[petsc-users] Error running make check with OneAPI C/C++ and Fortran compilers on Windows
Barry Smith bsmith at petsc.dev
Fri Nov 17 11:54:52 CST 2023
  Please run
mpiexec -n 1 ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres -info
and send all the output
> On Nov 17, 2023, at 12:14 PM, Maruthi NH <maruthinh at gmail.com> wrote:
> Hi Barry,
> I get the following error.
> ngh at ngh1 ~/petsc/src/snes/tutorials
> $ make ex19
> /home/ngh/petsc/lib/petsc/bin/win32fe/win32fe icl -Qwd10161  -Qstd=c99 -MT -O3  -I/home/ngh/petsc/include -I/home/ngh/petsc/intel-petsc-tag-v3.20.1/include -I/cygdrive/c/PROGRA~2/Intel/oneAPI/mpi/2021.6.0/include      ex19.c  -L/home/ngh/petsc/intel-petsc-tag-v3.20.1/lib -L/cygdrive/c/PROGRA~2/Intel/oneAPI/mkl/2022.1.0/lib/intel64 -lpetsc mkl_intel_lp64_dll.lib mkl_sequential_dll.lib mkl_core_dll.lib /cygdrive/c/PROGRA~2/Intel/oneAPI/mpi/2021.6.0/lib/release/impi.lib Gdi32.lib User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o ex19
> ex19.c
> $   mpiexec -n 1 ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   RANK 0 PID 1768 RUNNING AT ngh1
> =   EXIT STATUS: -1073741819 (c0000005)
> $   mpiexec -n 2 ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres
> =   RANK 0 PID 25936 RUNNING AT ngh1
> =   RANK 1 PID 5216 RUNNING AT ngh1
> Regards,
> Maruthi
> On Fri, Nov 17, 2023 at 9:26 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>   Please do
>>   cd src/snes/tutorials
>>   make ex19
>>   then with -n 2
>>   Cut and paste all the output and include it in your email response
>>    Barry
>>> On Nov 17, 2023, at 12:57 AM, Maruthi NH <maruthinh at gmail.com <mailto:maruthinh at gmail.com>> wrote:
>>> Hi all,
>>> I could successfully compile PETSc on Windows with Intel OneAPI C/C++ and Fortran compilers, however, when I tried to make a check after the successful installation, I got the following error message. I have also attached the configuration file.
>>> make PETSC_DIR=/home/ngh/petsc PETSC_ARCH=intel-petsc-tag-v3.20.1 check
>>> Running PETSc check examples to verify correct installation
>>> Using PETSC_DIR=/home/ngh/petsc and PETSC_ARCH=intel-petsc-tag-v3.20.1
>>> Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
>>> See https://petsc.org/release/faq/
>>> =   RANK 0 PID 13384 RUNNING AT BLRLAP1521
>>> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
>>> =   RANK 0 PID 20616 RUNNING AT BLRLAP1521
>>> =   RANK 1 PID 16900 RUNNING AT BLRLAP1521
>>> Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process
>>> forrtl: severe (157): Program Exception - access violation
>>> Image              PC                Routine            Line        Source
>>> ex5f.exe           00007FF661DB569B  Unknown               Unknown  Unknown
>>> ex5f.exe           00007FF661A760AF  Unknown               Unknown  Unknown
>>> ex5f.exe           00007FF6619E6EBD  Unknown               Unknown  Unknown
>>> ex5f.exe           00007FF6619C6294  Unknown               Unknown  Unknown
>>> ex5f.exe           00007FF6619C3152  Unknown               Unknown  Unknown
>>> ex5f.exe           00007FF6619C1051  Unknown               Unknown  Unknown
>>> ex5f.exe           00007FF662C3C16E  Unknown               Unknown  Unknown
>>> ex5f.exe           00007FF662C3CA50  Unknown               Unknown  Unknown
>>> KERNEL32.DLL       00007FFB12187344  Unknown               Unknown  Unknown
>>> ntdll.dll          00007FFB140C26B1  Unknown               Unknown  Unknown
>>> Completed PETSc check examples
>>> Error while running make check
>>> make[1]: *** [makefile:132: check] Error 1
>>> make: *** [GNUmakefile:17: check] Error 2
>>> Regards,
>>> mnh
>>> <intel-petsc-tag-v3.20.1.py <http://intel-petsc-tag-v3.20.1.py/>>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231117/58dc5bdb/attachment.html>
