[petsc-users] PetscSF Fortran interface
Nicholas Arnold-Medabalimi
narnoldm at umich.edu
Wed Jan 11 00:58:02 CST 2023
Hi Junchao
Apologies for not seeing that. Usually, the fortran90-specific functions
have notes on the original C version, and I also can't
see PetscSFCreateSectionSFF90 on the function list on the doc site. Thanks
so much, and I saw your notes on the merge request.
I don't suppose PetscSFReduceBegin and End are likewise hidden somewhere.
I'm moving between distributions, and I can go forward with
PetscSFBcastBegin, but I also need to go backward with Reduce.
I feel like this is a one-to-one change from Bcast to Reduce, and I've
added the relevant lines in src/vec/is/sf/interface/ftn-custom/zsf.c and
src/vec/f90-mod/petscvec.h90 and it compiles fine, but I'm still getting a
linking error for the Reduce routines.
I need some input on what I'm missing here. I hope I didn't miss that this
routine exists elsewhere.
I've attached the two files, but it's not an ideal way to transmit changes.
If I get some instructions on contributing, I can make a merge request for
the changes if they are helpful.
Thanks
Nicholas
On Tue, Jan 10, 2023 at 4:42 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> Hi, Nicholas,
> It seems we have implemented it, but with another name,
> PetscSFCreateSectionSFF90, see
> https://gitlab.com/petsc/petsc/-/merge_requests/5386
> Try it to see if it works!
> --Junchao Zhang
> On Tue, Jan 10, 2023 at 11:45 AM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Er to be honest I still can't get my stub to compile properly, and I
>> don't know how to go about making a merge request. But here is what I am
>> attempting right now. Let me know how best to proceed
>> Its not exactly clear to me how to setup up the remote offset properly.
>> PETSC_EXTERN void petscsfcreatesectionsf(PetscSF *sf, PetscSection
>> *rootSection, F90Array1d *aremoteOffsets, PetscSection *leafSection,
>> PetscSF *sectionSF, int * ierr PETSC_F90_2PTR_PROTO(remoteoffsetsd))
>> int * remoteOffsets;
>> *ierr = F90Array1dAccess(aremoteOffsets, PETSC_INT, (void**)
>> &remoteOffsets PETSC_F90_2PTR_PARAM(remoteoffsetsd));if (*ierr) return;
>> *ierr = PetscSFCreateSectionSF(*sf,*rootSection,
>> &remoteOffsets,*leafSection,*sectionSF);if (*ierr) return;
>> This is the sticking point.
>> Sincerely
>> Nicholas
>> On Tue, Jan 10, 2023 at 12:38 PM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> Hi, Nicholas,
>>> Could you make a merge request to PETSc and then our Fortran experts
>>> can comment on your MR?
>>> Thanks.
>>> --Junchao Zhang
>>> On Tue, Jan 10, 2023 at 11:10 AM Nicholas Arnold-Medabalimi <
>>>> Hi Junchao
>>>> I think I'm almost there, but I could use some insight into how to use
>>>> the PETSC_F90_2PTR_PROTO and F90Array1dAccess for the remoteOffset
>>>> parameter input so if another function comes up, I can add it myself
>>>> without wasting your time.
>>>> I am very grateful for your help and time.
>>>> Sincerely
>>>> Nicholas
>>>> On Tue, Jan 10, 2023 at 10:55 AM Junchao Zhang <junchao.zhang at gmail.com>
>>>> wrote:
>>>>> Hi, Nicholas,
>>>>> I am not a fortran guy, but I will try to add
>>>>> petscsfcreatesectionsf.
>>>>> Thanks.
>>>>> --Junchao Zhang
>>>>> On Tue, Jan 10, 2023 at 12:50 AM Nicholas Arnold-Medabalimi <
>>>>>> I think it should be something like this, but I'm not very fluent in
>>>>>> Fortran C interop syntax. Any advice would be appreciated. Thanks
>>>>>> PETSC_EXTERN void petscsfcreatesectionsf(PetscSF *sf, PetscSection *
>>>>>> *ierr = F90Array1dAccess(aremoteOffsets, PETSC_INT, (void**) &
>>>>>> *ierr = PetscSFCreateSectionSF(*sf,*rootSection, &remoteOffsets,*
>>>>>> On Mon, Jan 9, 2023 at 11:41 PM Nicholas Arnold-Medabalimi <
>>>>>>> Hi Junchao
>>>>>>> Thanks again for your help in November. I've been using the your
>>>>>>> merge request branch quite heavily. Would it be possible to add a
>>>>>>> petscsfcreatesectionsf interface as well?
>>>>>>> I'm trying to write it myself using your commits as a guide but I
>>>>>>> have been struggling with handling the section parameter properly.
