[petsc-users] Error running make check with OneAPI C/C++ and Fortran compilers on Windows
Maruthi NH maruthinh at gmail.com
Sun Nov 19 22:37:19 CST 2023
Hi Barry,
I have tried with icc 2021.6.0. I will try with icx and check.
Maruthi
On Sat, Nov 18, 2023 at 2:11 AM Barry Smith <bsmith at petsc.dev> wrote:
>   OneAPI has two sets of compilers, old icc and new icx.
>   Does it fail in this way for both? Can you try with the old?
> On Nov 17, 2023, at 12:59 PM, Maruthi NH <maruthinh at gmail.com> wrote:
> Hi Barry,
> It doesn't even start to run, I still get the same error. This is all the
> output I get.
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   RANK 0 PID 28192 RUNNING AT BLRLAP1521
> =   EXIT STATUS: -1073741819 (c0000005)
> With Windows C compiler and Intel OneAPI Fortran, it works fine. But when
> I use the OneAPI C/C++ compiler it fails.
> Regards,
> Maruthi
> On Fri, Nov 17, 2023 at 11:25 PM Barry Smith <bsmith at petsc.dev> wrote:
>>   Please run
>> mpiexec -n 1 ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres -info
>> and send all the output
>> On Nov 17, 2023, at 12:14 PM, Maruthi NH <maruthinh at gmail.com> wrote:
>> Hi Barry,
>> I get the following error.
>> ngh at ngh1 ~/petsc/src/snes/tutorials
>> $ make ex19
>> /home/ngh/petsc/lib/petsc/bin/win32fe/win32fe icl -Qwd10161  -Qstd=c99
>> -MT -O3  -I/home/ngh/petsc/include
>> -I/home/ngh/petsc/intel-petsc-tag-v3.20.1/include
>> -I/cygdrive/c/PROGRA~2/Intel/oneAPI/mpi/2021.6.0/include      ex19.c
>>  -L/home/ngh/petsc/intel-petsc-tag-v3.20.1/lib
>> -L/cygdrive/c/PROGRA~2/Intel/oneAPI/mkl/2022.1.0/lib/intel64 -lpetsc
>> mkl_intel_lp64_dll.lib mkl_sequential_dll.lib mkl_core_dll.lib
>> /cygdrive/c/PROGRA~2/Intel/oneAPI/mpi/2021.6.0/lib/release/impi.lib
>> Gdi32.lib User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o ex19
>> ex19.c
>> $   mpiexec -n 1 ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres
>> =   RANK 0 PID 1768 RUNNING AT ngh1
>> $   mpiexec -n 2 ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres
>> =   RANK 0 PID 25936 RUNNING AT ngh1
>> =   RANK 1 PID 5216 RUNNING AT ngh1
>> Regards,
>> Maruthi
>> On Fri, Nov 17, 2023 at 9:26 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>   Please do
>>>   cd src/snes/tutorials
>>>   make ex19
>>>   then with -n 2
>>>   Cut and paste all the output and include it in your email response
>>>    Barry
>>> On Nov 17, 2023, at 12:57 AM, Maruthi NH <maruthinh at gmail.com> wrote:
>>> Hi all,
>>> I could successfully compile PETSc on Windows with Intel OneAPI C/C++
>>> and Fortran compilers, however, when I tried to make a check after the
>>> successful installation, I got the following error message. I have also
>>> attached the configuration file.
>>> make PETSC_DIR=/home/ngh/petsc PETSC_ARCH=intel-petsc-tag-v3.20.1 check
>>> Running PETSc check examples to verify correct installation
>>> Using PETSC_DIR=/home/ngh/petsc and PETSC_ARCH=intel-petsc-tag-v3.20.1
>>> Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
>>> See https://petsc.org/release/faq/
>>> =   RANK 0 PID 13384 RUNNING AT BLRLAP1521
>>> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
>>> =   RANK 0 PID 20616 RUNNING AT BLRLAP1521
>>> =   RANK 1 PID 16900 RUNNING AT BLRLAP1521
>>> Possible error running Fortran example src/snes/tutorials/ex5f with 1
>>> MPI process
>>> forrtl: severe (157): Program Exception - access violation
>>> Image              PC                Routine            Line
>>>  Source
>>> ex5f.exe           00007FF661DB569B  Unknown               Unknown
>>>  Unknown
>>> ex5f.exe           00007FF661A760AF  Unknown               Unknown
>>>  Unknown
>>> ex5f.exe           00007FF6619E6EBD  Unknown               Unknown
>>>  Unknown
>>> ex5f.exe           00007FF6619C6294  Unknown               Unknown
>>>  Unknown
>>> ex5f.exe           00007FF6619C3152  Unknown               Unknown
>>>  Unknown
>>> ex5f.exe           00007FF6619C1051  Unknown               Unknown
>>>  Unknown
>>> ex5f.exe           00007FF662C3C16E  Unknown               Unknown
>>>  Unknown
>>> ex5f.exe           00007FF662C3CA50  Unknown               Unknown
>>>  Unknown
>>> KERNEL32.DLL       00007FFB12187344  Unknown               Unknown
>>>  Unknown
>>> ntdll.dll          00007FFB140C26B1  Unknown               Unknown
>>>  Unknown
>>> Completed PETSc check examples
>>> Error while running make check
>>> make[1]: *** [makefile:132: check] Error 1
>>> make: *** [GNUmakefile:17: check] Error 2
>>> Regards,
>>> mnh
>>> <intel-petsc-tag-v3.20.1.py>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231120/ca4f42dc/attachment-0001.html>
