[petsc-users] PetscSF Fortran interface
    Nicholas Arnold-Medabalimi
    narnoldm at umich.edu
    Wed Jan 11 10:29:58 CST 2023
Hi Junchao
I hope I didn't make making any errors; I created the merge request
following those instructions and commented @ you.
https://gitlab.com/petsc/petsc/-/merge_requests/5969
Sincerely
Nicholas
On Wed, Jan 11, 2023 at 9:16 AM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> Hi, Nicholas,
>   See
> https://petsc.org/release/developers/contributing/#starting-a-new-feature-branch
> on how to contribute.
>   You will need to create your own fork of petsc,  then create a feature
> branch and your code, and then ask for a merge request to merge your branch
> to the petsc repo.
>   Once you have the MR, we can figure out why it could not compile.
>   Thanks for the contribution!
> --Junchao Zhang
> On Wed, Jan 11, 2023 at 12:58 AM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Hi Junchao
>>  Apologies for not seeing that. Usually, the fortran90-specific functions
>> have notes on the original C version, and I also can't
>> see PetscSFCreateSectionSFF90 on the function list on the doc site. Thanks
>> so much, and I saw your notes on the merge request.
>> I don't suppose PetscSFReduceBegin and End are likewise hidden somewhere.
>> I'm moving between distributions, and I can go forward with
>> PetscSFBcastBegin, but I also need to go backward with Reduce.
>> I feel like this is a one-to-one change from Bcast to Reduce, and I've
>> added the relevant lines in src/vec/is/sf/interface/ftn-custom/zsf.c and
>> src/vec/f90-mod/petscvec.h90 and it compiles fine, but I'm still getting a
>> linking error for the Reduce routines.
>> I need some input on what I'm missing here. I hope I didn't miss that
>> this routine exists elsewhere.
>> I've attached the two files, but it's not an ideal way to transmit
>> changes.
>> If I get some instructions on contributing, I can make a merge request
>> for the changes if they are helpful.
>> Thanks
>> Nicholas
>> On Tue, Jan 10, 2023 at 4:42 PM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> Hi, Nicholas,
>>>    It seems we have implemented it, but with another name,
>>> PetscSFCreateSectionSFF90, see
>>> https://gitlab.com/petsc/petsc/-/merge_requests/5386
>>>    Try it to see if it works!
>>> --Junchao Zhang
>>> On Tue, Jan 10, 2023 at 11:45 AM Nicholas Arnold-Medabalimi <
>>>> Er to be honest I still can't get my stub to compile properly, and I
>>>> don't know how to go about making a merge request. But here is what I am
>>>> attempting right now. Let me know how best to proceed
>>>> Its not exactly clear to me how to setup up the remote offset properly.
>>>> PETSC_EXTERN void petscsfcreatesectionsf(PetscSF *sf, PetscSection
>>>> *rootSection, F90Array1d *aremoteOffsets, PetscSection *leafSection,
>>>> PetscSF *sectionSF, int * ierr PETSC_F90_2PTR_PROTO(remoteoffsetsd))
>>>>   int * remoteOffsets;
>>>>   *ierr = F90Array1dAccess(aremoteOffsets, PETSC_INT, (void**)
>>>> &remoteOffsets PETSC_F90_2PTR_PARAM(remoteoffsetsd));if (*ierr) return;
>>>>   *ierr = PetscSFCreateSectionSF(*sf,*rootSection,
>>>> &remoteOffsets,*leafSection,*sectionSF);if (*ierr) return;
>>>> This is the sticking point.
>>>> Sincerely
>>>> Nicholas
>>>> On Tue, Jan 10, 2023 at 12:38 PM Junchao Zhang <junchao.zhang at gmail.com>
>>>> wrote:
>>>>> Hi, Nicholas,
>>>>>   Could you make a merge request to PETSc and then our Fortran experts
>>>>> can comment on your MR?
>>>>>   Thanks.
>>>>> --Junchao Zhang
>>>>> On Tue, Jan 10, 2023 at 11:10 AM Nicholas Arnold-Medabalimi <
>>>>>> Hi Junchao
>>>>>> I think I'm almost there, but I could use some insight into how to
>>>>>> use the PETSC_F90_2PTR_PROTO and F90Array1dAccess for the remoteOffset
>>>>>> parameter input so if another function comes up, I can add it myself
>>>>>> without wasting your time.
>>>>>> I am very grateful for your help and time.
>>>>>> Sincerely
>>>>>> Nicholas
>>>>>> On Tue, Jan 10, 2023 at 10:55 AM Junchao Zhang <
>>>>>> junchao.zhang at gmail.com> wrote:
>>>>>>> Hi, Nicholas,
>>>>>>>    I am not a fortran guy, but I will try to add
>>>>>>> petscsfcreatesectionsf.