>>>>>>> Sincerely
>>>>>>> Nicholas
>>>>>>> On Sat, Nov 19, 2022 at 9:44 PM Junchao Zhang <
>>>>>>> junchao.zhang at gmail.com> wrote:
>>>>>>>> On Sat, Nov 19, 2022 at 8:05 PM Nicholas Arnold-Medabalimi <
>>>>>>>>> Hi
>>>>>>>>> Thanks, this is awesome. Thanks for the very prompt fix. Just one
>>>>>>>>> question: will the array outputs on the fortran side copies (and need to be
>>>>>>>>> deallocated) or direct access to the dmplex?
>>>>>>>> Direct access to internal data; no need to deallocate
>>>>>>>>> Sincerely
>>>>>>>>> Nicholas
>>>>>>>>> On Sat, Nov 19, 2022 at 8:21 PM Junchao Zhang <
>>>>>>>>>> Hi, Nicholas,
>>>>>>>>>> See this MR,
>>>>>>>>>> https://gitlab.com/petsc/petsc/-/merge_requests/5860
>>>>>>>>>> It is in testing, but you can try branch
>>>>>>>>>> jczhang/add-petscsf-fortran to see if it works for you.
>>>>>>>>>> Thanks.
>>>>>>>>>> --Junchao Zhang
>>>>>>>>>> On Sat, Nov 19, 2022 at 4:16 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>>> Hi Junchao
>>>>>>>>>>> Thanks. I was wondering if there is any update on this. I may
>>>>>>>>>>> write a small interface for those two routines myself in the interim but
>>>>>>>>>>> I'd appreciate any insight you have.
>>>>>>>>>>> Sincerely
>>>>>>>>>>> Nicholas
>>>>>>>>>>> On Wed, Nov 16, 2022 at 10:39 PM Junchao Zhang <
>>>>>>>>>>>> Hi, Nicholas,
>>>>>>>>>>>> I will have a look and get back to you.
>>>>>>>>>>>> Thanks.
>>>>>>>>>>>> --Junchao Zhang
>>>>>>>>>>>> On Wed, Nov 16, 2022 at 9:27 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>>>>> Hi Petsc Users
>>>>>>>>>>>>> I'm in the process of adding some Petsc for mesh management
>>>>>>>>>>>>> into an existing Fortran Solver. It has been relatively straightforward so
>>>>>>>>>>>>> far but I am running into an issue with using PetscSF routines. Some like
>>>>>>>>>>>>> the PetscSFGetGraph work no problem but a few of my routines require the
>>>>>>>>>>>>> use of PetscSFGetLeafRanks and PetscSFGetRootRanks and those don't seem to
>>>>>>>>>>>>> be in the fortran interface and I just get a linking error. I also don't
>>>>>>>>>>>>> seem to see a PetscSF file in the finclude. Any clarification or assistance
>>>>>>>>>>>>> Sincerely
>>>>>>>>>>>>> Nicholas
>>>>>>>>>>>>> Ph.D. Candidate
>>>>>>>>>>>>> Computational Aeroscience Lab
>>>>>>>>>>>>> University of Michigan
>>>>>>>>>>> Ph.D. Candidate
>>>>>>>>> Ph.D. Candidate
>>>>>>> Ph.D. Candidate
>>>>>> Ph.D. Candidate
>>>> Ph.D. Candidate
>> Ph.D. Candidate
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230111/21d4c2da/attachment-0001.html>
#include <petsc/private/f90impl.h>
#include <petsc/private/sfimpl.h>
#if defined(PETSC_HAVE_FORTRAN_CAPS)
#define petscsfview_ PETSCSFVIEW
#define petscsfgetgraph_ PETSCSFGETGRAPH
#define petscsfbcastbegin_ PETSCSFBCASTBEGIN
#define petscsfbcastend_ PETSCSFBCASTEND
#define petscsfreducebegin_ PETSCSFREDUCEBEGIN
#define petscsfreduceend_ PETSCSFREDUCEEND
#define f90arraysfnodecreate_ F90ARRAYSFNODECREATE
#define petscsfviewfromoptions_ PETSCSFVIEWFROMOPTIONS
#define petscsfdestroy_ PETSCSFDESTROY
#define petscsfsetgraph_ PETSCSFSETGRAPH
#define petscsfgetleafranks_ PETSCSFGETLEAFRANKS
#define petscsfgetrootranks_ PETSCSFGETROOTRANKS
#elif !defined(PETSC_HAVE_FORTRAN_UNDERSCORE)
#define petscsfgetgraph_ petscsfgetgraph
