[petsc-users] multi GPU partitions have very different memory usage
Mark Adams
mfadams at lbl.gov
Wed Jan 18 15:48:36 CST 2023
cusparse matrix triple product takes a lot of memory. We usually use
Kokkos, configured with TPL turned off.
If you have a complex problem different parts of the domain can coarsen at
different rates.
Jacobi instead of asm will save a fair amount od memory.
If you run with -ksp_view you will see operator/matrix complexity from
GAMG. These should be < 1.5,
On Wed, Jan 18, 2023 at 3:42 PM Mark Lohry <mlohry at gmail.com> wrote:
> With asm I see a range of 8GB-13GB, slightly smaller ratio but that
> probably explains it (does this still seem like a lot of memory to you for
> the problem size?)
> In general I don't have the same number of blocks per row, so I suppose it
> makes sense there's some memory imbalance.
> On Wed, Jan 18, 2023 at 3:35 PM Mark Adams <mfadams at lbl.gov> wrote:
>> Can your problem have load imbalance?
>> You might try '-pc_type asm' (and/or jacobi) to see your baseline load
>> imbalance.
>> GAMG can add some load imbalance but start by getting a baseline.
>> Mark
>> On Wed, Jan 18, 2023 at 2:54 PM Mark Lohry <mlohry at gmail.com> wrote:
>>> Q0) does -memory_view trace GPU memory as well, or is there another
>>> method to query the peak device memory allocation?
>>> Q1) I'm loading a aijcusparse matrix with MatLoad, and running with
>>> -ksp_type fgmres -pc_type gamg -mg_levels_pc_type asm with mat info
>>> 27,142,948 rows and cols, bs=4, total nonzeros 759,709,392. Using 8 ranks
>>> on 8x80GB GPUs, and during the setup phase before crashing with
>>> CUSPARSE_STATUS_INSUFFICIENT_RESOURCES nvidia-smi shows the below pasted
>>> content.
>>> GPU memory usage spanning from 36GB-50GB but with one rank at 77GB. Is
>>> this expected? Do I need to manually repartition this somehow?
>>> Thanks,
>>> Mark
>>> | Processes:
>>> | GPU GI CI PID Type Process name GPU
>>> Memory |
>>> | ID ID
>>> Usage |
>>> | 0 N/A N/A 1630309 C nvidia-cuda-mps-server
>>> 27MiB |
>>> | 0 N/A N/A 1696543 C ./petsc_solver_test
>>> 38407MiB |
>>> | 0 N/A N/A 1696544 C ./petsc_solver_test
>>> 467MiB |
>>> | 0 N/A N/A 1696545 C ./petsc_solver_test
>>> 467MiB |
>>> | 0 N/A N/A 1696546 C ./petsc_solver_test
>>> 467MiB |
>>> | 0 N/A N/A 1696548 C ./petsc_solver_test
>>> 467MiB |
>>> | 0 N/A N/A 1696550 C ./petsc_solver_test
>>> 471MiB |
>>> | 0 N/A N/A 1696551 C ./petsc_solver_test
>>> 467MiB |
>>> | 0 N/A N/A 1696552 C ./petsc_solver_test
>>> 467MiB |
>>> | 1 N/A N/A 1630309 C nvidia-cuda-mps-server
>>> 27MiB |
>>> | 1 N/A N/A 1696544 C ./petsc_solver_test
>>> 35849MiB |
>>> | 2 N/A N/A 1630309 C nvidia-cuda-mps-server
>>> 27MiB |
>>> | 2 N/A N/A 1696545 C ./petsc_solver_test
>>> 36719MiB |
>>> | 3 N/A N/A 1630309 C nvidia-cuda-mps-server
>>> 27MiB |
>>> | 3 N/A N/A 1696546 C ./petsc_solver_test
>>> 37343MiB |
>>> | 4 N/A N/A 1630309 C nvidia-cuda-mps-server
>>> 27MiB |
>>> | 4 N/A N/A 1696548 C ./petsc_solver_test
>>> 36935MiB |
>>> | 5 N/A N/A 1630309 C nvidia-cuda-mps-server
>>> 27MiB |
>>> | 5 N/A N/A 1696550 C ./petsc_solver_test
>>> 49953MiB |
>>> | 6 N/A N/A 1630309 C nvidia-cuda-mps-server
>>> 27MiB |
>>> | 6 N/A N/A 1696551 C ./petsc_solver_test
>>> 47693MiB |
>>> | 7 N/A N/A 1630309 C nvidia-cuda-mps-server
>>> 27MiB |
>>> | 7 N/A N/A 1696552 C ./petsc_solver_test
>>> 77331MiB |
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230118/f00ebaed/attachment.html>
