[petsc-users] PetscSF Fortran interface
Junchao Zhang
junchao.zhang at gmail.com
Wed Jan 11 08:16:01 CST 2023
Hi, Nicholas,
See
https://petsc.org/release/developers/contributing/#starting-a-new-feature-branch
on how to contribute.
You will need to create your own fork of petsc, then create a feature
branch and your code, and then ask for a merge request to merge your branch
to the petsc repo.
Once you have the MR, we can figure out why it could not compile.
Thanks for the contribution!
--Junchao Zhang
On Wed, Jan 11, 2023 at 12:58 AM Nicholas Arnold-Medabalimi <
narnoldm at umich.edu> wrote:
> Hi Junchao
> Apologies for not seeing that. Usually, the fortran90-specific functions
> have notes on the original C version, and I also can't
> see PetscSFCreateSectionSFF90 on the function list on the doc site. Thanks
> so much, and I saw your notes on the merge request.
> I don't suppose PetscSFReduceBegin and End are likewise hidden somewhere.
> I'm moving between distributions, and I can go forward with
> PetscSFBcastBegin, but I also need to go backward with Reduce.
> I feel like this is a one-to-one change from Bcast to Reduce, and I've
> added the relevant lines in src/vec/is/sf/interface/ftn-custom/zsf.c and
> src/vec/f90-mod/petscvec.h90 and it compiles fine, but I'm still getting a
> linking error for the Reduce routines.
> I need some input on what I'm missing here. I hope I didn't miss that this
> routine exists elsewhere.
> I've attached the two files, but it's not an ideal way to transmit
> changes.
> If I get some instructions on contributing, I can make a merge request for
> the changes if they are helpful.
> Thanks
> Nicholas
> On Tue, Jan 10, 2023 at 4:42 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> Hi, Nicholas,
>> It seems we have implemented it, but with another name,
>> PetscSFCreateSectionSFF90, see
>> https://gitlab.com/petsc/petsc/-/merge_requests/5386
>> Try it to see if it works!
>> --Junchao Zhang
>> On Tue, Jan 10, 2023 at 11:45 AM Nicholas Arnold-Medabalimi <
>>> Er to be honest I still can't get my stub to compile properly, and I
>>> don't know how to go about making a merge request. But here is what I am
>>> attempting right now. Let me know how best to proceed
>>> Its not exactly clear to me how to setup up the remote offset properly.
>>> PETSC_EXTERN void petscsfcreatesectionsf(PetscSF *sf, PetscSection
>>> *rootSection, F90Array1d *aremoteOffsets, PetscSection *leafSection,
>>> PetscSF *sectionSF, int * ierr PETSC_F90_2PTR_PROTO(remoteoffsetsd))
>>> int * remoteOffsets;
>>> *ierr = F90Array1dAccess(aremoteOffsets, PETSC_INT, (void**)
>>> &remoteOffsets PETSC_F90_2PTR_PARAM(remoteoffsetsd));if (*ierr) return;
>>> *ierr = PetscSFCreateSectionSF(*sf,*rootSection,
>>> &remoteOffsets,*leafSection,*sectionSF);if (*ierr) return;
>>> This is the sticking point.
>>> Sincerely
>>> Nicholas
>>> On Tue, Jan 10, 2023 at 12:38 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> Hi, Nicholas,
>>>> Could you make a merge request to PETSc and then our Fortran experts
>>>> can comment on your MR?
>>>> Thanks.
>>>> --Junchao Zhang
>>>> On Tue, Jan 10, 2023 at 11:10 AM Nicholas Arnold-Medabalimi <
>>>>> Hi Junchao
>>>>> I think I'm almost there, but I could use some insight into how to use
>>>>> the PETSC_F90_2PTR_PROTO and F90Array1dAccess for the remoteOffset
>>>>> parameter input so if another function comes up, I can add it myself
>>>>> without wasting your time.
>>>>> I am very grateful for your help and time.
>>>>> Sincerely
>>>>> Nicholas
>>>>> On Tue, Jan 10, 2023 at 10:55 AM Junchao Zhang <
>>>>> junchao.zhang at gmail.com> wrote:
>>>>>> Hi, Nicholas,
>>>>>> I am not a fortran guy, but I will try to add
>>>>>> petscsfcreatesectionsf.
>>>>>> Thanks.
