[petsc-users] Petsc DMLabel Fortran Stub request
    Nicholas Arnold-Medabalimi
    narnoldm at umich.edu
    Tue Mar 28 14:28:53 CDT 2023
Hi Matthew
Thanks for checking in on this. Fortunately, I was able to get the behavior
I needed through alternate means so I probably wouldn't investigate doing
this further.
Sincerely
Nicholas
On Mon, Mar 27, 2023 at 8:49 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jan 6, 2023 at 10:03 AM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Hi Petsc Users
> I apologize. I found this email today and it looks like no one answered.
>> I am trying to use the sequence of
>> call DMLabelPropagateBegin(synchLabel,sf,ierr)
>> call
>> DMLabelPropagatePush(synchLabel,sf,PETSC_NULL_OPTIONS,PETSC_NULL_INTEGER,ierr)
>> call DMLabelPropagateEnd(synchLabel,sf, ierr)
>> in fortran.
>> I apologize if I messed something up, it appears as if the
>> DMLabelPropagatePush command doesn't have an appropriate Fortran interface
>> as I get an undefined reference when it is called.
> Yes, it takes a function pointer, and using function pointers with Fortran
> is not easy, although it can be done. It might be better to create a C
> function with some default marking and then wrap that. What do you want to
> do?
>   Thanks,
>      Matt
>> I would appreciate any assistance.
>> As a side note in practice, what is the proper Fortran NULL pointer to
>> use for void arguments? I used an integer one temporarily to get to the
>> undefined reference error but I assume it doesn't matter?
>> Sincerely
>> Nicholas
>> Ph.D. Candidate
>> Computational Aeroscience Lab
>> University of Michigan
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230328/d4556dd1/attachment-0001.html>
