[petsc-users] multi GPU partitions have very different memory usage
Mark Adams mfadams at lbl.gov
Wed Jan 18 14:34:52 CST 2023
Can your problem have load imbalance?
You might try '-pc_type asm' (and/or jacobi) to see your baseline load
imbalance.
GAMG can add some load imbalance but start by getting a baseline.
On Wed, Jan 18, 2023 at 2:54 PM Mark Lohry <mlohry at gmail.com> wrote:
> Q0) does -memory_view trace GPU memory as well, or is there another method
> to query the peak device memory allocation?
> Q1) I'm loading a aijcusparse matrix with MatLoad, and running with
> -ksp_type fgmres -pc_type gamg -mg_levels_pc_type asm with mat info
> 27,142,948 rows and cols, bs=4, total nonzeros 759,709,392. Using 8 ranks
> on 8x80GB GPUs, and during the setup phase before crashing with
> CUSPARSE_STATUS_INSUFFICIENT_RESOURCES nvidia-smi shows the below pasted
> content.
> GPU memory usage spanning from 36GB-50GB but with one rank at 77GB. Is
> this expected? Do I need to manually repartition this somehow?
> Thanks,
> Mark
> | Processes:
> |  GPU   GI   CI        PID   Type   Process name                  GPU
> Memory |
> |        ID   ID
> Usage      |
> |    0   N/A  N/A   1630309      C   nvidia-cuda-mps-server
> 27MiB |
> |    0   N/A  N/A   1696543      C   ./petsc_solver_test
> 38407MiB |
> |    0   N/A  N/A   1696544      C   ./petsc_solver_test
> 467MiB |
> |    0   N/A  N/A   1696545      C   ./petsc_solver_test
> 467MiB |
> |    0   N/A  N/A   1696546      C   ./petsc_solver_test
> 467MiB |
> |    0   N/A  N/A   1696548      C   ./petsc_solver_test
> 467MiB |
> |    0   N/A  N/A   1696550      C   ./petsc_solver_test
> 471MiB |
> |    0   N/A  N/A   1696551      C   ./petsc_solver_test
> 467MiB |
> |    0   N/A  N/A   1696552      C   ./petsc_solver_test
> 467MiB |
> |    1   N/A  N/A   1630309      C   nvidia-cuda-mps-server
> 27MiB |
> |    1   N/A  N/A   1696544      C   ./petsc_solver_test
> 35849MiB |
> |    2   N/A  N/A   1630309      C   nvidia-cuda-mps-server
> 27MiB |
> |    2   N/A  N/A   1696545      C   ./petsc_solver_test
> 36719MiB |
> |    3   N/A  N/A   1630309      C   nvidia-cuda-mps-server
> 27MiB |
> |    3   N/A  N/A   1696546      C   ./petsc_solver_test
> 37343MiB |
> |    4   N/A  N/A   1630309      C   nvidia-cuda-mps-server
> 27MiB |
> |    4   N/A  N/A   1696548      C   ./petsc_solver_test
> 36935MiB |
> |    5   N/A  N/A   1630309      C   nvidia-cuda-mps-server
> 27MiB |
> |    5   N/A  N/A   1696550      C   ./petsc_solver_test
> 49953MiB |
> |    6   N/A  N/A   1630309      C   nvidia-cuda-mps-server
> 27MiB |
> |    6   N/A  N/A   1696551      C   ./petsc_solver_test
> 47693MiB |
> |    7   N/A  N/A   1630309      C   nvidia-cuda-mps-server
> 27MiB |
> |    7   N/A  N/A   1696552      C   ./petsc_solver_test
> 77331MiB |
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230118/8e85d344/attachment.html>
