[petsc-users] Vec Ownership ranges with Global Section Offsets
Fri Jan 6 09:59:08 CST 2023
On Fri, Jan 6, 2023 at 10:41 AM Nicholas Arnold-Medabalimi <
narnoldm at umich.edu> wrote:
> Hi Matt
> I appreciate the help. The section view is quite extensive because each
> cell has 55 dofs located at the cells and on certain faces. I've appended
> the first of these which corresponds with the output in the first email, to
> save space. The following 54 are exactly the same but offset incremented by
> 1. (or negative 1 for negative offsets)
Okay, from the output it is clear that this vector does not match your
global section. Did you get stateVec by calling DMCreateGlobalVector()?
     Matt
> Thanks for your time
> Nicholas
> On Fri, Jan 6, 2023 at 10:23 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Jan 6, 2023 at 10:10 AM Nicholas Arnold-Medabalimi <
>>> Hi Matt
>>> I apologize for any lack of clarity in the initial email.
>>> looking at the initial output on rank 1
>>> write(*,*) "cell",i,"offset",offset,'oStart',oStart, offset-oStart
>>> cell           0 offset        2475 oStart        2640        -165
>>>  cell           1 offset        2530 oStart        2640        -110
>>>  cell           2 offset        2585 oStart        2640         -55
>>>  cell           3 offset        2640 oStart        2640           0
>>> cell          15 offset        -771 oStart        2640       -3411
>>> cell 15 provides a negative offset because it is the overlap cell (that
>>> is unowned)
>>> The remained of cells are all owned. However, the first 3 cells (0,1,2)
>>> return an offset that is less than the starting ownership range. I would
>>> expect cell 0 to start at offset 2640 at minimum.
>> Send the output for this section
>>   call PetscSectionView(section, PETSC_VIEWER_STDOUT_WORLD);
>>   Thanks,
>>      Matt
>>> Sincerely
>>> Nicholas
>>> On Fri, Jan 6, 2023 at 10:05 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Fri, Jan 6, 2023 at 9:56 AM Nicholas Arnold-Medabalimi <
>>>>> Apologies. If it helps, there is one cell of overlap in this small
>>>>> test case for a 2D mesh that is 1 cell in height and a number of cells in
>>>>> length. .
>>>>> process 0
>>>>>  Petsc VecGetLocalSize        2750
>>>>>  size(stateVecV)        2750
>>>>> process 1
>>>>>  Petsc VecGetLocalSize        2640
>>>>>  size(stateVecV)        2640
>>>> The offsets shown below are well-within these sizes. I do not
>>>> understand the problem.
>>>>   Thanks,
>>>>      Matt
>>>>> On Fri, Jan 6, 2023 at 9:51 AM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Fri, Jan 6, 2023 at 9:37 AM Nicholas Arnold-Medabalimi <
>>>>>>> Hi Matt
>>>>>>> I made a typo on the line statVecV(offset) = <set to something> in
>>>>>>> my example, I agree. (I wrote that offhand since the actual assignment is
>>>>>>> much larger) I should be statVecV(offset+1) = <assignment> so I'm confident
>>>>>>> it's not a 1 0 indexing thing.
>>>>>>> My question is more related to what is happening in the offsets. c0
>>>>>>> and c1 are pulled using DMplexgetheight stratum, so they are zero-indexed
>>>>>>> (which is why I loop from c0 to (c1-1)).
>>>>>>> For the size inquiries. on processor 0
>>>>>>>  Petsc VecGetSize(stateVec)        5390
>>>>>> I need to see VecGetLocalSize()
>>>>>>   Matt
>>>>>>> on processor 1
>>>>>>> Petsc VecGetSize 5390
>>>>>>> It's quite weird to me that processor one can have a positive offset
>>>>>>> that is less than its starting ownership index (in the initial email
>>>>>>> output).
>>>>>>> Thanks for the assistance
>>>>>>> Nicholas
>>>>>>> On Fri, Jan 6, 2023 at 9:20 AM Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Fri, Jan 6, 2023 at 2:28 AM Nicholas Arnold-Medabalimi <
>>>>>>>>> Hi Petsc Users,
>>>>>>>>> I'm working with a dmplex system with a subsampled mesh
>>>>>>>>> distributed with an overlap of 1.
>>>>>>>>> I'm encountering unusual situations when using
>>>>>>>>> VecGetOwnershipRange to adjust the offset received from a global section.
