619C3152 Unknown Unknown
>> Unknown
>> ex5f.exe 00007FF6619C1051 Unknown Unknown
>> Unknown
>> ex5f.exe 00007FF662C3C16E Unknown Unknown
>> Unknown
>> ex5f.exe 00007FF662C3CA50 Unknown Unknown
>> Unknown
>> KERNEL32.DLL 00007FFB12187344 Unknown Unknown
>> Unknown
>> ntdll.dll 00007FFB140C26B1 Unknown Unknown
>> Unknown
>> Completed PETSc check examples
>> Error while running make check
>> make[1]: *** [makefile:132: check] Error 1
>> make: *** [GNUmakefile:17: check] Error 2
>> Regards,
>> mnh
>> <intel-petsc-tag-v3.20.1.py>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231117/819a798f/attachment.html>
