[petsc-users] Using PETSc Testing System
Daniele Prada daniele.prada85 at gmail.com
Tue Mar 28 16:51:38 CDT 2023
Will do, thanks!
On Tue, Mar 28, 2023 at 7:28 PM Jed Brown <jed at jedbrown.org> wrote:
> Great that you got it working. We would accept a merge request that made
> our infrastructure less PETSc-specific so long as it doesn't push more
> complexity on the end user. That would likely make it easier for you to
> pull updates in the future.
> Daniele Prada <daniele.prada85 at gmail.com> writes:
> > Dear Matthew, dear Jacob,
> > Thank you very much for your useful remarks. I managed to use the PETSc
> > Testing System by doing as follows:
> > 1. Redefined TESTDIR when running make
> > 2. Used a project tree similar to that of PETSc. For examples, tests for
> > 'package1' are in $MYLIB/src/package1/tests/
> > 3. cp $PETSC_DIR/gmakefile.test $MYLIB/gmakefile.test
> > Inside gmakefile.test:
> > 4. Right AFTER "-include petscdir.mk" added "-include mylib.mk" to have
> > $MYLIB exported (note: this affects TESTSRCDIR)
> > 5. Redefined variable pkgs as "pkgs := package1"
> > 6. Introduced a few variables to make PETSC_COMPILE.c work:
> > CFLAGS := -I$(MYLIB)/include
> > LDFLAGS = -L$(MYLIB)/lib
> > LDLIBS = -lmylib
> > 7. Changed the call to gmakegentest.py as follows
> > $(PYTHON) $(CONFIGDIR)/gmakegentest.py --petsc-dir=$(PETSC_DIR)
> > --petsc-arch=$(PETSC_ARCH) --testdir=$(TESTDIR) --srcdir=$(MYLIB)/src
> > --pkg-pkgs=$(pkgs)
> > 8. Changed the rule $(testexe.c) as follows:
> > $(call quiet,CLINKER) $(EXEFLAGS) $(LDFLAGS) -o $@ $^ $(PETSC_TEST_LIB)
> > $(LDLIBS)
> > 9. Added the option --srcdir=$(TESTSRCDIR) and set --petsc-dir=$(MYLIB)
> > when calling query_tests.py, for example:
> > TESTTARGETS := $(shell $(PYTHON) $(CONFIGDIR)/query_tests.py
> > --srcdir=$(TESTSRCDIR) --testdir=$(TESTDIR) --petsc-dir=$(MYLIB)
> > --petsc-arch=$(PETSC_ARCH) --searchin=$(searchin) 'name' '$(search)')
> > What do you think?
> > Best,
> > Daniele
> > On Mon, Mar 27, 2023 at 4:38 PM Matthew Knepley <knepley at gmail.com>
> wrote:
> >> On Mon, Mar 27, 2023 at 10:19 AM Jacob Faibussowitsch <
> jacob.fai at gmail.com>
> >> wrote:
> >>> Our testing framework was pretty much tailor-made for the PETSc src
> tree
> >>> and as such has many hard-coded paths and decisions. I’m going to go
> out on
> >>> a limb and say you probably won’t get this to work...
> >> I think we can help you get this to work. I have wanted to generalize
> the
> >> test framework for a long time. Everything is build by
> >>   confg/gmakegentest.py
> >> and I think we can get away with just changing paths here and everything
> >> will work.
> >>   Thanks!
> >>      Matt
> >>> That being said, one of the “base” paths that the testing harness uses
> to
> >>> initially find tests is the `TESTSRCDIR` variable in
> >>> `${PETSC_DIR}/gmakefile.test`. It is currently defined as
> >>> # TESTSRCDIR is always relative to gmakefile.test
> >>> #  This must be before includes
> >>> mkfile_path := $(abspath $(lastword $(MAKEFILE_LIST)))
> >>> TESTSRCDIR := $(dir $(mkfile_path))src
> >>> You should start by changing this to
> >>> TESTSRCDIR ?= $(dir $(mkfile_path))src
> >>> That way you could run your tests via
> >>> $ make test TESTSRCDIR=/path/to/your/src/dir
> >>> I am sure there are many other modifications you will need to make.
> >>> Best regards,
> >>> (Jacob Fai - booss - oh - vitch)
> >>> > On Mar 27, 2023, at 06:14, Daniele Prada <daniele.prada85 at gmail.com>
> >>> wrote:
> >>> > Hello everyone,
> >>> > I would like to use the PETSc Testing System for testing a package
> that
> >>> I am developing.
> >>> > I have read the PETSc developer documentation and have written some
> >>> tests using the PETSc Test Description Language. I am going through the
> >>> files in ${PETSC_DIR}/config but I am not able to make the testing
> system
> >>> look into the directory tree of my project.
> >>> > Any suggestions?
> >>> > Thanks in advance
> >>> > Daniele
> >> What most experimenters take for granted before they begin their
> >> experiments is infinitely more interesting than any results to which
> their
> >> experiments lead.
> >> -- Norbert Wiener
> >> https://www.cse.buffalo.edu/~knepley/
> >> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230328/59329c75/attachment.html>