#define petscsfview_ petscsfview
#define petscsfbcastbegin_ petscsfbcastbegin
#define petscsfbcastend_ petscsfbcastend
#define petscsfreducebegin_ petscsfreducebegin
#define petscsfreduceend_ petscsfreduceend
#define f90arraysfnodecreate_ f90arraysfnodecreate
#define petscsfviewfromoptions_ petscsfviewfromoptions
#define petscsfdestroy_ petscsfdestroy
#define petscsfsetgraph_ petscsfsetgraph
#define petscsfgetleafranks_ petscsfgetleafranks
#define petscsfgetrootranks_ petscsfgetrootranks
#endif
PETSC_EXTERN void f90arraysfnodecreate_(const PetscInt *,PetscInt *,void * PETSC_F90_2PTR_PROTO_NOVAR);
PETSC_EXTERN void petscsfsetgraph_(PetscSF *sf,PetscInt *nroots,PetscInt *nleaves, PetscInt *ilocal,PetscCopyMode *localmode, PetscSFNode *iremote,PetscCopyMode *remotemode, int *ierr)
if (ilocal == PETSC_NULL_INTEGER_Fortran) ilocal = NULL;
*ierr = PetscSFSetGraph(*sf,*nroots,*nleaves,ilocal,*localmode,iremote,*remotemode);
PETSC_EXTERN void petscsfview_(PetscSF *sf, PetscViewer *vin, PetscErrorCode *ierr)
PetscViewer v;
PetscPatchDefaultViewers_Fortran(vin, v);
*ierr = PetscSFView(*sf, v);
PETSC_EXTERN void petscsfgetgraph_(PetscSF *sf,PetscInt *nroots,PetscInt *nleaves, F90Array1d *ailocal, F90Array1d *airemote, PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(pilocal) PETSC_F90_2PTR_PROTO(piremote))
const PetscInt *ilocal;
const PetscSFNode *iremote;
PetscInt nl;
*ierr = PetscSFGetGraph(*sf,nroots,nleaves,&ilocal,&iremote);if (*ierr) return;
nl = *nleaves;
if (!ilocal) nl = 0;
*ierr = F90Array1dCreate((void*)ilocal,MPIU_INT,1,nl, ailocal PETSC_F90_2PTR_PARAM(pilocal));
/* this creates a memory leak */
f90arraysfnodecreate_((PetscInt*)iremote,nleaves, airemote PETSC_F90_2PTR_PARAM(piremote));
PETSC_EXTERN void petscsfgetleafranks_(PetscSF *sf, PetscInt *niranks, F90Array1d *airanks, F90Array1d *aioffset, F90Array1d *airootloc, PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(piranks) PETSC_F90_2PTR_PROTO(pioffset) PETSC_F90_2PTR_PROTO(pirootloc))
const PetscMPIInt *iranks;
const PetscInt *ioffset;
const PetscInt *irootloc;
*ierr = PetscSFGetLeafRanks(*sf, niranks, &iranks, &ioffset, &irootloc);if (*ierr) return;
*ierr = F90Array1dCreate((void *)iranks, MPI_INT, 1, *niranks, airanks PETSC_F90_2PTR_PARAM(piranks));if (*ierr) return;
*ierr = F90Array1dCreate((void*)ioffset, MPIU_INT, 1, *niranks+1, aioffset PETSC_F90_2PTR_PARAM(pioffset));if (*ierr) return;
*ierr = F90Array1dCreate((void *)irootloc, MPIU_INT, 1, ioffset[*niranks], airootloc PETSC_F90_2PTR_PARAM(pirootloc));if (*ierr) return;
PETSC_EXTERN void petscsfgetrootranks_(PetscSF *sf, PetscInt *nranks, F90Array1d *aranks, F90Array1d *aroffset, F90Array1d *armine, F90Array1d *arremote,
PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(pranks) PETSC_F90_2PTR_PROTO(proffset) PETSC_F90_2PTR_PROTO(prmine) PETSC_F90_2PTR_PROTO(prremote))
const PetscMPIInt *ranks;
const PetscInt *roffset;
const PetscInt *rmine;
const PetscInt *rremote;
*ierr = PetscSFGetRootRanks(*sf, nranks, &ranks, &roffset, &rmine, &rremote);if (*ierr) return;
*ierr = F90Array1dCreate((void*)ranks, MPI_INT, 1, *nranks, aranks PETSC_F90_2PTR_PARAM(pranks));if (*ierr) return;
*ierr = F90Array1dCreate((void*)roffset, MPIU_INT, 1, *nranks+1, aroffset PETSC_F90_2PTR_PARAM(proffset));if (*ierr) return;
