[petsc-users] PetscSF Fortran interface
Nicholas Arnold-Medabalimi narnoldm at umich.edu
Tue Jan 10 11:44:36 CST 2023
Er to be honest I still can't get my stub to compile properly, and I don't
know how to go about making a merge request. But here is what I am
attempting right now. Let me know how best to proceed
Its not exactly clear to me how to setup up the remote offset properly.
in src/vec/is/sf/interface/ftn-custom/zsf.c
PETSC_EXTERN void petscsfcreatesectionsf(PetscSF *sf, PetscSection
*rootSection, F90Array1d *aremoteOffsets, PetscSection *leafSection,
PetscSF *sectionSF, int * ierr PETSC_F90_2PTR_PROTO(remoteoffsetsd))
  int * remoteOffsets;
  *ierr = F90Array1dAccess(aremoteOffsets, PETSC_INT, (void**)
&remoteOffsets PETSC_F90_2PTR_PARAM(remoteoffsetsd));if (*ierr) return;
  *ierr = PetscSFCreateSectionSF(*sf,*rootSection,
&remoteOffsets,*leafSection,*sectionSF);if (*ierr) return;
This is the sticking point.
Sincerely
Nicholas
On Tue, Jan 10, 2023 at 12:38 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> Hi, Nicholas,
>   Could you make a merge request to PETSc and then our Fortran experts can
> comment on your MR?
>   Thanks.
> --Junchao Zhang
> On Tue, Jan 10, 2023 at 11:10 AM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Hi Junchao
>> I think I'm almost there, but I could use some insight into how to use
>> the PETSC_F90_2PTR_PROTO and F90Array1dAccess for the remoteOffset
>> parameter input so if another function comes up, I can add it myself
>> without wasting your time.
>> I am very grateful for your help and time.
>> Sincerely
>> Nicholas
>> On Tue, Jan 10, 2023 at 10:55 AM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> Hi, Nicholas,
>>>    I am not a fortran guy, but I will try to add petscsfcreatesectionsf.
>>>    Thanks.
>>> --Junchao Zhang
>>> On Tue, Jan 10, 2023 at 12:50 AM Nicholas Arnold-Medabalimi <
>>>> I think it should be something like this, but I'm not very fluent in
>>>> Fortran C interop syntax. Any advice would be appreciated. Thanks
>>>> PETSC_EXTERN void petscsfcreatesectionsf(PetscSF *sf, PetscSection *
>>>>   *ierr = F90Array1dAccess(aremoteOffsets, PETSC_INT, (void**) &
>>>>   *ierr = PetscSFCreateSectionSF(*sf,*rootSection, &remoteOffsets,*
>>>> On Mon, Jan 9, 2023 at 11:41 PM Nicholas Arnold-Medabalimi <
>>>>> Hi Junchao
>>>>> Thanks again for your help in November. I've been using the your merge
>>>>> request branch quite heavily. Would it be possible to add a
>>>>> petscsfcreatesectionsf interface as well?
>>>>> I'm trying to write it myself using your commits as a guide but I have
>>>>> been struggling with handling the section parameter properly.
>>>>> Sincerely
>>>>> Nicholas
>>>>> On Sat, Nov 19, 2022 at 9:44 PM Junchao Zhang <junchao.zhang at gmail.com>
>>>>> wrote:
>>>>>> On Sat, Nov 19, 2022 at 8:05 PM Nicholas Arnold-Medabalimi <
>>>>>>> Hi
>>>>>>> Thanks, this is awesome. Thanks for the very prompt fix. Just one
>>>>>>> question: will the array outputs on the fortran side copies (and need to be
>>>>>>> deallocated) or direct access to the dmplex?
>>>>>> Direct access to internal data;  no need to deallocate
>>>>>>> Sincerely
>>>>>>> Nicholas
>>>>>>> On Sat, Nov 19, 2022 at 8:21 PM Junchao Zhang <
>>>>>>> junchao.zhang at gmail.com> wrote:
>>>>>>>> Hi, Nicholas,
>>>>>>>>   See this MR, https://gitlab.com/petsc/petsc/-/merge_requests/5860
>>>>>>>>   It is in testing, but you can try branch
>>>>>>>> jczhang/add-petscsf-fortran to see if it works for you.
>>>>>>>>   Thanks.
>>>>>>>> --Junchao Zhang
>>>>>>>> On Sat, Nov 19, 2022 at 4:16 PM Nicholas Arnold-Medabalimi <
>>>>>>>>> Hi Junchao
>>>>>>>>> Thanks. I was wondering if there is any update on this. I may
>>>>>>>>> write a small interface for those two routines myself in the interim but
>>>>>>>>> I'd appreciate any insight you have.
>>>>>>>>> Sincerely
>>>>>>>>> Nicholas
>>>>>>>>> On Wed, Nov 16, 2022 at 10:39 PM Junchao Zhang <
>>>>>>>>>> Hi, Nicholas,
>>>>>>>>>>   I will have a look and get back to you.
>>>>>>>>>>   Thanks.
>>>>>>>>>> --Junchao Zhang
>>>>>>>>>> On Wed, Nov 16, 2022 at 9:27 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>>> Hi Petsc Users
>>>>>>>>>>> I'm in the process of adding some Petsc for mesh management into
>>>>>>>>>>> an existing Fortran Solver. It has been relatively straightforward so far
>>>>>>>>>>> but I am running into an issue with using PetscSF routines. Some like the
>>>>>>>>>>> PetscSFGetGraph work no problem but a few of my routines require the use of
>>>>>>>>>>> PetscSFGetLeafRanks and PetscSFGetRootRanks and those don't seem to be in
>>>>>>>>>>> the fortran interface and I just get a linking error. I also don't seem to
>>>>>>>>>>> see a PetscSF file in the finclude. Any clarification or assistance would
>>>>>>>>>>> be appreciated.
>>>>>>>>>>> Sincerely
>>>>>>>>>>> Nicholas
>>>>>>>>>>> Ph.D. Candidate
>>>>>>>>>>> Computational Aeroscience Lab
>>>>>>>>>>> University of Michigan
>>>>>>>>> Ph.D. Candidate
>>>>>>> Ph.D. Candidate
>>>>> Ph.D. Candidate
>>>> Ph.D. Candidate
>> Ph.D. Candidate
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230110/9722cb28/attachment.html>
