[petsc-users] Create a nest not aligned by processors
    Matthew Knepley
    knepley at gmail.com
    Fri Mar 17 13:29:13 CDT 2023
On Fri, Mar 17, 2023 at 2:23 PM Berger Clement <clement.berger at ens-lyon.fr>
wrote:
> My issue is that it seems to improperly with some step of my process, the
> solve step doesn't provide the same result depending on the number of
> processors I use. I manually tried to multiply one the matrices I defined
> as a nest against a vector, and the result is not the same with e.g. 1 and
> 3 processors. That's why I tried the toy program I wrote in the first
> place, which highlights the misplacement of elements.
Ah, now I think I understand.
  The PETSC_DECIDE arguments for sizes change with a different number of
processes. You can put in har numbers if you want.
     Matt
> Clément BERGER
> ENS de Lyon
> Le 2023-03-17 19:14, Barry Smith a écrit :
>    This sounds  like a fine use of MATNEST. Now back to the original
> question
> I want to construct a matrix by blocs, each block having different sizes
> and partially stored by multiple processors. If I am not mistaken, the
> right way to do so is by using the MATNEST type. However, the following code
> Call
> MatCreateConstantDiagonal(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,4,4,2.0E0_wp,A,ierr)
> Call
> MatCreateConstantDiagonal(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,4,4,1.0E0_wp,B,ierr)
> Call
> MatCreateNest(PETSC_COMM_WORLD,2,PETSC_NULL_INTEGER,2,PETSC_NULL_INTEGER,(/A,PETSC_NULL_MAT,PETSC_NULL_MAT,B/),C,ierr)
> does not generate the same matrix depending on the number of processors.
> It seems that it starts by everything owned by the first proc for A and B,
> then goes on to the second proc and so on (I hope I am being clear).
> Is it possible to change that ?
>   If I understand correctly it is behaving as expected. It is the same
> matrix on 1 and 2 MPI processes, the only difference is the ordering of the
> rows and columns.
>   Both matrix blocks are split among the two MPI processes. This is how
> MATNEST works and likely what you want in practice.
> On Mar 17, 2023, at 1:19 PM, Berger Clement <clement.berger at ens-lyon.fr>
> wrote:
> I have a matrix with four different blocks (2rows - 2columns). The block
> sizes differ from one another, because they correspond to a different
> physical variable. One of the block has the particularity that it has to be
> updated at each iteration. This update is performed by replacing it with a
> product of multiple matrices that depend on the result of the previous
> iteration. Note that these intermediate matrices are not square (because
> they also correspond to other types of variables), and that they must be
> completely refilled by hand (i.e. they are not the result of some simple
> linear operations). Finally, I use this final block matrix to solve
> multiple linear systems (with different righthand sides), so for now I use
> MUMPS as only the first solve takes time (but I might change it).
> Considering this setting, I created each type of variable separately,
> filled the different matrices, and created different nests of vectors /
> matrices for my operations. When the time comes to use KSPSolve, I use
> MatConvert on my matrix to get a MATAIJ compatible with MUMPS, I also copy
> the few vector data I need from my nests in a regular Vector, I solve, I
> get back my data in my nest and carry on with the operations needed for my
> updates.
> Is that clear ? I don't know if I provided too many or not enough details.
> Thank you
> Clément BERGER
> ENS de Lyon
> Le 2023-03-17 17:34, Barry Smith a écrit :
>    Perhaps if you provide a brief summary of what you would like to do and
> we may have ideas on how to achieve it.
>    Barry
> Note: that MATNEST does require that all matrices live on all the MPI
> processes within the original communicator. That is if the original
> communicator has ranks 0,1, and 2 you cannot have a matrix inside MATNEST
> that only lives on ranks 1,2 but you could have it have 0 rows on rank zero
> so effectively it lives only on rank 1 and 2 (though its communicator is
> all three ranks).
> On Mar 17, 2023, at 12:14 PM, Berger Clement <clement.berger at ens-lyon.fr>
> wrote:
> It would be possible in the case I showed you but in mine that would
> actually be quite complicated, isn't there any other workaround ? I precise
> that I am not entitled to utilizing the MATNEST format, it's just that I
> think the other ones wouldn't work.
> Clément BERGER
> ENS de Lyon
> Le 2023-03-17 15:48, Barry Smith a écrit :
>    You may be able to mimic what you want by not using PETSC_DECIDE but
> instead computing up front how many rows of each matrix you want stored on
> each MPI process. You can use 0 for on certain MPI processes for certain
> matrices if you don't want any rows of that particular matrix stored on
> that particular MPI process.
>   Barry
> On Mar 17, 2023, at 10:10 AM, Berger Clement <clement.berger at ens-lyon.fr>
> wrote:
> Dear all,
> Call
> Call
> Call
> Note that I am coding in fortran if that has ay consequence.
> Thank you,
> Sincerely,
> Clément BERGER
> ENS de Lyon
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230317/87323cf8/attachment.html>
