[petsc-users] Create a nest not aligned by processors
    Matthew Knepley
    knepley at gmail.com
    Mon Mar 20 12:03:05 CDT 2023
On Mon, Mar 20, 2023 at 12:20 PM Berger Clement <clement.berger at ens-lyon.fr>
wrote:
> That seems to be working fine, thank you !
Great!
  Thanks
     Matt
> Clément BERGER
> ENS de Lyon
> Le 2023-03-20 15:51, Matthew Knepley a écrit :
> On Mon, Mar 20, 2023 at 10:09 AM Berger Clement <
> clement.berger at ens-lyon.fr> wrote:
>> Ok so this means that if I define my vectors via VecNest (organized as
>> the matrices), everything will be correctly ordered ?
> Yes.
>> How does that behave with MatConvert ? In the sense that if I convert a
>> MatNest to MatAIJ via MatConvert, will the vector as built in the example I
>> showed you work properly ?
>> No. MatConvert just changes the storage format, not the ordering.
>   Thanks,
>      Matt
>> Thank you !
>> Clément BERGER
>> ENS de Lyon
>> Le 2023-03-20 14:58, Matthew Knepley a écrit :
>> On Mon, Mar 20, 2023 at 9:35 AM Berger Clement <
>>> 1) Yes in my program I use PETSC_DETERMINE, but I don't see what is the
>>> issue there. From what I understand, it just lets PETSc set the total size
>>> from the local sizes provided, am I mistaken ?
>>> 2) I attached a small script, when I run it with 1 proc the output
>>> vector is not the same as if I run it with 2 procs, I don't know what I
>>> should do to make them match.
>>> PS : I precise that I am not trying to point out a bug here, I realize
>>> that my usage is wrong somehow, I just can't determine why, sorry if I gave
>>> you the wrong impression !
>>> I think I can now explain this clearly. Thank you for the nice simple
>> example. I attach my slightly changed version (I think better in C). Here
>> is running on one process:
>> master *:~/Downloads/tmp/Berger$ /PETSc3/petsc/apple/bin/mpiexec -n 1
>> ./nestTest -left_view -right_view -nest_view -full_view
>> Mat Object: 1 MPI process
>>   type: nest
>>   Matrix object:
>>     type=nest, rows=2, cols=2
>>     MatNest structure:
>>     (0,0) : type=constantdiagonal, rows=4, cols=4
>>     (0,1) : NULL
>>     (1,0) : NULL
>>     (1,1) : type=constantdiagonal, rows=4, cols=4
>>   type: seqaij
>> row 0: (0, 2.)
>> row 1: (1, 2.)
>> row 2: (2, 2.)
>> row 3: (3, 2.)
>> row 4: (4, 1.)
>> row 5: (5, 1.)
>> row 6: (6, 1.)
>> row 7: (7, 1.)
>> Vec Object: 1 MPI process
>>   type: seq
>> 0.
>> 1.
>> 2.
>> 3.
>> 4.
>> 5.
>> 6.
>> 7.
>>   type: seq
>> 0.
>> 2.
>> 4.
>> 6.
>> 4.
>> 5.
>> 6.
>> 7.
>> This looks like what you expect. Doubling the first four rows and
>> reproducing the last four. Now let's run on two processes:
>> master *:~/Downloads/tmp/Berger$ /PETSc3/petsc/apple/bin/mpiexec -n 2
>> Mat Object: 2 MPI processes
>>   type: nest
>>   Matrix object:
>>     MatNest structure:
>>     (0,1) : NULL
>>     (1,0) : NULL
>>   type: mpiaij
>> row 0: (0, 2.)
>> row 1: (1, 2.)
>> row 2: (2, 1.)
>> row 3: (3, 1.)
>> row 4: (4, 2.)
>> row 5: (5, 2.)
>> row 6: (6, 1.)
>> row 7: (7, 1.)
>> Vec Object: 2 MPI processes
>>   type: mpi
>> Process [0]
>> 0.
>> 1.
>> 2.
>> 3.
>> Process [1]
>> 4.
>> 5.
>> 6.
>> 7.
>>   type: mpi
>> Process [0]
>> 0.
>> 2.
>> 2.
>> 3.
>> Process [1]
>> 8.
>> 10.
>> 6.
>> 7.
>> Let me describe what has changed. The matrices A and B are parallel, so
>> each has two rows on process 0 and two rows on process 1. In the MatNest
>> they are interleaved because we asked for contiguous numbering (by giving
>> NULL for the IS of global row numbers). If we want to reproduce the same
>> output, we would need to produce our input vector with the same interleaved
>> numbering.