>>>>>> --Junchao Zhang
>>>>>> On Tue, Jan 10, 2023 at 12:50 AM Nicholas Arnold-Medabalimi <
>>>>>>> I think it should be something like this, but I'm not very fluent in
>>>>>>> Fortran C interop syntax. Any advice would be appreciated. Thanks
>>>>>>> PETSC_EXTERN void petscsfcreatesectionsf(PetscSF *sf, PetscSection *
>>>>>>> *ierr = F90Array1dAccess(aremoteOffsets, PETSC_INT, (void**) &
>>>>>>> return;
>>>>>>> *ierr = PetscSFCreateSectionSF(*sf,*rootSection, &remoteOffsets,*
>>>>>>> On Mon, Jan 9, 2023 at 11:41 PM Nicholas Arnold-Medabalimi <
>>>>>>>> Hi Junchao
>>>>>>>> Thanks again for your help in November. I've been using the your
>>>>>>>> merge request branch quite heavily. Would it be possible to add a
>>>>>>>> petscsfcreatesectionsf interface as well?
>>>>>>>> I'm trying to write it myself using your commits as a guide but I
>>>>>>>> have been struggling with handling the section parameter properly.
>>>>>>>> Sincerely
>>>>>>>> Nicholas
>>>>>>>> On Sat, Nov 19, 2022 at 9:44 PM Junchao Zhang <
>>>>>>>>> On Sat, Nov 19, 2022 at 8:05 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>> Hi
>>>>>>>>>> Thanks, this is awesome. Thanks for the very prompt fix. Just one
>>>>>>>>>> question: will the array outputs on the fortran side copies (and need to be
>>>>>>>>>> deallocated) or direct access to the dmplex?
>>>>>>>>> Direct access to internal data; no need to deallocate
>>>>>>>>>> Sincerely
>>>>>>>>>> Nicholas
>>>>>>>>>> On Sat, Nov 19, 2022 at 8:21 PM Junchao Zhang <
>>>>>>>>>>> Hi, Nicholas,
>>>>>>>>>>> See this MR,
>>>>>>>>>>> https://gitlab.com/petsc/petsc/-/merge_requests/5860
>>>>>>>>>>> It is in testing, but you can try branch
>>>>>>>>>>> jczhang/add-petscsf-fortran to see if it works for you.
>>>>>>>>>>> Thanks.
>>>>>>>>>>> --Junchao Zhang
>>>>>>>>>>> On Sat, Nov 19, 2022 at 4:16 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>>>> Hi Junchao
>>>>>>>>>>>> Thanks. I was wondering if there is any update on this. I may
>>>>>>>>>>>> write a small interface for those two routines myself in the interim but
>>>>>>>>>>>> I'd appreciate any insight you have.
>>>>>>>>>>>> Sincerely
>>>>>>>>>>>> Nicholas
>>>>>>>>>>>> On Wed, Nov 16, 2022 at 10:39 PM Junchao Zhang <
>>>>>>>>>>>>> Hi, Nicholas,
>>>>>>>>>>>>> I will have a look and get back to you.
>>>>>>>>>>>>> Thanks.
>>>>>>>>>>>>> --Junchao Zhang
>>>>>>>>>>>>> On Wed, Nov 16, 2022 at 9:27 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>>>>>> Hi Petsc Users
>>>>>>>>>>>>>> I'm in the process of adding some Petsc for mesh management
>>>>>>>>>>>>>> into an existing Fortran Solver. It has been relatively straightforward so
>>>>>>>>>>>>>> far but I am running into an issue with using PetscSF routines. Some like
>>>>>>>>>>>>>> the PetscSFGetGraph work no problem but a few of my routines require the
>>>>>>>>>>>>>> use of PetscSFGetLeafRanks and PetscSFGetRootRanks and those don't seem to
>>>>>>>>>>>>>> be in the fortran interface and I just get a linking error. I also don't
>>>>>>>>>>>>>> seem to see a PetscSF file in the finclude. Any clarification or assistance
>>>>>>>>>>>>>> Sincerely
>>>>>>>>>>>>>> Nicholas
>>>>>>>>>>>>>> Ph.D. Candidate
>>>>>>>>>>>>>> Computational Aeroscience Lab
>>>>>>>>>>>>>> University of Michigan
>>>>>>>>>>>> Ph.D. Candidate
>>>>>>>>>> Ph.D. Candidate
>>>>>>>> Ph.D. Candidate
>>>>>>> Ph.D. Candidate
>>>>> Ph.D. Candidate
>>> Ph.D. Candidate
> Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230111/c5c93dbb/attachment-0001.html>
