[petsc-users] multi GPU partitions have very different memory usage
Mark Lohry
mlohry at gmail.com
Wed Jan 18 14:42:19 CST 2023
With asm I see a range of 8GB-13GB, slightly smaller ratio but that
probably explains it (does this still seem like a lot of memory to you for
the problem size?)
In general I don't have the same number of blocks per row, so I suppose it
makes sense there's some memory imbalance.
On Wed, Jan 18, 2023 at 3:35 PM Mark Adams <mfadams at lbl.gov> wrote:
> Can your problem have load imbalance?
> You might try '-pc_type asm' (and/or jacobi) to see your baseline load
> imbalance.
> GAMG can add some load imbalance but start by getting a baseline.
> Mark
> On Wed, Jan 18, 2023 at 2:54 PM Mark Lohry <mlohry at gmail.com> wrote:
>> Q0) does -memory_view trace GPU memory as well, or is there another
>> method to query the peak device memory allocation?
>> Q1) I'm loading a aijcusparse matrix with MatLoad, and running with
>> -ksp_type fgmres -pc_type gamg -mg_levels_pc_type asm with mat info
>> 27,142,948 rows and cols, bs=4, total nonzeros 759,709,392. Using 8 ranks
>> on 8x80GB GPUs, and during the setup phase before crashing with
>> CUSPARSE_STATUS_INSUFFICIENT_RESOURCES nvidia-smi shows the below pasted
>> content.
>> GPU memory usage spanning from 36GB-50GB but with one rank at 77GB. Is
>> this expected? Do I need to manually repartition this somehow?
>> Thanks,
>> Mark
>> | Processes:
>> | GPU GI CI PID Type Process name GPU
>> Memory |
>> | ID ID
>> Usage |
>> | 0 N/A N/A 1630309 C nvidia-cuda-mps-server
>> 27MiB |
>> | 0 N/A N/A 1696543 C ./petsc_solver_test
>> 38407MiB |
>> | 0 N/A N/A 1696544 C ./petsc_solver_test
>> 467MiB |
>> | 0 N/A N/A 1696545 C ./petsc_solver_test
>> 467MiB |
>> | 0 N/A N/A 1696546 C ./petsc_solver_test
>> 467MiB |
>> | 0 N/A N/A 1696548 C ./petsc_solver_test
>> 467MiB |
>> | 0 N/A N/A 1696550 C ./petsc_solver_test
>> 471MiB |
>> | 0 N/A N/A 1696551 C ./petsc_solver_test
>> 467MiB |
>> | 0 N/A N/A 1696552 C ./petsc_solver_test
>> 467MiB |
>> | 1 N/A N/A 1630309 C nvidia-cuda-mps-server
>> 27MiB |
>> | 1 N/A N/A 1696544 C ./petsc_solver_test
>> 35849MiB |
>> | 2 N/A N/A 1630309 C nvidia-cuda-mps-server
>> 27MiB |
>> | 2 N/A N/A 1696545 C ./petsc_solver_test
>> 36719MiB |
>> | 3 N/A N/A 1630309 C nvidia-cuda-mps-server
>> 27MiB |
>> | 3 N/A N/A 1696546 C ./petsc_solver_test
>> 37343MiB |
>> | 4 N/A N/A 1630309 C nvidia-cuda-mps-server
>> 27MiB |
>> | 4 N/A N/A 1696548 C ./petsc_solver_test
>> 36935MiB |
>> | 5 N/A N/A 1630309 C nvidia-cuda-mps-server
>> 27MiB |
>> | 5 N/A N/A 1696550 C ./petsc_solver_test
>> 49953MiB |
>> | 6 N/A N/A 1630309 C nvidia-cuda-mps-server
>> 27MiB |
>> | 6 N/A N/A 1696551 C ./petsc_solver_test
>> 47693MiB |
>> | 7 N/A N/A 1630309 C nvidia-cuda-mps-server
>> 27MiB |
>> | 7 N/A N/A 1696552 C ./petsc_solver_test
>> 77331MiB |
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230118/b61dd1d2/attachment-0001.html>