*ierr = F90Array1dCreate((void*)rmine, MPIU_INT, 1, roffset[*nranks], armine PETSC_F90_2PTR_PARAM(prmine));if (*ierr) return;
*ierr = F90Array1dCreate((void*)rremote, MPIU_INT, 1, roffset[*nranks], arremote PETSC_F90_2PTR_PARAM(prremote));if (*ierr) return;
#if defined(PETSC_HAVE_F90_ASSUMED_TYPE_NOT_PTR)
PETSC_EXTERN void petscsfbcastbegin_(PetscSF *sf, MPI_Fint *unit, const void *rptr, void *lptr, MPI_Fint *op, PetscErrorCode *ierr)
MPI_Datatype dtype;
MPI_Op cop = MPI_Op_f2c(*op);
*ierr = PetscMPIFortranDatatypeToC(*unit,&dtype);if (*ierr) return;
*ierr = PetscSFBcastBegin(*sf, dtype, rptr, lptr, cop);
PETSC_EXTERN void petscsfbcastend_(PetscSF *sf, MPI_Fint *unit, const void *rptr, void *lptr, MPI_Fint *op, PetscErrorCode *ierr)
MPI_Datatype dtype;
*ierr = PetscSFBcastEnd(*sf, dtype, rptr, lptr, cop);
PETSC_EXTERN void petscsfreducebegin_(PetscSF *sf, MPI_Fint *unit, const void *lptr, void *rptr, MPI_Fint *op, PetscErrorCode *ierr)
MPI_Datatype dtype;
*ierr = PetscSFReduceBegin(*sf, dtype, lptr, rptr, cop);
PETSC_EXTERN void petscsfreduceend_(PetscSF *sf, MPI_Fint *unit, const void *lptr, void *rptr, MPI_Fint *op, PetscErrorCode *ierr)
MPI_Datatype dtype;
*ierr = PetscSFReduceEnd(*sf, dtype, lptr, rptr, cop);
#else
PETSC_EXTERN void petscsfbcastbegin_(PetscSF *sf, MPI_Fint *unit,F90Array1d *rptr, F90Array1d *lptr, MPI_Fint *op, PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(rptrd) PETSC_F90_2PTR_PROTO(lptrd))
MPI_Datatype dtype;
const void *rootdata;
void *leafdata;
*ierr = F90Array1dAccess(rptr, dtype, (void**) &rootdata PETSC_F90_2PTR_PARAM(rptrd));if (*ierr) return;
*ierr = F90Array1dAccess(lptr, dtype, (void**) &leafdata PETSC_F90_2PTR_PARAM(lptrd));if (*ierr) return;
*ierr = PetscSFBcastBegin(*sf, dtype, rootdata, leafdata, cop);
PETSC_EXTERN void petscsfbcastend_(PetscSF *sf, MPI_Fint *unit,F90Array1d *rptr, F90Array1d *lptr, MPI_Fint *op, PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(rptrd) PETSC_F90_2PTR_PROTO(lptrd))
MPI_Datatype dtype;
void *leafdata;
*ierr = PetscSFBcastEnd(*sf, dtype, rootdata, leafdata, cop);
PETSC_EXTERN void petscsfreducebegin_(PetscSF *sf, MPI_Fint *unit,F90Array1d *lptr, F90Array1d *rptr, MPI_Fint *op, PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(lptrd) PETSC_F90_2PTR_PROTO(rptrd))
MPI_Datatype dtype;
void *leafdata;
*ierr = PetscSFReduceBegin(*sf, dtype, rootdata, leafdata, cop);
PETSC_EXTERN void petscsfreduceend_(PetscSF *sf, MPI_Fint *unit,F90Array1d *lptr, F90Array1d *rptr, MPI_Fint *op, PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(lptrd) PETSC_F90_2PTR_PROTO(rptrd))
MPI_Datatype dtype;
void *leafdata;
*ierr = PetscSFReduceEnd(*sf, dtype, rootdata, leafdata, cop);
PETSC_EXTERN void petscsfviewfromoptions_(PetscSF *ao,PetscObject obj,char* type,PetscErrorCode *ierr,PETSC_FORTRAN_CHARLEN_T len)
char *t;
FIXCHAR(type,len,t);
CHKFORTRANNULLOBJECT(obj);
*ierr = PetscSFViewFromOptions(*ao,obj,t);if (*ierr) return;
FREECHAR(type,t);
PETSC_EXTERN void petscsfdestroy_(PetscSF *x,int *ierr)
PETSC_FORTRAN_OBJECT_F_DESTROYED_TO_C_NULL(x);
*ierr = PetscSFDestroy(x); if (*ierr) return;
PETSC_FORTRAN_OBJECT_C_NULL_TO_F_DESTROYED(x);
#endif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230111/21d4c2da/attachment-0001.obj>