>>   Thanks,
>>      Matt
>>> Thank you,
>>> Clément BERGER
>>> ENS de Lyon
>>> Le 2023-03-20 12:53, Matthew Knepley a écrit :
>>> On Mon, Mar 20, 2023 at 6:18 AM Berger Clement <
>>>> I simplified the problem with the initial test I talked about because I
>>>> thought I identified the issue, so I will walk you through my whole problem
>>>> - first the solve doesn't produce the same results as mentioned
>>>> - I noticed that the duration of the factorization step of the matrix
>>>> was also not consistent with the number of processors used (it is longer
>>>> with 3 processes than with 1), I didn't think much of it but I now realize
>>>> that for instance with 4 processes, MUMPS crashes when factorizing
>>>> - I thought my matrices were wrong, but it's hard for me to use MatView
>>>> to compare them with 1 or 2 proc because I work with a quite specific
>>>> geometry, so in order not to fall into some weird particular case I need to
>>>> use at least roughly 100 points, so looking at 100x100 matrices is not
>>>> really nice...Instead I tried to multiply them by a vector full of one
>>>> (after I used the vector v such that v(i)=i). I tried it on two matrices,
>>>> and the results didn't depend on the number of procs, but when I tried to
>>>> multiply against the nest of these two matrices (a 2x2 block diagonal
>>>> nest), the result changed depending on the number of processors used
>>>> - that's why I tried the toy problem I wrote to you in the first place
>>>> I hope it's clearer now.
>>> Unfortunately, it is not clear to me. There is nothing attached to this
>>> email. I will try to describe things from my end.
>>> 1) There are lots of tests. Internally, Nest does not depend on the
>>> number of processes unless you make it so. This leads
>>>      me to believe that your construction of the matrix changes with the
>>> number of processes. For example, using PETSC_DETERMINE
>>>      for sizes will do this.
>>> 2) In order to understand what you want to achieve, we need to have
>>> something running in two cases, one with "correct" output and one
>>>     with something different. It sounds like you have such a small
>>> example, but I have missed it.
>>> Can you attach this example? Then I can run it, look at the matrices,
>>> and see what is different.
>>>   Thanks,
>>>       Matt
>>>> Thank you
>>>> Clément BERGER
>>>> ENS de Lyon
>>>> Le 2023-03-17 21:57, Barry Smith a écrit :
>>>>   Yes, you would benefit from a VecConvert() to produce a standard
>>>> vector. But you should be able to use VecGetArray() on the nest array and
>>>> on the standard array and copy the values between the arrays any way you
>>>> like. You don't need to do any reordering when you copy. Is that not
>>>> working and what are the symptoms (more than just the answers to the linear
>>>> solve are different)? Again you can run on one and two MPI processes with a
>>>> tiny problem to see if things are not in the correct order in the vectors
>>>> and matrices.
>>>>   Barry
>>>> On Mar 17, 2023, at 3:22 PM, Berger Clement <clement.berger at ens-lyon.fr>
>>>> wrote:
>>>> To use MUMPS I need to convert my matrix in MATAIJ format (or at least
>>>> not MATNEST), after that if I use a VECNEST for the left and right hanside,
>>>> I get an error during the solve procedure, it is removed if I copy my data
>>>> in a vector with standard format, I couldn't find any other way
>>>> Clément BERGER
>>>> ENS de Lyon
>>>> Le 2023-03-17 19:53, Matthew Knepley a écrit :
>>>> On Fri, Mar 17, 2023 at 2:53 PM Berger Clement <
>>>>> But this is to properly fill up the VecNest am I right ? Because this
>>>>> one is correct, but I can't directly use it in the KSPSolve, I need to copy
>>>>> it into a standard vector
>>>> I do not understand what you mean here. You can definitely use a
>>>> VecNest in a KSP.
>>>>   Thanks,
>>>>     Matt
>>>>> Clément BERGER
>>>>> ENS de Lyon
>>>>> Le 2023-03-17 19:39, Barry Smith a écrit :
>>>>>   I think the intention is that you use VecNestGetSubVecs()
>>>>> or VecNestGetSubVec() and fill up the sub-vectors in the same style as the
>>>>> matrices; this decreases the change of a reordering mistake in trying to do
>>>>> it by hand in your code.
>>>>> On Mar 17, 2023, at 2:35 PM, Berger Clement <
>>>>> That might be it, I didn't find the equivalent of MatConvert for the
>>>>> vectors, so when I need to solve my linear system, with my righthandside
>>>>> properly computed in nest format, I create a new vector using VecDuplicate,
>>>>> and then I copy into it my data using VecGetArrayF90 and copiing each
>>>>> element by hand. Does it create an incorrect ordering ? If so how can I get
>>>>> the correct one ?
>>>>> Clément BERGER
>>>>> ENS de Lyon
>>>>> Le 2023-03-17 19:27, Barry Smith a écrit :
>>>>>   I would run your code with small sizes on 1, 2, 3 MPI ranks and use
>>>>> MatView() to examine the matrices. They will definitely be ordered
>>>>> differently but should otherwise be the same. My guess is that the right
>>>>> hand side may not have the correct ordering with respect to the matrix
>>>>> ordering in parallel. Note also that when the right hand side does have the
>>>>> correct ordering the solution will have a different ordering for each
>>>>> different number of MPI ranks when printed (but changing the ordering
>>>>> should give the same results up to machine precision.
>>>>>   Barry
>>>>> On Mar 17, 2023, at 2:23 PM, Berger Clement <
>>>>> My issue is that it seems to improperly with some step of my process,
>>>>> the solve step doesn't provide the same result depending on the number of
>>>>> processors I use. I manually tried to multiply one the matrices I defined
>>>>> as a nest against a vector, and the result is not the same with e.g. 1 and
>>>>> 3 processors. That's why I tried the toy program I wrote in the first
>>>>> place, which highlights the misplacement of elements.
