[petsc-users] PetscSF Fortran interface
Junchao Zhang
junchao.zhang at gmail.com
Tue Jan 10 15:42:33 CST 2023
Hi, Nicholas,
It seems we have implemented it, but with another name,
PetscSFCreateSectionSFF90, see
https://gitlab.com/petsc/petsc/-/merge_requests/5386
Try it to see if it works!
--Junchao Zhang
On Tue, Jan 10, 2023 at 11:45 AM Nicholas Arnold-Medabalimi <
narnoldm at umich.edu> wrote:
> Er to be honest I still can't get my stub to compile properly, and I don't
> know how to go about making a merge request. But here is what I am
> attempting right now. Let me know how best to proceed
> Its not exactly clear to me how to setup up the remote offset properly.
> in src/vec/is/sf/interface/ftn-custom/zsf.c
> PETSC_EXTERN void petscsfcreatesectionsf(PetscSF *sf, PetscSection
> *rootSection, F90Array1d *aremoteOffsets, PetscSection *leafSection,
> PetscSF *sectionSF, int * ierr PETSC_F90_2PTR_PROTO(remoteoffsetsd))
> int * remoteOffsets;
> *ierr = F90Array1dAccess(aremoteOffsets, PETSC_INT, (void**)
> &remoteOffsets PETSC_F90_2PTR_PARAM(remoteoffsetsd));if (*ierr) return;
> *ierr = PetscSFCreateSectionSF(*sf,*rootSection,
> &remoteOffsets,*leafSection,*sectionSF);if (*ierr) return;
> This is the sticking point.
> Sincerely
> Nicholas
> On Tue, Jan 10, 2023 at 12:38 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> Hi, Nicholas,
>> Could you make a merge request to PETSc and then our Fortran experts
>> can comment on your MR?
>> Thanks.
>> --Junchao Zhang
>> On Tue, Jan 10, 2023 at 11:10 AM Nicholas Arnold-Medabalimi <
>>> Hi Junchao
>>> I think I'm almost there, but I could use some insight into how to use
>>> the PETSC_F90_2PTR_PROTO and F90Array1dAccess for the remoteOffset
>>> parameter input so if another function comes up, I can add it myself
>>> without wasting your time.
>>> I am very grateful for your help and time.
>>> Sincerely
>>> Nicholas
>>> On Tue, Jan 10, 2023 at 10:55 AM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> Hi, Nicholas,
>>>> I am not a fortran guy, but I will try to add petscsfcreatesectionsf.
>>>> Thanks.
>>>> --Junchao Zhang
>>>> On Tue, Jan 10, 2023 at 12:50 AM Nicholas Arnold-Medabalimi <
>>>>> I think it should be something like this, but I'm not very fluent in
>>>>> Fortran C interop syntax. Any advice would be appreciated. Thanks
>>>>> PETSC_EXTERN void petscsfcreatesectionsf(PetscSF *sf, PetscSection *
>>>>> *ierr = F90Array1dAccess(aremoteOffsets, PETSC_INT, (void**) &
>>>>> *ierr = PetscSFCreateSectionSF(*sf,*rootSection, &remoteOffsets,*
>>>>> On Mon, Jan 9, 2023 at 11:41 PM Nicholas Arnold-Medabalimi <
>>>>>> Hi Junchao
>>>>>> Thanks again for your help in November. I've been using the your
>>>>>> merge request branch quite heavily. Would it be possible to add a
>>>>>> petscsfcreatesectionsf interface as well?
>>>>>> I'm trying to write it myself using your commits as a guide but I
>>>>>> have been struggling with handling the section parameter properly.
>>>>>> Sincerely
>>>>>> Nicholas
>>>>>> On Sat, Nov 19, 2022 at 9:44 PM Junchao Zhang <
>>>>>> junchao.zhang at gmail.com> wrote:
>>>>>>> On Sat, Nov 19, 2022 at 8:05 PM Nicholas Arnold-Medabalimi <
>>>>>>>> Hi
>>>>>>>> Thanks, this is awesome. Thanks for the very prompt fix. Just one
>>>>>>>> question: will the array outputs on the fortran side copies (and need to be
>>>>>>>> deallocated) or direct access to the dmplex?
>>>>>>> Direct access to internal data; no need to deallocate
>>>>>>>> Sincerely
>>>>>>>> Nicholas
>>>>>>>> On Sat, Nov 19, 2022 at 8:21 PM Junchao Zhang <
>>>>>>>>> Hi, Nicholas,
>>>>>>>>> See this MR,
>>>>>>>>> https://gitlab.com/petsc/petsc/-/merge_requests/5860
>>>>>>>>> It is in testing, but you can try branch
>>>>>>>>> jczhang/add-petscsf-fortran to see if it works for you.
>>>>>>>>> Thanks.
>>>>>>>>> --Junchao Zhang
>>>>>>>>> On Sat, Nov 19, 2022 at 4:16 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>> Hi Junchao
>>>>>>>>>> Thanks. I was wondering if there is any update on this. I may
>>>>>>>>>> write a small interface for those two routines myself in the interim but
>>>>>>>>>> I'd appreciate any insight you have.
>>>>>>>>>> Sincerely
>>>>>>>>>> Nicholas
>>>>>>>>>> On Wed, Nov 16, 2022 at 10:39 PM Junchao Zhang <
>>>>>>>>>>> Hi, Nicholas,
>>>>>>>>>>> I will have a look and get back to you.
>>>>>>>>>>> Thanks.
>>>>>>>>>>> --Junchao Zhang
>>>>>>>>>>> On Wed, Nov 16, 2022 at 9:27 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>>>> Hi Petsc Users
>>>>>>>>>>>> I'm in the process of adding some Petsc for mesh management
>>>>>>>>>>>> into an existing Fortran Solver. It has been relatively straightforward so
>>>>>>>>>>>> far but I am running into an issue with using PetscSF routines. Some like
>>>>>>>>>>>> the PetscSFGetGraph work no problem but a few of my routines require the
>>>>>>>>>>>> use of PetscSFGetLeafRanks and PetscSFGetRootRanks and those don't seem to
>>>>>>>>>>>> be in the fortran interface and I just get a linking error. I also don't
>>>>>>>>>>>> seem to see a PetscSF file in the finclude. Any clarification or assistance
>>>>>>>>>>>> Sincerely
>>>>>>>>>>>> Nicholas
>>>>>>>>>>>> Ph.D. Candidate
>>>>>>>>>>>> Computational Aeroscience Lab
>>>>>>>>>>>> University of Michigan
>>>>>>>>>> Ph.D. Candidate
>>>>>>>> Ph.D. Candidate
>>>>>> Ph.D. Candidate
>>>>> Ph.D. Candidate
>>> Ph.D. Candidate
> Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230110/d0c044ad/attachment-0001.html>
