[petsc-users] Using PETSc Testing System
    Jed Brown
    jed at jedbrown.org
    Tue Mar 28 12:27:58 CDT 2023
Great that you got it working. We would accept a merge request that made our infrastructure less PETSc-specific so long as it doesn't push more complexity on the end user. That would likely make it easier for you to pull updates in the future.
Daniele Prada <daniele.prada85 at gmail.com> writes:
> Dear Matthew, dear Jacob,
> Thank you very much for your useful remarks. I managed to use the PETSc
> Testing System by doing as follows:
> 1. Redefined TESTDIR when running make
> 2. Used a project tree similar to that of PETSc. For examples, tests for
> 'package1' are in $MYLIB/src/package1/tests/
> 3. cp $PETSC_DIR/gmakefile.test $MYLIB/gmakefile.test
> Inside gmakefile.test:
> 4. Right AFTER "-include petscdir.mk" added "-include mylib.mk" to have
> $MYLIB exported (note: this affects TESTSRCDIR)
> 5. Redefined variable pkgs as "pkgs := package1"
> 6. Introduced a few variables to make PETSC_COMPILE.c work:
> CFLAGS := -I$(MYLIB)/include
> LDFLAGS = -L$(MYLIB)/lib
> LDLIBS = -lmylib
> 7. Changed the call to gmakegentest.py as follows
> $(PYTHON) $(CONFIGDIR)/gmakegentest.py --petsc-dir=$(PETSC_DIR)
> --petsc-arch=$(PETSC_ARCH) --testdir=$(TESTDIR) --srcdir=$(MYLIB)/src
> --pkg-pkgs=$(pkgs)
> 8. Changed the rule $(testexe.c) as follows:
> $(call quiet,CLINKER) $(EXEFLAGS) $(LDFLAGS) -o $@ $^ $(PETSC_TEST_LIB)
> $(LDLIBS)
> 9. Added the option --srcdir=$(TESTSRCDIR) and set --petsc-dir=$(MYLIB)
> when calling query_tests.py, for example:
> TESTTARGETS := $(shell $(PYTHON) $(CONFIGDIR)/query_tests.py
> --srcdir=$(TESTSRCDIR) --testdir=$(TESTDIR) --petsc-dir=$(MYLIB)
> --petsc-arch=$(PETSC_ARCH) --searchin=$(searchin) 'name' '$(search)')
> What do you think?
> Best,
> Daniele
> On Mon, Mar 27, 2023 at 4:38 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Mar 27, 2023 at 10:19 AM Jacob Faibussowitsch <jacob.fai at gmail.com>
>> wrote:
>>> Our testing framework was pretty much tailor-made for the PETSc src tree
>>> and as such has many hard-coded paths and decisions. I’m going to go out on
>>> a limb and say you probably won’t get this to work...
>> I think we can help you get this to work. I have wanted to generalize the
>> test framework for a long time. Everything is build by
>>   confg/gmakegentest.py
>> and I think we can get away with just changing paths here and everything
>> will work.
>>   Thanks!
>>      Matt
>>> That being said, one of the “base” paths that the testing harness uses to
>>> initially find tests is the `TESTSRCDIR` variable in
>>> `${PETSC_DIR}/gmakefile.test`. It is currently defined as
>>> # TESTSRCDIR is always relative to gmakefile.test
>>> #  This must be before includes
>>> mkfile_path := $(abspath $(lastword $(MAKEFILE_LIST)))
>>> TESTSRCDIR := $(dir $(mkfile_path))src
>>> You should start by changing this to
>>> TESTSRCDIR ?= $(dir $(mkfile_path))src
>>> That way you could run your tests via
>>> $ make test TESTSRCDIR=/path/to/your/src/dir
>>> I am sure there are many other modifications you will need to make.
>>> Best regards,
>>> (Jacob Fai - booss - oh - vitch)
>>> > On Mar 27, 2023, at 06:14, Daniele Prada <daniele.prada85 at gmail.com>
>>> wrote:
>>> > Hello everyone,
>>> > I would like to use the PETSc Testing System for testing a package that
>>> I am developing.
>>> > I have read the PETSc developer documentation and have written some
>>> tests using the PETSc Test Description Language. I am going through the
>>> files in ${PETSC_DIR}/config but I am not able to make the testing system
>>> look into the directory tree of my project.
>>> > Any suggestions?
>>> > Thanks in advance
>>> > Daniele
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
