[petsc-users] Using PETSc Testing System
Daniele Prada
daniele.prada85 at gmail.com
Tue Mar 28 10:24:15 CDT 2023
Dear Matthew, dear Jacob,
Thank you very much for your useful remarks. I managed to use the PETSc
Testing System by doing as follows:
1. Redefined TESTDIR when running make
2. Used a project tree similar to that of PETSc. For examples, tests for
'package1' are in $MYLIB/src/package1/tests/
3. cp $PETSC_DIR/gmakefile.test $MYLIB/gmakefile.test
Inside gmakefile.test:
4. Right AFTER "-include petscdir.mk" added "-include mylib.mk" to have
$MYLIB exported (note: this affects TESTSRCDIR)
5. Redefined variable pkgs as "pkgs := package1"
6. Introduced a few variables to make PETSC_COMPILE.c work:
CFLAGS := -I$(MYLIB)/include
LDFLAGS = -L$(MYLIB)/lib
LDLIBS = -lmylib
7. Changed the call to gmakegentest.py as follows
$(PYTHON) $(CONFIGDIR)/gmakegentest.py --petsc-dir=$(PETSC_DIR)
--petsc-arch=$(PETSC_ARCH) --testdir=$(TESTDIR) --srcdir=$(MYLIB)/src
--pkg-pkgs=$(pkgs)
8. Changed the rule $(testexe.c) as follows:
$(call quiet,CLINKER) $(EXEFLAGS) $(LDFLAGS) -o $@ $^ $(PETSC_TEST_LIB)
$(LDLIBS)
9. Added the option --srcdir=$(TESTSRCDIR) and set --petsc-dir=$(MYLIB)
when calling query_tests.py, for example:
TESTTARGETS := $(shell $(PYTHON) $(CONFIGDIR)/query_tests.py
--srcdir=$(TESTSRCDIR) --testdir=$(TESTDIR) --petsc-dir=$(MYLIB)
--petsc-arch=$(PETSC_ARCH) --searchin=$(searchin) 'name' '$(search)')
What do you think?
Best,
Daniele
On Mon, Mar 27, 2023 at 4:38 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 27, 2023 at 10:19 AM Jacob Faibussowitsch <jacob.fai at gmail.com>
> wrote:
>> Our testing framework was pretty much tailor-made for the PETSc src tree
>> and as such has many hard-coded paths and decisions. I’m going to go out on
>> a limb and say you probably won’t get this to work...
> I think we can help you get this to work. I have wanted to generalize the
> test framework for a long time. Everything is build by
> confg/gmakegentest.py
> and I think we can get away with just changing paths here and everything
> will work.
> Thanks!
> Matt
>> That being said, one of the “base” paths that the testing harness uses to
>> initially find tests is the `TESTSRCDIR` variable in
>> `${PETSC_DIR}/gmakefile.test`. It is currently defined as
>> # TESTSRCDIR is always relative to gmakefile.test
>> # This must be before includes
>> mkfile_path := $(abspath $(lastword $(MAKEFILE_LIST)))
>> TESTSRCDIR := $(dir $(mkfile_path))src
>> You should start by changing this to
>> TESTSRCDIR ?= $(dir $(mkfile_path))src
>> That way you could run your tests via
>> $ make test TESTSRCDIR=/path/to/your/src/dir
>> I am sure there are many other modifications you will need to make.
>> Best regards,
>> (Jacob Fai - booss - oh - vitch)
>> > On Mar 27, 2023, at 06:14, Daniele Prada <daniele.prada85 at gmail.com>
>> wrote:
>> > Hello everyone,
>> > I would like to use the PETSc Testing System for testing a package that
>> I am developing.
>> > I have read the PETSc developer documentation and have written some
>> tests using the PETSc Test Description Language. I am going through the
>> files in ${PETSC_DIR}/config but I am not able to make the testing system
>> look into the directory tree of my project.
>> > Any suggestions?
>> > Thanks in advance
>> > Daniele
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230328/9de2a617/attachment.html>