>>>>> Clément BERGER
>>>>> ENS de Lyon
>>>>> Le 2023-03-17 19:14, Barry Smith a écrit :
>>>>>    This sounds  like a fine use of MATNEST. Now back to the original
>>>>> question
>>>>> I want to construct a matrix by blocs, each block having different
>>>>> sizes and partially stored by multiple processors. If I am not mistaken,
>>>>> the right way to do so is by using the MATNEST type. However, the following
>>>>> code
>>>>> Call
>>>>> MatCreateConstantDiagonal(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,4,4,2.0E0_wp,A,ierr)
>>>>> Call
>>>>> MatCreateConstantDiagonal(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,4,4,1.0E0_wp,B,ierr)
>>>>> Call
>>>>> MatCreateNest(PETSC_COMM_WORLD,2,PETSC_NULL_INTEGER,2,PETSC_NULL_INTEGER,(/A,PETSC_NULL_MAT,PETSC_NULL_MAT,B/),C,ierr)
>>>>> does not generate the same matrix depending on the number of
>>>>> processors. It seems that it starts by everything owned by the first proc
>>>>> for A and B, then goes on to the second proc and so on (I hope I am being
>>>>> clear).
>>>>> Is it possible to change that ?
>>>>>   If I understand correctly it is behaving as expected. It is the same
>>>>> matrix on 1 and 2 MPI processes, the only difference is the ordering of the
>>>>> rows and columns.
>>>>>   Both matrix blocks are split among the two MPI processes. This is
>>>>> how MATNEST works and likely what you want in practice.
>>>>> On Mar 17, 2023, at 1:19 PM, Berger Clement <
>>>>> I have a matrix with four different blocks (2rows - 2columns). The
>>>>> block sizes differ from one another, because they correspond to a different
>>>>> physical variable. One of the block has the particularity that it has to be
>>>>> updated at each iteration. This update is performed by replacing it with a
>>>>> product of multiple matrices that depend on the result of the previous
>>>>> iteration. Note that these intermediate matrices are not square (because
>>>>> they also correspond to other types of variables), and that they must be
>>>>> completely refilled by hand (i.e. they are not the result of some simple
>>>>> linear operations). Finally, I use this final block matrix to solve
>>>>> multiple linear systems (with different righthand sides), so for now I use
>>>>> MUMPS as only the first solve takes time (but I might change it).
>>>>> Considering this setting, I created each type of variable separately,
>>>>> filled the different matrices, and created different nests of vectors /
>>>>> matrices for my operations. When the time comes to use KSPSolve, I use
>>>>> MatConvert on my matrix to get a MATAIJ compatible with MUMPS, I also copy
>>>>> the few vector data I need from my nests in a regular Vector, I solve, I
>>>>> get back my data in my nest and carry on with the operations needed for my
>>>>> updates.
>>>>> Is that clear ? I don't know if I provided too many or not enough
>>>>> details.
>>>>> Thank you
>>>>> Clément BERGER
>>>>> ENS de Lyon
>>>>> Le 2023-03-17 17:34, Barry Smith a écrit :
>>>>>    Perhaps if you provide a brief summary of what you would like to do
>>>>> and we may have ideas on how to achieve it.
>>>>>    Barry
>>>>> Note: that MATNEST does require that all matrices live on all the MPI
>>>>> processes within the original communicator. That is if the original
>>>>> communicator has ranks 0,1, and 2 you cannot have a matrix inside MATNEST
>>>>> that only lives on ranks 1,2 but you could have it have 0 rows on rank zero
>>>>> so effectively it lives only on rank 1 and 2 (though its communicator is
>>>>> all three ranks).
>>>>> On Mar 17, 2023, at 12:14 PM, Berger Clement <
>>>>> It would be possible in the case I showed you but in mine that would
>>>>> actually be quite complicated, isn't there any other workaround ? I precise
>>>>> that I am not entitled to utilizing the MATNEST format, it's just that I
>>>>> think the other ones wouldn't work.
>>>>> Clément BERGER
>>>>> ENS de Lyon
>>>>> Le 2023-03-17 15:48, Barry Smith a écrit :
>>>>>    You may be able to mimic what you want by not using PETSC_DECIDE
>>>>> but instead computing up front how many rows of each matrix you want stored
>>>>> on each MPI process. You can use 0 for on certain MPI processes for certain
>>>>> matrices if you don't want any rows of that particular matrix stored on
>>>>> that particular MPI process.
>>>>>   Barry
>>>>> On Mar 17, 2023, at 10:10 AM, Berger Clement <
>>>>> Dear all,
>>>>> code
>>>>> Call
>>>>> Call
>>>>> Call
>>>>> clear).
>>>>> Note that I am coding in fortran if that has ay consequence.
>>>>> Thank you,
>>>>> Sincerely,
>>>>> Clément BERGER
>>>>> ENS de Lyon
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230320/7c09c46e/attachment-0001.html>
