[petsc-users] Error running configure on HDF5 in PETSc-3.18.3
Pierre Jolivet pierre at joliv.et
Fri Jan 6 09:58:51 CST 2023
> On 6 Jan 2023, at 4:49 PM, Danyang Su <danyang.su at gmail.com> wrote:
> Hi All,
> I get ‘Error running configure on HDF5’ in PETSc-3.18.3 on MacOS, but no problem on Ubuntu. Attached is the configuration log file.
> ./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-mumps --download-scalapack --download-parmetis --download-metis --download-ptscotch --download-fblaslapack --download-mpich --download-hypre --download-superlu_dist --download-hdf5=yes --with-debugging=0 --download-cmake --with-hdf5-fortran-bindings
> Any idea on this?
Could you try to reconfigure in a shell without conda being activated?
You have PATH=/Users/danyangsu/Soft/Anaconda3/bin:/Users/danyangsu/Soft/Anaconda3/condabin:[…] which typically results in a broken configuration.
Pierre
> Thanks,
> Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230106/5bc94844/attachment.html>