>>>>>>>    Thanks.
>>>>>>> --Junchao Zhang
>>>>>>> On Tue, Jan 10, 2023 at 12:50 AM Nicholas Arnold-Medabalimi <
>>>>>>>> I think it should be something like this, but I'm not very fluent
>>>>>>>> in Fortran C interop syntax. Any advice would be appreciated. Thanks
>>>>>>>> (remoteoffsetsd))
>>>>>>>>   *ierr = F90Array1dAccess(aremoteOffsets, PETSC_INT, (void**) &
>>>>>>>> return;
>>>>>>>>   *ierr = PetscSFCreateSectionSF(*sf,*rootSection, &remoteOffsets,*
>>>>>>>> On Mon, Jan 9, 2023 at 11:41 PM Nicholas Arnold-Medabalimi <
>>>>>>>>> Hi Junchao
>>>>>>>>> Thanks again for your help in November. I've been using the your
>>>>>>>>> merge request branch quite heavily. Would it be possible to add a
>>>>>>>>> petscsfcreatesectionsf interface as well?
>>>>>>>>> I'm trying to write it myself using your commits as a guide but I
>>>>>>>>> have been struggling with handling the section parameter properly.
>>>>>>>>> Sincerely
>>>>>>>>> Nicholas
>>>>>>>>> On Sat, Nov 19, 2022 at 9:44 PM Junchao Zhang <
>>>>>>>>>> On Sat, Nov 19, 2022 at 8:05 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>>> Hi
>>>>>>>>>>> Thanks, this is awesome. Thanks for the very prompt fix. Just
>>>>>>>>>>> one question: will the array outputs on the fortran side copies (and need
>>>>>>>>>>> to be deallocated) or direct access to the dmplex?
>>>>>>>>>> Direct access to internal data;  no need to deallocate
>>>>>>>>>>> Sincerely
>>>>>>>>>>> Nicholas
>>>>>>>>>>> On Sat, Nov 19, 2022 at 8:21 PM Junchao Zhang <
>>>>>>>>>>>> Hi, Nicholas,
>>>>>>>>>>>>   See this MR,
>>>>>>>>>>>> https://gitlab.com/petsc/petsc/-/merge_requests/5860
>>>>>>>>>>>>   It is in testing, but you can try branch
>>>>>>>>>>>> jczhang/add-petscsf-fortran to see if it works for you.
>>>>>>>>>>>>   Thanks.
>>>>>>>>>>>> --Junchao Zhang
>>>>>>>>>>>> On Sat, Nov 19, 2022 at 4:16 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>>>>> Hi Junchao
>>>>>>>>>>>>> Thanks. I was wondering if there is any update on this. I may
>>>>>>>>>>>>> write a small interface for those two routines myself in the interim but
>>>>>>>>>>>>> I'd appreciate any insight you have.
>>>>>>>>>>>>> Sincerely
>>>>>>>>>>>>> Nicholas
>>>>>>>>>>>>> On Wed, Nov 16, 2022 at 10:39 PM Junchao Zhang <
>>>>>>>>>>>>>> Hi, Nicholas,
>>>>>>>>>>>>>>   I will have a look and get back to you.
>>>>>>>>>>>>>>   Thanks.
>>>>>>>>>>>>>> --Junchao Zhang
>>>>>>>>>>>>>> On Wed, Nov 16, 2022 at 9:27 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>>>>>>> Hi Petsc Users
>>>>>>>>>>>>>>> I'm in the process of adding some Petsc for mesh management
>>>>>>>>>>>>>>> into an existing Fortran Solver. It has been relatively straightforward so
>>>>>>>>>>>>>>> far but I am running into an issue with using PetscSF routines. Some like
>>>>>>>>>>>>>>> the PetscSFGetGraph work no problem but a few of my routines require the
>>>>>>>>>>>>>>> use of PetscSFGetLeafRanks and PetscSFGetRootRanks and those don't seem to
>>>>>>>>>>>>>>> be in the fortran interface and I just get a linking error. I also don't
>>>>>>>>>>>>>>> seem to see a PetscSF file in the finclude. Any clarification or assistance
>>>>>>>>>>>>>>> Sincerely
>>>>>>>>>>>>>>> Nicholas
>>>>>>>>>>>>>>> Ph.D. Candidate
>>>>>>>>>>>>>>> Computational Aeroscience Lab
>>>>>>>>>>>>>>> University of Michigan
>>>>>>>>>>>>> Ph.D. Candidate
>>>>>>>>>>> Ph.D. Candidate
>>>>>>>>> Ph.D. Candidate
>>>>>>>> Ph.D. Candidate
>>>>>> Ph.D. Candidate
>>>> Ph.D. Candidate
>> Ph.D. Candidate
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230111/2a43e0a6/attachment-0001.html>