>>>>>>>>> The logic of the following code is first to get the offset needed to index
>>>>>>>>> a global vector while still being able to check if it is an overlapped cell
>>>>>>>>> and skip if needed while counting the owned cells.
>>>>>>>>> call DMGetGlobalSection(dmplex,section,ierr)
>>>>>>>>> call VecGetArrayF90(stateVec,stateVecV,ierr)
>>>>>>>>> call VecGetOwnershipRange(stateVec,oStart,oEnd,ierr)
>>>>>>>>> do i = c0, (c1-1)
>>>>>>>>>     call PetscSectionGetOffset(section,i,offset,ierr)
>>>>>>>>> oStart
>>>>>>>>>     if(offset<0) then
>>>>>>>>>         cycle
>>>>>>>>>     endif
>>>>>>>>> offset=offset-oStart
>>>>>>>>> plexcells=plexcells+1
>>>>>>>>> stateVecV(offset)= <set to something> enddo
>>>>>>>>> I'm noticing some very weird results that I've appended below. The
>>>>>>>>> GetOffset documentation notes that a negative offset indicates an unowned
>>>>>>>>> point (which I use to cycle). However, the offset subtraction with oStart
>>>>>>>>> will yield an illegal index for the Vector access. I see that on the
>>>>>>>>> documentation for GetOwnershipRange, it notes that this may be
>>>>>>>>> "ill-defined"  but I wanted to see if this is type of ill-defined I can
>>>>>>>>> expect or there is just something terribly wrong with my PetscSection.(both
>>>>>>>>> the Vec and Section were produced from DMPlexDistributeField so should by
>>>>>>>>> definition have synchronized section information) I was wondering if there
>>>>>>>>> is a possible output and/or the best way to index the vector. I'm thinking
>>>>>>>>> of subtracting the offset of cell 0 perhaps?
>>>>>>>> Can you show your vector sizes? Are you sure it is not the fact
>>>>>>>> that F90 arrays use 1-based indices, but these are 0-based offsets?
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> on rank 0
>>>>>>>>>  cell           0 offset           0 oStart           0           0
>>>>>>>>>  cell           1 offset          55 oStart           0          55
>>>>>>>>>  cell           2 offset         110 oStart           0         110
>>>>>>>>>  cell           3 offset         165 oStart           0         165
>>>>>>>>>  cell           4 offset         220 oStart           0         220
>>>>>>>>>  cell           5 offset         275 oStart           0         275
>>>>>>>>>  cell           6 offset         330 oStart           0         330
>>>>>>>>>  cell           7 offset         385 oStart           0         385
>>>>>>>>>  cell           8 offset         440 oStart           0         440
>>>>>>>>>  cell           9 offset         495 oStart           0         495
>>>>>>>>>  cell          10 offset         550 oStart           0         550
>>>>>>>>>  cell          11 offset         605 oStart           0         605
>>>>>>>>>  cell          12 offset         660 oStart           0         660
>>>>>>>>>  cell          13 offset         715 oStart           0         715
>>>>>>>>> and on rank one
>>>>>>>>>  cell           4 offset        2695 oStart        2640          55
>>>>>>>>>  cell           5 offset        2750 oStart        2640         110
>>>>>>>>>  cell           6 offset        2805 oStart        2640         165
>>>>>>>>>  cell           7 offset        2860 oStart        2640         220
>>>>>>>>>  cell           8 offset        2915 oStart        2640         275
>>>>>>>>>  cell           9 offset        2970 oStart        2640         330
>>>>>>>>>  cell          10 offset        3025 oStart        2640         385
>>>>>>>>>  cell          11 offset        3080 oStart        2640         440
>>>>>>>>>  cell          12 offset        3135 oStart        2640         495
>>>>>>>>>  cell          13 offset        3190 oStart        2640         550
>>>>>>>>>  cell          14 offset        3245 oStart        2640         605
>>>>>>>>> Sincerely
>>>>>>>>> Nicholas
>>>>>>>>> Ph.D. Candidate
>>>>>>>>> Computational Aeroscience Lab
>>>>>>>>> University of Michigan
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>> Ph.D. Candidate
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> Ph.D. Candidate
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Ph.D. Candidate
>> experiments lead.
>> -- Norbert Wiener
> Ph.D. Candidate
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230106/2b4c8ab3/attachment-0001.html>
